Espritmodel.com Heli Air
Old Jan 25, 2003, 07:59 PM
Joined Nov 2001
Endoplasma wire gauge?
Does anyone know the gauge of the wire used in the Endoplasma? I know it has 16 turns and is double wound but am unsure of the gauge of wire used.
Adam
Foxy is offline Find More Posts by Foxy
Old Jan 26, 2003, 10:38 PM
now that's a wattmeter...
simingx's Avatar
Singapore
Joined May 2002
Why would you need that info? If you're connecting the motor to the ESC, 14 gauge (good for 32A) would be more than enough.
simingx is offline Find More Posts by simingx
Old Jan 27, 2003, 07:28 AM
GWRIGHT's Avatar
United States
Joined May 2000
since I normally run the endo's at 40 amps (or a touch higher) peak current, I don't use 14 guage wire. 13G is a bit difficult to find and 12 guage is avalable at the local hobby shop (Deans "wet noodle" variety), so I use the 12 guage. I've use 14 guage before, but both wire and connectors get hot, and the 12 guage doesn't.
GWRIGHT is offline Find More Posts by GWRIGHT
Old Jan 27, 2003, 06:51 PM
Joined Nov 2001
Im rewinding an old Kyosho lemans480 motor for gearbox use. Ill go with two winds of .63mm and see how that goes.
Adam
Old Jan 28, 2003, 03:23 AM
PDK
PDK's Avatar
Gladstone, Queensland, Australia
Joined Nov 2002
Hi Foxy, Motocalc has a motor designer section. If you know the original diameter and turns of the Lemans480 you can trial different turns and diameters to suit your batteries, gearbox etc. Makes it easier!! You can download a trial version from http://www.capable.on.ca/escbec.htm
Regards Phil
PDK is offline Find More Posts by PDK
Old Jan 28, 2003, 06:07 PM
Joined Nov 2001
good idea, thanks for that.
Adam
Wire Gauge in Brushless motor windings? Jim McPherson Power Systems 3 Apr 29, 2002 12:07 PM
Music wire gauge conversion lumins Power Systems 3 Jan 13, 2002 04:14 PM
35-ish Amp System - Sermos OK? What Wire Gauge? Mitch G Power Systems 3 Jul 19, 2001 09:07 AM
Wire gauge??? planecrash Electric Plane Talk 3 May 09, 2001 04:35 PM
Battery Pack Wire Gauge? LJH Power Systems 8 Apr 23, 2001 12:55 AM
