Old May 03, 2013, 12:32 AM
Joined Apr 2012
How I Start My OS Max S 35
Normally I prime the intake and squirt a few drops into the exhaust port. With a muffler installed, I point the intake up and put 12 drops into the intake and turn the propeller through compression stroke once. Light the plug, listen for the boil and flip it through forward. If it burns the prime but doesn't start repeat step one.
tigreflyer is offline Find More Posts by tigreflyer
Old May 03, 2013, 01:44 AM
Greggles47
greggles47's Avatar
Sydney OZ
Joined May 2007
Sounds like a complicated job.
Mine's got a muffler on full-time, and all I do is choke it a couple of times, till it feels nice and lose. Then connect the glow driver and turn it over. If it gives a bump, I flick it & it runs. If it doesn't bump, I check the plug is working - usually yes, then check that it's wet enough. Basically though, it usually starts up all the time. No worries.
Greg
greggles47 is offline Find More Posts by greggles47
Old May 03, 2013, 09:19 AM
Joined Apr 2012
I used to start my lower compression engines that way. But I found it hard to get a size consistent prime and prime burn time. Twelve drops down the intake and one pull through compression stroke puts a precise, consistent prime exactly where it needs to be for an instant start. I'll bet someone's going to post some way I never thought of.
Old May 03, 2013, 10:54 AM
I was flying an upright mounted K&B 4011 with muffler. I would put prime in the intake, turn it over once. Attach battery and flip. Usually one flip starts. I sort of noticed, over time, that I was using more and more intake prime to achieve the same result. The front bearing shed its seal. I replaced the front bearing, and, because I had the motor apart, installed a new ring. Result was the the needed prime dropped back to what I started with, and the engine had a hair more power.
Jim Thomerson is offline Find More Posts by Jim Thomerson
For Sale Os max-s 35 jjvb Aircraft - Fuel - Engines and Accessories (FS/W) 2 Jan 12, 2013 11:29 AM
Sold Vintage OS Max-S35 R/C W/Jetstream Muffler In Original Box $35.00 stevster Aircraft - Fuel - Engines and Accessories (FS/W) 2 Jan 05, 2013 05:39 PM
Discussion OS max s 35 with 30 p/s jasburrito Engines 4 Oct 26, 2009 08:57 PM
For Sale OS MAX-H 40 & OS MAX-S 35 fabmaster911 Aircraft - Fuel - Engines and Accessories (FS/W) 0 Jun 08, 2008 09:40 PM
Starting an OS Max FP 35 amuldoon Nitro and Glow Power Cars 3 Jul 22, 2005 04:23 AM
