Old Oct 05, 2012, 08:38 PM
sarkantyu's Avatar
United States, MI, Lake Orion
Joined Feb 2004
Question
Krick engine
Does anyone have any experience with this engine?I have a Victoria that goes with it also that I plan to finish.What else can you tell me about this setup such as should I use a condenser/oil separator? I read some where that the boiler tends to leek.Thanks Joe
sarkantyu is offline Find More Posts by sarkantyu
Old Oct 06, 2012, 04:24 AM
Damp and Dizzy member
Brooks's Avatar
Bozeman, Montana, United States
Joined Aug 2003
I have a similar motor (probably older version) in my Krick Patricia. It ran fine, though motor is showing signs of wear after many years. My boiler did develop a leak in the joint around the water glass, after about 20 years. I replaced it with a custom boiler from Maccsteam.
Brooks is offline Find More Posts by Brooks
Old Oct 06, 2012, 06:04 AM
-kno3-'s Avatar
Romania, Bucuresti, Bucharest
Joined Mar 2008
You should use a condenser, if you don't want your boat and the pond water full of messy oil. And you should also add a steam lubricator, because those two cup oilers are awfully small.
-kno3- is offline Find More Posts by -kno3-
Old Oct 07, 2012, 07:09 AM
sarkantyu's Avatar
Joined Feb 2004
Thanks for your responses.It is just what i was looking for.Can some one of you tell me the what run time I can expect from the unit?Joe
Old Oct 07, 2012, 10:56 PM
Brooks's Avatar
Joined Aug 2003
Run=10-15 minutes, if I recall right. Double cylinder, double-acting engines eat up a lot of steam. As the motor gets broken in, you will be able to run at lower throttle settings, thus the big range of time cited. I run by watch time, usually, once I know the characteristics of the powerplant. You don't want to run the boiler dry, of course, so your first cruises should be short, say 5 minutes then return to shore. This allows you to keep a close eye on water consumption.
Old Oct 08, 2012, 09:01 AM
-kno3-'s Avatar
Joined Mar 2008
I had the Wilesco D49, which has the same boiler and cylinders (in a v-twin configuration) and it could run for at least 30 minutes on a water filling.
Old Oct 08, 2012, 06:52 PM
sarkantyu's Avatar
Joined Feb 2004
Has anyone of you tried to control the flame from the valve on the tank? I thought of soldering a lever on and using a servo to adjust it.What do you think?
Old Oct 08, 2012, 09:59 PM
Brooks's Avatar
Joined Aug 2003
The problem with adjusting the flame remotely (rc) is that the cues one needs to adjust it are unavailable. Sound of the flame, and sight of the flame are the usual cues I use to decide if I've got the gas valve right. W/o those cues, you run the risk of turning the gas too low, and snuffing the flame. By the time you realize what's happened, you may not have enough steam left to return to shore. About the only cue easily visable from shore is the safety popping, and wasting water&steam in a nice plume :-)
My usual procedure is to set the flame high to generate steam from the cold water/cold boiler, adjust it downwards prior to launch of the craft, run for a few minutes, then return to shore to fine tune the flame as needed. Air temperature, gas tank temperature (which drops as you discharge gas), wind, and boat performance all factor into the adjustment.
If you are good at installing telemetry, then gas tank temperature could be relayed to shore. Some of the race car radio systems can monitor temperature (usually car's motor). Perhaps you could put the sensor on the tank. As the tank cools, you need to turn up the gas to maintain the fire since the cool tank's pressure has dropped. W/o such a sensor, the usual method is to notice that the boat is slowing down, and then to bring her to shore so you can manually increase the gas flow (boiler water permitting....the boat will also slow if you run out of water....Machdog installed a gas cutoff servo to prevent boiler damage in that circumstance, see "Steam powered Tramp" thread for details.)
Much of the fun in steamboating, for me, is this hands-on fiddling with the steam plant. Thus, adjustments are a "feature" not a "problem" of model steaming. To each his own, though :-).
http://www.rcgroups.com/forums/showthread.php?t=717385
Old Oct 10, 2012, 09:49 AM
SagittaXC
Soquel CA.
Joined Feb 2007
Krick Victoria
Sar, I've got the exact same set-up...I got mine on a trade (Sailplane for Steam Boat) Where do you buy the lubricator from and what size? And do you really need one?? Sorry, I'm not much help... Jack T. P.S. The Boiler and Victoria Kit Look Bitchen
jacktrotter is online now Find More Posts by jacktrotter
Old Sep 21, 2014, 09:28 PM
United States, NJ, East Hanover
Joined Jul 2013
I just got a Krick Victoria with the boiler, but I dont' have the burner or fuel tank, what fuel does it use? I have the instructions, but there in German. Is it possible someone can sell me an extra burner? Or could you tell me the dimensions of the burner so I could make one? Mainly interested in keeping the fuel to air mixture correct, and rate of fuel used.
mikes112 is offline Find More Posts by mikes112
For Sale Krick Grunau Baby Kit 1:6 scale Dog_Squadron Aircraft - Sailplanes (FS/W) 3 Sep 26, 2012 06:51 PM
Discussion Krick 1/4 Grunau Baby Slopeangel Scale Sailplanes 15 Aug 29, 2012 02:55 AM
Wanted Krick SG38 millow Aircraft - Sailplanes (FS/W) 1 Aug 17, 2012 11:32 PM
Sold Krick U-25 submarine kit MIB redlite Boats (FS/W) 0 Jun 12, 2012 01:40 AM
Sold 3.4m Krick Grunau Baby IIb--Pending payment cpdude Aircraft - Sailplanes (FS/W) 2 Apr 04, 2012 10:16 AM
