May 26, 2009, 09:47 PM
Omaha, Ne.
Joined Jul 2004
3 OS 60 size engines that won't run.
I have 3 older (exagerated!!) OS engines that I can't get to run. I haven't tried them for about 3 years now and just put them on the stand this last weekend. They are a 60 FP, a 61 SF, and an SR 60. I have an OS engine book form 1990 that goes back quite a ways and it doesn't even mention the SR series, just the FSR.
The SR & the FP have plenty of compression so I'm not as worried about those 2 as the SF. I had this on my senior telemaster 4 years ago. It pooped out on a very hot summer day-maybe I ran it a little too lean-I'm not sure? This one has very poor compression. I took the head off and removed the back plate and cylinder liner. The piston ring seems to be seized in the piston. I tired soaking in carburetor cleaner, spraying with the aerosol carb cleaner and letting it sit-all of the usual things that worked for my other engines. I don't know if I can even find a new piston ring for a 61SF? The other thing was how do you get the rod off of the crank? Do you heat it up, or is there a special trick or tool to release it from the crank? It will slide back about 1/4th of the way then stops.
This engine did power my telemaster around quite well but not like an FX. I bought this one used a long time ago then used it myself. However, the rest of it is in good shape and I would like to keep it if I can. Thanks for bearing through this with me. Tracy.
