Old Mar 15, 2009, 11:07 AM
Dr Kiwi is offline
Find More Posts by Dr Kiwi
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
Mini-Review
Turnigy C3530-1100 (~1075Kv)
Mini-Review - Turnigy C3530-1100 (~1075Kv)
The last of the motors lent to me by Steve Atchinson (Butch777). This gold Turnigy C3530-1050 is said, by Hobby-City, to be most efficient at 10A-15A, but no max. current draw is given. Strangely, H-C over-stated the weight - with the supplied connectors I made it only 73g, not 77g.
Reading the reviews one wonders who is writing them, what sort of measuring devices (and math skills) they have, and what their definitions of "barely warm" can be. It seems to me that the typical user (abuser) is pushing this motor far too hard, with props which are far too big for it. Let me share some of the weirdness: With a 10x5 guys are stating that it draws, variously, 15A, 19A, 22A - the guy running the 22A said it got to 70C in 4 minutes of mixed flying. Another guy using a 10x6 measured 20A/240W and said "good cooling is a must". A 10x7 was variously quoted as 16A/220W on 3s (13.75v for 3s?), 25A/250W ("not even warm") and 24A/303W (12.6v for 3s?, "80C after 4 minutes of mixed flying"). An 11x4.7 APC SF drew "22A-23A max" and "30A-40A", yet a 10x8x4 drew only 23A/197W (8.56v for 3s?). A 12x6 drew, variously, 25A/250W, 27A/270W, 30A ("barely warm") and 38A/400W!
After running some no-loads, I tried 8x4 through 11x7 GWS HD. Since the 11x7 was obviously too big, yet the 10x6 was not pushing it too hard, I then tried a 10x6x3 GWS HD.
The 10x6 GWS HD drew 16.05A/172W @ 10.7v, and the motor did not get much more than warm. Over 32oz thrust @ 47mph is not too bad. The 11x7 GWS HD was too much for it - even though it drew only a little over 20A the motor could not hold rpm and amp draw, and got hot (~75C) fast - the 10x6 x3 GWS HD seems to be a good compromise for getting as much as one can without over-doing it - 36oz @ 43mph from 19.10A/203W.
Cheers, Phil
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old Mar 15, 2009, 11:30 AM
eckace1 is offline
Find More Posts by eckace1
OFF TOPIC POSTER
Des Moines IA
Joined Dec 2005
http://www.rcgroups.com/forums/attac...mentid=2400695 Does that prop look bent to you? must be an optical illusion. Robert
eckace1 is offline Find More Posts by eckace1
Old Mar 15, 2009, 12:18 PM
Dr Kiwi is offline
Dr Kiwi's Avatar
Joined May 2003
Remember it will look odd 'cos it's on backward, as a pusher.
Old Mar 15, 2009, 11:41 PM
Butch777 is offline
Find More Posts by Butch777
Livermore, CA
Joined Sep 2004
Hey Doc,
How does this motor hold up against the Turnigy 3530 Sk black and silver outrunner you tested a while back?? Any pros or cons??
And do you think the SK is worth the extra money? Thanks, Butch
Butch777 is offline Find More Posts by Butch777
Old Mar 16, 2009, 12:11 AM
rcalldaylong is offline
Find More Posts by rcalldaylong
Dude, I do fly all day long!
rcalldaylong's Avatar
San Jose, California
Joined Dec 2007
if you still have the setup handy, would you be so kind to try a APC 11x5.5E?
rcalldaylong is offline Find More Posts by rcalldaylong
Old Mar 16, 2009, 04:06 AM
vintage1 is offline
Find More Posts by vintage1
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
I have this flying on apc 10x7. We did meter it and on a fresh, but not especially good, 3s pack it was around 20A.
I personally found it an excellent motor, I suspect that unloading will drop the current a lot and an 11x5.5 is on, but would be wary of static testing with that.
Also the efficiency starts to roll off a lot I suspect..if you really want much over 200W, pick a bigger motor.
In my head, this is a 200W/20A motor. Runs best on 3s or 4s. Or if you want to swing very large props slow, 2s, but the power will be less..about 150W at best.
Old Mar 16, 2009, 01:51 PM
Dr Kiwi is offline
Dr Kiwi's Avatar
Joined May 2003
It seems we agree to agree, Vintage! Why some of these idiots who post "reviews on H-C think they can run 12x6 at 300W-400W I have no clue (and neither do they!). I will try the 11x5.5 APC E just for the heck of it... if that unloads a fair bit in the air, then it would be fine. I did put ?20A max for a reason, and the 10x6x3 got it as close as one can expect to that point (19.10A/203W).
Old Mar 16, 2009, 02:18 PM
Joined Dec 2007
Yes 12x6 would be pushing it. I've tried it on 12x6 and that motor would get really hot and smelled after just 10 secs of WOT.
I'm asking because I was running that on 11x5.5 and it does fly fairly well, but back then I didn't have an ampmeter...and have since sold the motor. Now I'm thinking about buying the motor again and using it on 11x5.5
thanks.
Old Mar 16, 2009, 02:49 PM
vintage1 is offline
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
To be honest, if I wanted an 11x5.5 or 11x7 I'd got to the 3536 instead: chances are you could use a smaller battery for the same duration as the efficiency would be better.
Old Mar 16, 2009, 02:54 PM
myp is offline
myp
Find More Posts by myp
myp
Joined Oct 2007
I have this motor on my SA Groove. It draws 21A static WOT with the GWS 10x5 HD. Power was supplied by a fresh set of 25C Xcite 1800 battery. The difference with Dr Kiwi's #s can probably be attributed to the (infamous) Kv variance of HC motors. I did try an APC 11x5.5 on the Groove. It drew 24A static WOT. In the air, I could not tell the difference from the GWS 10x6 (... I am still learning). It did seemed a little easier to hover the Groove probably due to more thrust provided at lower rpm by the 11 in prop.
myp is offline Find More Posts by myp
Old Mar 16, 2009, 03:01 PM
Dr Kiwi is offline
Dr Kiwi's Avatar
Joined May 2003
21A with a 10x6 GWS HD - maybe your pack was delivering close to 12v at the outset...but I doubt that even that would increase amp draw from 16A to 21A.... or, as you say, your motor might be higher Kv... who knows!
Old Mar 16, 2009, 03:15 PM
Joined Dec 2007
I'd love to use the 10x6, but the plane I'm putting this on has a huge cowl and pretty much a 10x6 dosn't push any air.
Old Mar 16, 2009, 03:22 PM
Dr Kiwi is offline
Dr Kiwi's Avatar
Joined May 2003
You need a lower Kv motor so that you can run a 12"-13" prop.
Old Mar 16, 2009, 03:31 PM
Joined Dec 2007
Well, I'm trying to find the right balance...I don't want to go too low on KV, since I want to go fast, but at the same time want to save on weight as well as good amp draw.
I would guess that on 11x5.5 it's going to hit 20-23 amps somewhere and onloading in the air might be ok.
Old Mar 16, 2009, 03:33 PM
vintage1 is offline
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
It wont be fast on an 11x5.5.
Want more like a 10x10, but in reality, you want a bigger motor.
Discussion Question about Turnigy C3530- 1100 Trumanmc Power Systems 11 Jan 26, 2009 08:43 PM
Sold Turnigy C3530-1100 motor rsasaki Aircraft - Electric - Power Systems (FS/W) 2 Oct 23, 2008 06:07 PM
Discussion Turnigy c3530-1100.. What plane? FlightCrazed 3D Flying 3 Aug 15, 2008 11:14 PM
Sold Turnigy C3530 1100kv Brushless Sproket Aircraft - Electric - Power Systems (FS/W) 2 Jun 14, 2008 01:04 AM
