Old Feb 22, 2013, 03:42 AM
Roto Rob is offline
Find More Posts by Roto Rob
Denver, CO
Joined Dec 2005
I wonder how they did that. Maybe a printed transfer. Would be some work to spray.
Roto Rob is offline Find More Posts by Roto Rob
Old Feb 22, 2013, 06:48 AM
robertboxhoorn is offline
Find More Posts by robertboxhoorn
Flying Dutchman!
robertboxhoorn's Avatar
Nederland, FL, Emmeloord
Joined Sep 2011
Just paint it pink and make templates from the flowers and spray it the girl is a sticker I guess ;-)
robertboxhoorn is offline Find More Posts by robertboxhoorn
Old Feb 22, 2013, 10:52 AM
chester2240 is offline
Find More Posts by chester2240
chester2240's Avatar
United States, CO, Westminster
Joined Jul 2011
Its from the game acecombate u should see the one for the F-15 its awsome.
chester2240 is offline Find More Posts by chester2240
Old Mar 04, 2013, 07:28 PM
Roto Rob is offline
Denver, CO
Joined Dec 2005
I'm still sort of working on it. Got called away, so didn't have time to clean the paint out of my airbrush. So now its not spraying good. I'll have to clean it.
Old Mar 04, 2013, 08:45 PM
Joined Jul 2011
i soak mine in acetone when i want mine shinny new again
Old Mar 13, 2013, 03:08 PM
Roto Rob is offline
Denver, CO
Joined Dec 2005
Decided to go with a darker color on top, I think I'll keep it lighter on bottom. I think I'll do most of the details with a brush, rather than the airbrush.
Getting close. Will add a little more detail, and need to do the taileron linkages. Found a 10 gram lighter lipo, I'll see if it can put out enough power. I think the CG will be great with the lighter lipo, will see. I'll get some better pictures before I fly it.
Made up linkages, soldered ends on.
Old Aug 03, 2013, 03:51 AM
Roto Rob is offline
Denver, CO
Joined Dec 2005
I haven't forgot about this plane. Just to many important projects keep coming up.
Old Jan 02, 2014, 03:09 AM
Roto Rob is offline
Denver, CO
Joined Dec 2005
It's done now.
For securing the tailerons, I drilled down the center of the carbon tube with a dremel. Then super glued a screw in. After the CA setup, I removed the screw, leaving threads. Used needle nose pliers to tighten the screws after assembly. I needed to lubricate the carbon rod with graphite from a pencil lead, since it was grabbing the shrinkwrap I used for the pivot tube.
The weather is not great here, so will wait for a dry field. I'll try and find a decent camera, for some better pictures before I fly it.
Old Jan 02, 2014, 08:24 AM
ksqm is online now
Find More Posts by ksqm
Hampton, VA
Joined Mar 2009
Glad to see you finished. It should be a sweet maiden. Good luck!
ksqm is online now Find More Posts by ksqm
Old Jan 02, 2014, 11:33 AM
pdawg is online now
Find More Posts by pdawg
Need 4 Speed!
pdawg's Avatar
United States, OH, Dayton
Joined Apr 2004
Great project! Hopefully it will fly as well as it looks!
pdawg is online now Find More Posts by pdawg
Latest blog entry: Visiting Edwards AFB
Old Jan 02, 2014, 04:42 PM
NitroCharged is offline
Find More Posts by NitroCharged
Team30 Micro EDF
NitroCharged's Avatar
Adelaide, Australia
Joined Apr 2004
Glad your back into it Rob. She looks great!
NitroCharged is offline Find More Posts by NitroCharged
Old Jan 02, 2014, 06:49 PM
Roto Rob is offline
Denver, CO
Joined Dec 2005
Thanks.
I'm not sure how I'm going to launch it. Its fairly flat so hard to hold onto. I think a little sandpaper glued on for grips might work. Don't want to dork a first launch. Might hold the wing tip for a discus launch.
Looks like snow for the weekend. So maybe towards the end of next week, the field may dry out.
Old Jan 02, 2014, 11:47 PM
Joined Jul 2011
Where are you planing on flying it at?
Old Jan 03, 2014, 03:42 AM
Roto Rob is offline
Denver, CO
Joined Dec 2005
Looking for a good dry field. Sometimes I go to the Ronney road soccer field.
With a 400mah Hyperion 35c 2 cell its weight came in at 104.5 grams. I had a hard time measuring thrust. Holding the F22 it is almost weightless at full thrust. So must be close to 1 to 1, thrust to weight. After some playing around tonight, I think it will be easy to launch, since it wants to fly out of my hand. Probably will be some short flights with only 400mah though.
Sold TX LPU: 30mm EPO Nano F-86 Sabre - PNP w/batteries: $55 Roswalt Aircraft - Electric - Jets (FS/W) 2 Jul 28, 2012 04:03 PM
Sold LPU San Antonio TX: JPower 50mm MiG-15, F-86, F-22 and F-35. FoamJunkE Aircraft - Electric - Jets (FS/W) 3 May 09, 2012 12:00 PM
For Sale Great Planes F-86 Micro EDF 30mm with Anylink $85 Shipped tsever00 Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 4 Mar 28, 2012 03:01 PM
Alert HEY EVERYONE! the great planes 30mm f-86 foam parts are all in stock! Mason W. Micro EDF Jets and Power Systems 5 Mar 05, 2012 09:28 PM
Off Site Great Planes 30mm Brushless Micro EDF F-86 Sabre battery adapters glenn2626 Aircraft - Electric - Batteries & Chargers (FS/W) 0 Feb 26, 2012 01:17 PM
