Old Oct 01, 2012, 01:49 PM
I want to go flying!
BE77 Pilot's Avatar
Joined May 2010
Turnigy Aerodrive SK3 - 5065-275kv Mtr Queston
Any one have experience with this motor? Why is it so long? It has the numbers I am looking for but why are the dementions so strange. I thought at first it might have a gear drive up front.
http://www.hobbyking.com/hobbyking/s...ner_Motor.html
Specs.
Turns: 8T
Voltage: 6~10S Lipoly
RPM/V: 275kv
Internal resistance: 0.017 Ohm
Max Loading: 65A
Max Power: 2050W
Shaft Dia: 6.0mm
Bolt holes: 25mm
Bolt thread: M4
Weight: 531g
Motor Plug: 4.0mm Bullet Connector
BE77 Pilot is offline Find More Posts by BE77 Pilot
Old Oct 02, 2012, 08:53 PM
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
I trust that it is exceptionally well trued and balanced, and has superior bearings.. otherwise it will have issues with that long moment arm from prop to mount (especially if you use the radial adapter). Fixing it behind a firewall with a collet adapter on the exposed shaft would allow for better balance... but even so I'd be wary of it.
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old Oct 03, 2012, 06:11 AM
BE77 Pilot's Avatar
Joined May 2010
That is a good point Dr. Kiwi. I need to mount in from of the firewall so maybe that isn't the best choice.
Old Oct 03, 2012, 07:53 AM
Jack
USA, ME, Ellsworth
Joined May 2008
Is that motor made with two stators joined back to back or in line on a common shaft? Or is is just one extra long stator? It is a little hard to figure out the details there.
The dimensions show the can as 49mm O.D. x 58mm long, that is a little out of the ordinary for sure.
That motor cries out to be taken apart...
Jack
jackerbes is offline Find More Posts by jackerbes
Old Oct 07, 2012, 10:28 AM
MagnusEl's Avatar
Sweden, Gävleborg County
Joined Jan 2004
I think this one have a big bearing in the back of the can.
MagnusEl is offline Find More Posts by MagnusEl
Sold turnigy aerodrive sk3 5055-280kv mbsilvia Aircraft - Electric - Power Systems (FS/W) 1 Sep 23, 2012 10:56 AM
Question Turnigy Aerodrive SK3 - 2122-1800kv ESC Chairplane Power Systems 2 Apr 08, 2012 08:30 AM
Discussion Reccomendation for Turnigy Aerodrive SK3 – 2822-1090kv alternative? Whitworth Multirotor Talk 8 Mar 31, 2012 07:06 PM
Question Turnigy Aerodrive SK3 28xx hardware dimensions Physics_Dude Power Systems 5 Mar 17, 2012 09:33 AM
Discussion Turnigy Aerodrive SK3 - 6374-192kv makser Power Systems 1 Jan 12, 2012 05:29 AM
