Old May 04, 2010, 07:41 PM
niner555's Avatar
Memphis, TN
Joined Jul 2006
Build Log
Hotliner Sport Jet
After seeing Erik v. Schaik's video of his hotliner with a Wemo fan pod on it a few years back:
http://www.rcgroups.com/forums/showthread.php?t=589243
I was amazed at how fast it was for such little power input (400 watts).
Seeing the efficiency of his hotliner EDF, I thought it would be cool to marry the wing and T-tail from a hotliner to a "jet" looking fuselage......... The result being my current project, the Hotliner Sport Jet.
Specs:
* 59" WS, 350 sq. in. wing
* 1500 watt, 65mm Haoye shroud/Minifan rotor hybrid fan unit (ARC 28-47-2 motor, 8S 2200mah lipo)
* CC HV45 ESC
* Estimated 52 ounce AUW
The donor hotliner was a crashed JP Models Ion Pro that a friend gave me:
I cut out the damaged portion of the wing and fiberglassed it back together...... also chopped off the T-tail as well:
niner555 is offline Find More Posts by niner555
Old May 04, 2010, 07:52 PM
niner555's Avatar
Memphis, TN
Joined Jul 2006
Since I was going to scratch build the fuselage, I wanted something unique looking, yet very sleek and aerodynamic. I drafted-up a very basic, hand drawn 2 view drawing. I used good old butcher/freezer paper.....one roll will last a lot of builds
After establishing the basic side and top down views, I moved on to making the former templates....once again, hand drawn/old school lead pencil baby
Old May 04, 2010, 07:58 PM
niner555's Avatar
Memphis, TN
Joined Jul 2006
After getting the forward section templates finished, I cut them out and used rubber cement to glue them onto my balsa sheeting:
Started framing-up and planking the nose section together yesterday.
Old May 04, 2010, 08:07 PM
BVM Viper Fever
pdawg's Avatar
United States, OH, Dayton
Joined Apr 2004
Lookin sweet...and fast
pdawg is online now Find More Posts by pdawg
Old May 05, 2010, 02:14 AM
My project: FAIREY DELTA 1
Erik v. Schaik's Avatar
Uden Volkel, Netherlands
Joined Dec 2003
Sweeeet 9er!!
I upgraded my Lift-off to A123 and it went to 600W. Here some vids:
http://airtoimedia.nl/web/upload/Emi...k_8-7-2007.wmv
This version has glassed wings unlike the 1st version. You can see in the vid the wing does bent in tight corners so I didn't increase power.
A few weeks ago the stab got damaged at a landing. I was approaching and only a small dot visible when a cloud of birds passed behind the Lift-off. I lost the dot in a blink and it went down. It is an easy repair but the new balsa stab needs to wait until the moulds of the fd1 are completed. Just too much balsa dust I cannot deal with at this moment
Keep those pics coming!!
Erik v. Schaik is offline Find More Posts by Erik v. Schaik
Old Jul 15, 2010, 02:47 AM
if you see a weed, pick it
malakiblunt's Avatar
Devon England
Joined Oct 2006
hows this coming along? im realy likeing the look of this, im currently buliding an 80% slipso with a gws40 on top. i think modern high performance F5B F5D models have alot to teach us for scale bulds as well as sport models.
malakiblunt is offline Find More Posts by malakiblunt
Old Aug 08, 2010, 10:52 AM
Camarillo California
lets see some flight video !
Kayaker1 is offline Find More Posts by Kayaker1
Old Jul 30, 2011, 10:36 AM
niner555's Avatar
Memphis, TN
Joined Jul 2006
Well, after taking a year long hiatus on this project, I am back on it, motivated and ready to get it finished.
I decided to make this jet in sections, so that I could maintain a flat, level jig for each one. With the front structure basically finished, I decided to move onto the center section. This was probably the most challenging bit, because this section contains the fiberglass inlet ducting.
I started with gluing-in the beginning former and the end former.
Using this as the jig, I made a tool for the ducting by drawing up some templates, rubber cementing them to pink foam and cutting them out. Then I just glued the sections together, sanded/smoothed them out, waxed-up the tools (cheap automotive Turtle-Wax ) and put two layers of 2oz. glass over them.
I then trimmed the ends, slit the back of the ducts and pulled them off the tool. As you can see, the wax layer pulled off of the foam tools without any damage to the foam itself. With a couple fresh coats of wax, these would be ready to make another set of ducts if needed.
Everything fit just perfect, I am pretty happy with how they turned out.
Finally, I finished the templates for the rear section, glued them to balsa sheeting and cut them out with my scroll saw.
Old Jul 30, 2011, 12:27 PM
frank40's Avatar
Denmark
Joined Sep 2005
niner555...That looks great and nicely build to.
frank40 is offline Find More Posts by frank40
Old Aug 07, 2011, 12:35 AM
niner555's Avatar
Memphis, TN
Joined Jul 2006
Little update......
Finished framing-in the mid-section of the jet to the nose. Installed and trimmed the ducts, made the fan mounts and installed the tail section mounting lugs. I am planning on having a removeable tail section that will attached internally with a long screwdriver, inserted through the tail cone.
Old Aug 07, 2011, 12:22 PM
LuvEvolution7's Avatar
St.Catharines, Ontario
Joined Jan 2009
that is looking very nice. great job so far.
LuvEvolution7 is offline Find More Posts by LuvEvolution7
Old Jan 10, 2012, 10:51 PM
Speed Demon
GregG's Avatar
Antioch,CA,USA
Joined Dec 1999
This is interesting, thanks for the update!
GregG is offline Find More Posts by GregG
Old Jan 21, 2012, 12:16 PM
niner555's Avatar
Memphis, TN
Joined Jul 2006
Finished planking, added the nose and rounded ducting inlets, made the wing fillets and did the first round of balsa filler and sanding.
Taped the T-tail onto the back of the fuselage and now we can see what it is really going to look like.....I am really excited that the vision in my head is starting to become reality
Also taped all the batteries, wires, ESC, BEC, etc. onto the fuselage, just to confirm that with everything in place, I can hit my desired CG. Turned out perfect, with about 1.5" of additional room for the batteries to move around, so I should have no problems being able to fine tune the CG.
Old Jan 21, 2012, 01:14 PM
niner555's Avatar
Memphis, TN
Joined Jul 2006
Just weighed everything and it is sitting right at 51.9 oz. This is before glassing and painting, so I am guessing the final AUW will be closer to 55 oz. than my originally estimated 52 oz.
Discussion New Electrifly Rifle - All Composite "Sport Pylon" racer/mini hotliner? BTerry High Performance 4994 Sep 17, 2014 04:45 AM
Discussion My new EDF Sport Jet Soulcry RW-Jets Electric Ducted Fan Jet Talk 29 Oct 16, 2010 12:48 PM
New Product Matrix 90mm sport jet Maiden Getmore Rc Electric Ducted Fan Jet Talk 80 Aug 01, 2010 08:51 AM
Found Fiberglass Sport Jet toxic-trip Aircraft - Electric - Jets (FS/W) 7 Feb 26, 2010 07:25 AM
Discussion X-models xray sport hotliner details needed. stevext Electric Sailplanes 0 Oct 12, 2009 04:05 PM
