Old Sep 28, 2012, 01:05 PM
United States, MI, South Lyon
Joined Feb 2005
Help!
Tetsing of various planforms
drive320 is offline Find More Posts by drive320
Old Sep 28, 2012, 01:35 PM
Cromer,Norfolk, UK
Joined Nov 2006
If you keep the wing area/section/speed the same, the lift force, if I understand it correctly, will not change. The planform will change the pattern of lift distribution (as well as mass distribution) which will have an impact on handling etc, but lift force is a function of lifting area, lift coefficient, and airspeed, rather than planform. I think! I may be incorrect.
MCarlton is offline Find More Posts by MCarlton
Old Sep 28, 2012, 11:18 PM
Joined Feb 2005
Old Sep 29, 2012, 06:50 AM
richard hanson's Avatar
United States, UT, Salt Lake City
Joined Oct 2007
Maybe, maybe not
the slower and smaller the subject becomes , the more a low aspect ratio is favored.
You will love this part
The air always takes the path of least resistance and the only way you can get any pressure difference (lift) is to have enough surface ,arranged such that the lifting surface can develop higher and lower pressures. A high aspect setup works - but only as speed increases.
It is obviously a bag of compromises where you have to pick and choose to get performance you are after.
richard hanson is online now Find More Posts by richard hanson
Old Sep 29, 2012, 09:12 AM
Grad student in aeronautics
United States, GA, Atlanta
Joined Oct 2010
Just as different planforms will have different span efficiency factors, they will also have different lift curve slopes ( dCL/dalpha). Aspect ratio will have the largest effect on this.
I'm still not sure exactly what you're testing. Are you testing their maximum lift ability?
DPATE is offline Find More Posts by DPATE
Old Sep 29, 2012, 10:46 AM
Joined Feb 2005
Old Sep 29, 2012, 01:21 PM
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
Can't quite visualize how you are doing it, but my first thought was basically the tow line glider hook location. I assume you would need something to mount the wings on, a 'fuselage' ?, possibly even with a rear stabilizer ?.
eflightray is offline Find More Posts by eflightray
Old Sep 29, 2012, 02:18 PM
Joined Feb 2005
Old Sep 29, 2012, 04:54 PM
Joined Oct 2010
I think I understand a little better. It sounds like you are calculating lift based off of the moment it applies about the pivot point, and you want to know how best to pick the moment arm, which will factor into the equation.
Ideally you would place the moment arm at the center of pressure, which is where lift and drag act. However, this location changes with angle of attack.
Question Correct Use of Planform Correction Factors? Yak 52 Modeling Science 22 Jan 28, 2014 11:04 AM
Discussion wing planform, can't decide! MCarlton Slope 7 Aug 21, 2012 07:19 AM
Wanted Wanted- Cuppaccino or other ship similar Wing Planform kewhite Aircraft - Sailplanes (FS/W) 6 Jun 16, 2012 03:30 PM
Discussion Looking for thread or exp about wing planform kewhite Multi Task F3X 1 Apr 04, 2012 05:09 PM
