Old Feb 15, 2012, 07:21 PM
Half way there
bill clark's Avatar
USA, FL, Ocoee
Joined Sep 2008
ESC,caps,switches, and the Spark
I am trying to determine which is the best route here on my new plane. 8s, CC ICE 100 w/cap packs and an external arming switch (handling the full current load) for safety and because my canopy is screwed on. I dont want one of those gaudy power poles sticking out the side so I have some ideas for a clean, fabricated switch but my questions are. will the additional caps make the spark more intense and what components (resistor?) do I need to arrest the spark. also how is this arrestor wired in and does it need to be connected/disconected each time the battery is? I know there is lots of topics on the spark arrestors but felt this is the best place to get specific info with my components. thanks
bill clark is offline Find More Posts by bill clark
Latest blog entry: 3D printing small parts
Old Feb 16, 2012, 04:37 AM
A man with too many toys
United States
Joined Feb 2001
An ICE 100 with the extra Cap Pack is going to destroy about any switch fairly quickly. For a spark suppressor use a 1-ohm resistor. You need to first switch the resistor into the circuit. After about a second it will be save to engage the main arming switch.
RC Man is offline Find More Posts by RC Man
Old Feb 16, 2012, 06:57 AM
Half way there
bill clark's Avatar
USA, FL, Ocoee
Joined Sep 2008
thanks RC. So continuing along the thinking of the external arming. could the suppressor be switched in with a small toggle switch or a slider (like the one for turning on the rx) and is the resistor before or after the switch? You mentioned 1 sec before switching on the main. is there a maximum?
Old Feb 16, 2012, 07:24 AM
United States
Joined Feb 2001
Itís best to close the main power switch as soon as possible. If you mode servos or turn on motor before closing the main switch you could blow the resistor. Maybe a 3-yaw switch would work (down-off, center-resistor, up-power).
The reason that switches are not very popular is that it takes a large switch to handle 150 amps at DC voltage. I would recommend a switch thatís 150% larger than any peaks you see on the data log. That would be very bad if that switch failed in-flight.
Iím sure you will get other opinions and someone else might have a more elegant solution. Have you looked at this http://www.sharprc.com/
Old Feb 16, 2012, 11:53 AM
Half way there
bill clark's Avatar
USA, FL, Ocoee
Joined Sep 2008
I plan to take one of the big CC bullets, make a few parts on the lathe and make the switch from that. actually I guess it will be more of a plug than a switch and connect/disconnect one lead from outside the plane. do you think it matters which lead and should that lead have the suppressor on it? and should it be between the plug and the batt or the plug and the esc?
Old Feb 21, 2012, 11:48 PM
firehawkzach's Avatar
United States, TX, Fort Worth
Joined Jan 2011
Pictures of this please
firehawkzach is offline Find More Posts by firehawkzach
Idea Another good choice of 160amp esc for my Spark? neversommer Electric Ducted Fan Jet Talk 22 Nov 24, 2011 02:18 AM
Sold mtrs,esc,couplers,mtr mounts,ant tubes,caps and diodes $25 shipped kartooo Boats (FS/W) 2 Nov 01, 2011 10:06 AM
Question Caps and anti spark lightningmcnul Electric Ducted Fan Jet Talk 29 Sep 03, 2011 04:31 AM
Discussion caps on esc.. sebbe Power Systems 5 Jul 19, 2011 06:53 AM
Discussion MX12 3pos. switches instead of regular 2pos. switches ??? vlatko Radios 0 Mar 16, 2011 07:10 AM
