Old Aug 08, 2012, 11:50 PM
Australia, QLD, Brisbane
Joined Nov 2011
Originally Posted by Rotorhead0207 View Post
www.skookumrobotics.com/ not brain dead by a long shot. I run a SK720 on a 450 rex and a 500 rex and every thing that you could want to adjust you can. Update the firmware just like a kk board. And a really good solid selflevel. Haven't run a SK540 on a quad and don't intend to because of cost.
At $249.95 to $399.95 I can see why there would d be interest in using the KK2 at one tenth of the price!
Erknie is offline Find More Posts by Erknie
Old Aug 08, 2012, 11:53 PM
United States, CA, Santa Monica
Joined Jul 2011
Anyone flight tested this with the new firmware yet? How is it compared to the old firmware?
Lpbug is offline Find More Posts by Lpbug
Old Aug 09, 2012, 12:00 AM
Custom quad builder
tech69x's Avatar
United States, TX, Spring
Joined Apr 2012
What I noticed is better stick response in auto level mode
tech69x is offline Find More Posts by tech69x
Latest blog entry: Win a frame
Old Aug 09, 2012, 12:17 AM
United States, TX, Richmond
Joined Aug 2010
All I can say is night and day! Just finished flashing the board on my small quad and the response is really smooth with the default PI settings. I am using turnigy 30A esc and I will have to lower the I gain just a tad as I see some slow wobbling.
Self level is much better, just started to pitch foiward a bit but brought it back and it stayed there with very slight drifting.
rcjose is offline Find More Posts by rcjose
Old Aug 09, 2012, 12:18 AM
Joined Aug 2010
How to Flash video
I finished the how to flash video and am uploading it now to my youtube channel. Will post the link when done!
Old Aug 09, 2012, 12:44 AM
rustymit's Avatar
Saudi Arabia, Tabuk Province, Tabuk
Joined Nov 2005
Thank you for this, I look forward to watching it.
rustymit is offline Find More Posts by rustymit
Old Aug 09, 2012, 01:39 AM
Joined Aug 2010
Video on how to flash the KK2 board
Here it is. Enjoy and happy flashing!
Flashing The KK2 Board Using The LazyZero FlashTool (15 min 51 sec)
Old Aug 09, 2012, 01:56 AM
quad pilot
LazyZero's Avatar
Alsdorf/Eifel, Germany
Joined Jun 2005
Very good work, I will add the video to the tutorial section of the flashtool.
Thanks Christian
LazyZero is offline Find More Posts by LazyZero
Old Aug 09, 2012, 02:11 AM
Austria
Joined Jan 2004
Originally Posted by Erknie View Post
Because batteries don't have a standard or spare pin connector which could possible fit the board, in fact battery connectors vary so much they are a problem in their own right.
You have to solder ESCs and they don't void warranty.
There is a plug for the buzzer ...
All what it was needed, it was to have a single plug (male, like the servo plug, but instead of 3 pins, just 1 pin), with eventually a cable with the female single pin plug with a wire already connected ... then everybody could easily and without any risk make a connector.
The cost of it ... only additional few cents in the production.
Tchuss
e_lm_70
e_lm_70 is offline Find More Posts by e_lm_70
Old Aug 09, 2012, 02:29 AM
Austria
Joined Jan 2004
Originally Posted by evildean View Post
Has anyone noticed the esc configuration option is missing in the new firmware?
Originally Posted by HappySundays View Post
And for good reason. Well-intentioned, I'm sure, but not the safest way to calibrate ESCs.
Best to do it manually
I see that HappySunday still did not check the source code of the Kapitain
The calibration ESC, (that in my opinion, it is needed), it is still there ... just you don't see it anymore in the setting menu, nor the text for the ESC calibration procedure is stored in the limited memory of the KK2.0
But if you press the two buttons at start up, you will get the ESC calibration again ... same as previous version
Tchuss
e_lm_70
ps: I was looking for my error with saturated stuff .. that did crash my quad time ago ... and ... this does not exist anymore in the new firmware ... ... maybe it was a wrong idea in first place to reset the KK2.0 board in case of value outside the expected range ...
Old Aug 09, 2012, 03:15 AM
FLY IY, BREAK IT, FIX IT,
Hampshire, United Kingdom
Joined Jun 2005
http://www.youtube.com/watch?v=EEErn...ature=youtu.be
Good work RCJOSE, thank you - and Lazy Zero.
Is is absolutely necessary to disconnect the ESC's and RX inputs before flashing?
Impailer is offline Find More Posts by Impailer
Old Aug 09, 2012, 03:21 AM
Joined Aug 2011
I didn't disconnect them and the upgrade worked flawlessly.
I did remove my props however as the upgrade resets the controller to factory defaults.
jim350 is offline Find More Posts by jim350
Old Aug 09, 2012, 03:24 AM
Enjoying the sunshine
HappySundays's Avatar
Australia, NSW, Sydney
Joined Feb 2011
I have the original V1.0 source, but apart from the LCD initialisation values there is none of his code in OpenAero2
By the way, the text "Saturated", "Saturate" or even "Satur" does not appear anywhere in the old V1.0 source code either...
HappySundays is offline Find More Posts by HappySundays
Old Aug 09, 2012, 03:26 AM
Austria
Joined Jan 2004
Don't be Lazy
Unplug all ... and use the limited USB power for Flash the KK2.0 ... once connected, you power with 5V from USB the full Quad, via the KK2.0 board ... so ... I guess you don't want to overload you little 500mA from your USB port ...
Tchuss
e_lm_70
Old Aug 09, 2012, 03:30 AM
quad pilot
LazyZero's Avatar
Joined Jun 2005
I didn't unplug anything, too lazy. The 5v from the usb is only put to M1 and the receiver, so no problem at all. M2-M8 are an own circuit.
Christian
