Old Oct 22, 2014, 09:33 PM
Sandman70 is offline
Find More Posts by Sandman70
John
Willow Grove, PA
Joined Nov 2007
First build and have an issue
I went to install the aileron rods and it appears they are way too long (see pics). Since this is my first build I wanted to make sure before I get the dremel out and make a permanent mistake. Let me know if the rods need to be cut. Thanks
Sandman70 is offline Find More Posts by Sandman70
Old Oct 22, 2014, 10:25 PM
stevelmaa is offline
Find More Posts by stevelmaa
Renton, Wa.
Joined Feb 2006
Hi Sandman. Make sure that those rods are not for the rudder and elevator, since they are so much longer. If they are not, or you have the proper length rods for the rudder and elevator, cut to fit. Make sure the aileron servos centered. Hope that helps.
stevelmaa is offline Find More Posts by stevelmaa
Old Oct 23, 2014, 01:22 AM
Digital Don is offline
Find More Posts by Digital Don
Digital Don's Avatar
United States, IL, Manteno
Joined Dec 2006
Sandman70,
Are those the landing gear?
Don
Digital Don is offline Find More Posts by Digital Don
Old Oct 23, 2014, 07:29 AM
John
Willow Grove, PA
Joined Nov 2007
Thank you!
Originally Posted by Digital Don View Post
Sandman70,
Don
I think your right and will check it out tonight. I was wondering why they made the diameter so much thicker than the rudder and elevator rods but never thought to check the landing gear rods. I can't believe I made this stupid of a mistake . Thank you for pointing it out Don!
John
Old Oct 23, 2014, 09:04 AM
Kricke is offline
Find More Posts by Kricke
Gasser 3D newb
Sweden, Sodermanland County
Joined Mar 2014
Sandman
You have the aileron servo arm in the wrong direction..
The "U" should face forward.
//Kricke
Kricke is offline Find More Posts by Kricke
Old Oct 23, 2014, 12:22 PM
John
Willow Grove, PA
Joined Nov 2007
Originally Posted by Kricke View Post
Sandman
//Kricke
Maybe I should have someone else build this
At least this is an easier fix. Thanks for pointing it out.
Old Oct 23, 2014, 04:23 PM
Kricke is offline
Gasser 3D newb
Joined Mar 2014
No worries.
There are so many different styles to build these planes, so you need to test and se whats working for you.
If you didn't get a proper manual for your plane my tip is to go to http://www.twistedhobbys.com/ and snag some manual of a similar plane and study how they do it and adapt.
//K
Old Oct 23, 2014, 06:36 PM
spastic is offline
Find More Posts by spastic
ProBro Spaz
spastic's Avatar
Buffalo, NY
Joined Aug 2004
looks like a valuehobby epp plane, check my blog i have a laser build that is close to that build. the Landing Gear rods are about 200mm long the aileron rods are shorter about 120mm ish
spastic is offline Find More Posts by spastic
Old Oct 23, 2014, 08:14 PM
John
Willow Grove, PA
Joined Nov 2007
I found your build thread a few days ago and bookmarked it, many thanks for uploading all the pictures! The manual is very vague and I can't see the pics very well, your pics are much easier to see and clear up questions. Hopefully I can start making progressing after undoing the aileron rod mistake!
Discussion Having an issue with the Nano QX TiraULTI Mini Multirotors 5 Sep 16, 2014 07:10 AM
Help! Having an Issue JRAllen Multirotor Talk 0 Aug 19, 2014 12:40 PM
Help! First H Quad build...having issues with all 4 motors spooling during elevator input 68 stang 19 Scratchbuilt Multirotors 10 Apr 22, 2013 07:53 AM
Help! Is this an ESC / Motor issue? (First Quad build) TEDious Multirotor Talk 4 Mar 20, 2013 11:59 AM
Question First Kit build and I found an issue is it an issue? -S- The Builders Workshop 27 Jan 22, 2013 04:30 PM
