Old Nov 04, 2012, 11:08 AM
Denmark, Capital Region of Denmark, Frederiksberg
Joined Dec 2009
Glow conversion
Hi guys,
What do you think about this model with a modified firewall and a Saito 30FA 5CCM four stroke, I do not plan to fly 3D just for cruising around, do touch and gos and basic loops and rolls.
Is it too big or??
http://www.hobbyking.com/hobbyking/s...arehouse_.html
UB
ubihof is offline Find More Posts by ubihof
Old Nov 04, 2012, 12:36 PM
team sleprock
whiskykid's Avatar
United States, WA, Port Angeles
Joined Dec 2009
that plane would be more suited to a 46 2 stroke!
need ta look for someting between 1000 and 1100
whiskykid is offline Find More Posts by whiskykid
Latest blog entry: heli's
Old Nov 04, 2012, 02:35 PM
Joined Dec 2009
Ok thank you.. :-)
Old Nov 04, 2012, 10:41 PM
team sleprock
whiskykid's Avatar
Joined Dec 2009
this would be a easy conversion
Old Nov 05, 2012, 05:49 AM
Joined Dec 2009
Hi Whiskykid,
I have looked at that one too, but I already have a larger Decathlon with a OS 70fs, I was looking for something low wing sporty kind of plane, for the little Saito.
Thanks anyway
Old Nov 05, 2012, 07:37 AM
Fueled by Arabica Beans
ChillPhatCat's Avatar
United States, NY, Syracuse
Joined Oct 2008
It might fly it as a sport flyer if it really does come out to 1200g, but I think it will be at LEAST a pound over that. I'd say it's a coin flip whether it would have satisfactory flight performance on that airframe. Most of the hobbyking electric offerings are too delicate for a nitro engine. I can't really see any sport planes that they sell that would be a good fit other than that Decathalon. But, if there's a 1000mm plane that you like, you can always double up the firewall and add some wood to the weakest points, particularly in the wing saddle area.
If you can keep the plane down to about 3.5 lbs (1588g) then you should get decent performance with that .30.
ChillPhatCat is online now Find More Posts by ChillPhatCat
Old Nov 06, 2012, 04:11 PM
Joined Dec 2009
Thanks for the advice guys, I ended up buying this one http://www.rcmodelcentre.co.uk/Black...rod_22788.html I could not resist visiting my local plane pusher today, looks like a robust build with plenty of room in the cowling for a cylinder horizontal mount. Can not wait to modify that firewall, bolt the Saito in it and get it to the flying field.
Happy landings
Ulrich
Old Nov 07, 2012, 07:21 AM
Joined Oct 2008
Looks like a solid plane. Good luck on the conversion!
Old Nov 10, 2012, 10:17 AM
team sleprock
whiskykid's Avatar
Joined Dec 2009
post up your firewall mods for future refrence!
Old Nov 11, 2012, 10:52 AM
I'm a pilot... 100 yrs to late
Thermalin's Avatar
USA, FL, Palm Harbor
Joined Jan 2005
Your original selection would shake apart after a couple flights.. cracked joints, etc... 2 or 4 stroke.
On any electric you'll need to beef up the entire area or it will just twist off or smash when you apply the starter.
You'll need to figure out what to do about balancing after your done as it will be quite nose heavy now.
Thermalin is offline Find More Posts by Thermalin
Old Nov 12, 2012, 12:19 AM
team sleprock
whiskykid's Avatar
Joined Dec 2009
all I did was shorten the firewall and make a new one, then boxed in the motor exstension with some 1/64th lite ply to keep fuel out from inside airframe!
she's no 3d beast but a great sport flyer, the airframe I been looking for, for this lil engine, for over 20 yrs!
P.s. that lil EDGE should be a blast!
Sold Glow Plugs, Glow Plugs, Glow Plugs !!! shooboy Aircraft - Fuel - Engines and Accessories (FS/W) 6 Sep 07, 2012 06:31 PM
Discussion Conver a balsa stick 40 plus FireChief4302 Glow to Electric Conversions 6 Aug 25, 2012 01:41 AM
Discussion Convered Dynamax Fan CoolerByTheLake Electric Ducted Fan Jet Talk 0 May 28, 2012 07:49 PM
Sold Cox Tailwind 40 convered to EP with Floats $400 LPU be69ar Aircraft - Electric - Airplanes (FS/W) 0 May 04, 2012 11:01 AM
Convering for beginners khaoz Beginner Training Area (Aircraft-Electric) 8 Oct 03, 2005 04:25 PM
