May 08, 2013, 05:04 PM
Junction City, KS
Joined Sep 2004
Originally Posted by shadowolf2
battery seems ok when I turn it on the servos do give a little movement but only when I power it up then its all dead
I need you to make sure that the battery is fully charged. Use a voltmeter to read the charge of the battery. the fact that the servos move, indicate that the servos may be working. I F the battery is charged, and the servos work, then the problem is between the radio and the receiver. You already confirmed that they have the same number on the crystal. So the problem may be internal.
1. Find somebody that will loan you a spare receiver, swap out the crystal and try again.
2. Send the whole thing to be looked at by the manufacturer.
May not be what you are looking for, but unless you have knowledge about electronics, this is as far as I can take you. Hell I don't know how these things work inside, so without being there, this is as far as I can take you. Sorry
Rafael
