This thread is privately moderated by RAY GWS, who may elect to delete unwanted replies.
Old Jan 22, 2013, 10:42 AM
yorkshire UK
Joined Oct 2007
Originally Posted by fvega View Post
I am working on finishing the fw 190 and noted that the cowl is very lose over the nose, there is about a 1/4 inch gap all around, is that the same experience for others? I have done a couple of GWS planes and the cowls are always a good fit.
That does seem looser then mine was, but as above glass the inside for strength anyway will probably sort it out to fit better, the alternative is to cut it length ways and then glue it back tighter.
Mine is still sitting on top of my wardrobe as the field is terrible still and getting worse, nothing with wheel is worth trying apart from my little tiger moth which I can take off and land on the tiny car park.
I'm really hoping the school will sort out a better job of it this year, I got lots of planes with retracts when the field was well kept and now I can use them
Still, I'm loving my blaster dlg.
nigelsheffield is offline Find More Posts by nigelsheffield
Old Jan 22, 2013, 06:23 PM
fvega
United States, VA, Newport News
Joined Jul 2007
thanks for the comments on the cowl one last advice request: I seen posting by others about using the parkzone corsair cowl, any comments on fit? How about the parkzone fw 190 cowl that is still available on e bay is it too small?
Again greatly appreciate the comments
fvega is offline Find More Posts by fvega
Old Jan 22, 2013, 08:23 PM
57sailplane's Avatar
Joined Nov 2008
the pz corsair cowl fits but needs some masaging of the fuse. on my eps version this was easy just had to sand to fit. and epo version might be tuffer. but it looks good when done..
57sailplane is offline Find More Posts by 57sailplane
Old Jan 26, 2013, 02:14 PM
Flyin' low & slow T-28s!
MaladroitFL's Avatar
United States, FL, Vero Beach
Joined Feb 2011
I have the PZ Corsair cowl. It fits nicely, but I glued 3 balsa blocks where the screw holes are so the cowl doesn't pinch or get crooked.
I left the flair on the open end, which doesn't look scale. I should trim it off while I've got it off and see if I can fit the two cowl blisters on. It looks more realistic with the "bumps" under the cowl.
I found out my crash had loosened the motor mount. If all goes right, I'll be flying it in the morning (Sunday).
Mac
MaladroitFL is offline Find More Posts by MaladroitFL
Old Jan 26, 2013, 06:24 PM
GiusedtoBe's Avatar
Tennessee
Joined Apr 2009
PZ FW-190 cowl is too small
GiusedtoBe is offline Find More Posts by GiusedtoBe
Old Jan 26, 2013, 06:53 PM
Joined Nov 2008
yep so cut out the grill-fan on the pz 190 with its outer ring and glue to the pz corsair cowl then trim flaired end. this is how it looks
Old Jan 27, 2013, 10:56 AM
Joined Feb 2011
It seems to fit just fine on my FW190.
Mac
Old Jan 27, 2013, 11:32 AM
GiusedtoBe's Avatar
Tennessee
Joined Apr 2009
Mac
Well I could be mistaken but I believe yours is the Corsair cowl.
Old Jan 29, 2013, 05:11 PM
Joined Feb 2011
Right. It's the Corsair - not the PZ FW190 cowl.
That's what I wrote above though... I thought you meant something else....
http://www.rcgroups.com/forums/showp...postcount=2554
My flight went perfectly, BTW!
The 190 flew well and landed a little hard, but the gear withstood it. I think this plane needs to land hot.
Old Jan 30, 2013, 11:49 AM
yorkshire UK
Joined Oct 2007
focke wulf gws fw190 in epo with servoless retracts and flaps (4 min 28 sec)
Check out mine with flaps and retracts, comes in a LOT slower with flaps, just have to watch out for tip stall if landing in a cross wind as was the case on this flight.
If I land into the wind it's much slower then in vid but the ground is rough everywhere apart from the strip that I landed on and so I stick to the smoother stuff!
The field has been terrible though the past year and so I cannot take off and land at all!
A m8 put flaps on his and was amazed at how much nicer the landing were but unfortunately he put the servos arms sticking out of bottom of plane rather far and when he tried to belly land it ripped the servos up. I put mine so that hardly any arm shows from bottom and have not bellied it!
I would think that unless you are using wheels then stick to no flaps and just take a long approach.
Old Jan 30, 2013, 01:24 PM
Joined Nov 2008
um,
realy havnt seen a problem with landing this thing without flaps, when i load this thing up for long flight times i use a 4s 5000mah pack and the plane weighs in at 56 oz. its hard on the heavier gear i use as it bends it on taxi but still lands well, need to put even heavier gear in.
when i land with all this weight i am realy pulling back on the stick and cloping the plane it realy holds in the air nicely.
later andrew k
Old Jan 31, 2013, 06:44 AM
yorkshire UK
Joined Oct 2007
5000mah 4 cell??? in a 1m fw190? hard to imagine where it would actually fit!
Some people seem to have well behaved ones but many like me who have the early epo version have found that they need a lot of speed to keep from a nasty tip stall, once the stall has started the only thing to do is allow it to dive and build up speed for a recovery-any attempt to recover b4 speed has built up results in a worse stall/spin, I moved the cog around to see if that helped but it did not, but with flaps down it turned into a pussy cat, with slow tight turns possible.
It's such an easy mod as the flaps are almost there already, a quick cut and some hinges, install a couple of servos and away you go, the flap mod took me no more then 1/2 hour, the retracts took quite a bit longer but was worth it-there is something about seeing the wheels go up after a take off that impresses me (dont ask me why lol).
Old Jan 31, 2013, 08:00 AM
GiusedtoBe's Avatar
Tennessee
Joined Apr 2009
I agree. I put rotaters and flaps on my GWS P-40 and I love to see it lift off and the gear come up.
When I build the 190 I've been hoarding I plan to use both retracts and flaps. I also have several spinners and props from the hobbico/flyzone FW that I plan to use for a more scale look.
Nice landing BTW!
Regards,
Alan
Old Jan 31, 2013, 09:56 AM
chuck
santa barbara, CA
Joined May 2009
after reading comments re. tip stall i feel the need to tell of a recent discovery. mine is one of the early eps versions and has seen many flights, >100 easily. even w/ this being the lighter foam getting cg forward enough was a bit of a struggle. w/ a 80 gram motor i still needed to use a 2250 in the stock battery box to just make book cg. at 33oz , i never thought of this one as light and it flew that way , good but needed some speed both in flight and landing. i got used to it and flew it a lot.
move forward 2 years and i am flying 1 day and have a motor mount failure. motor hanging by the wires ect. get it landed ok dead stick , so its time for a new box style ply motor mount . being that i always wanted to be able to use a smaller battery , i moved the motor out a 1/2" or so and repositioned the cowl. between the mount, moving the motor forward, i was able to use a 1800/3's and balance was slightly forward(<1/4") of where i flew it for years . the plane was still the same auw due to the mount ect but just the small cg change made more difference than i can tell u.
now i am one that likes my planes on the tail heavy side, more responsive , float better ect, but in this case the landing and slow flight is like a different plane. normally i would have played w/ the cg early on but due to battery location and the fact it was at book cg , i just called it good . so the lesson, at least on this one is don't be afraid to go forward at bit further on the cg if u can.
chuck
chas650r is offline Find More Posts by chas650r
Old Jan 31, 2013, 06:21 PM
Joined Nov 2008
yep,
i have never had a problem with cg it will fly werever. this plane is so forgiving. mind you it needs to fly fast it is a war bird but remember it will only roll farther at a higher speed landing. very interesting about the flaps. might do this mod. man you could put a 6s 5000mah pack in this thing it sounds like with flaps. my plane is the early eps version.
by the way last summer i had someone toss this thing at the lake to take off and fly darn near hit a tree because i needed some room to get moving. I did a belly landing with this weight. i had to because there was no runnway. but it can be done. lol
later andrew K
New Product **** GWS-190: Unbeatable Butcher Bird **** RAY GWS Product Announcements 4 May 15, 2007 02:00 AM
Yippee! Balsacraft FW 190 'Butcher Bird' W@CC0 Scale Electric Planes 116 Feb 24, 2006 08:51 AM
the butcher bird(FW-190) kase_kopf Foamies (Kits) 16 Dec 16, 2005 02:47 PM
GWS Corsair tuff little bird xmech Parkflyers 10 Feb 13, 2004 10:34 PM
GWS PT-17 late bird maiden sheerLuck GWS (Grand Wing Servo) 7 Oct 05, 2003 09:50 PM
