Old Yesterday, 03:24 PM
Canada, ON, Ottawa
Joined Jun 2009
I need a good old protractor.
Wasp09 is offline Find More Posts by Wasp09
Old Yesterday, 07:03 PM
Joined Oct 2010
Originally Posted by eggma View Post
yeah... and I find the servo overthrow correction will be helpful to Master Cp and other big helis as well.
Also I just didn't know my heli's potential was limited by improper set-up until I've seen his videos.. I always thought it was the motor / battery.
ummmm, I would say that his collective management is quite good though. If you are a newer flier you will be hard pressed to perform some of the stunts he does on 1s.
pmerritt is offline Find More Posts by pmerritt
Old Yesterday, 08:11 PM
IHW Heli Division
IntegrityHndywrk's Avatar
United States, FL, Palm Coast
Joined Mar 2012
+1 and I would add that even if your an experienced 3D pilot on a 550 class or something. Trying to perform 3D moves that you do every day with your 550 on a V120D02S using 1S lipos and the stock gyro will be a MAJOR challenge. Like pmerritt implied. If you over throw your collective you kill your performance. When your used to something like a 550. Over throwing your collective isn't a problem and it might even be a little fun. So when you get to flying a V120 in 3D and your used to being able to flick the sticks around like nothing. Well, there might some issues on the 1S V120 with bogging, tail kicking, and crashing
IntegrityHndywrk is offline Find More Posts by IntegrityHndywrk
Old Today, 01:16 AM
jamichx's Avatar
United Kingdom
Joined Sep 2013
Can we get back to my original question on page 940 ?
jamichx is offline Find More Posts by jamichx
Old Today, 01:32 AM
IHW Heli Division
Joined Mar 2012
Originally Posted by jamichx View Post
How do you guys straighten up tail shaft ?
I did mine but still needs work and don't have any good tool for that. The tail is still not ok and wobbles a little bit.
Lets hear how you do it ...
This question?
To straighten a shaft i usually drill a few holes in a block of wood just a bit smaller than the shaft. Than i run the shaft through to heat it and straighten it. But you can't really do that with the V120 original shaft because the hub doesn't come off. But thinking back i don't think i ever bent a tail shaft that i can remember.
Old Today, 02:05 AM
soonglim's Avatar
Joined Sep 2012
I don't recall I've had a bent v120 stock tail shaft either - but have several times had them snap in half.
You can tap out the tiny pin securing it to the hub to remove the shaft. I've occassion replaced it with the 130x tail shaft, reusing the V120 tail hub - perfect for the slipper clutch. Just remember to use loctite when inserting the shaft into the hub .
soonglim is online now Find More Posts by soonglim
Latest blog entry: V120D02S with 130X Main Gear
Old Today, 03:49 AM
jamichx's Avatar
United Kingdom
Joined Sep 2013
Originally Posted by IntegrityHndywrk View Post
This question?
I am using bob's clutch not original shaft ? But I like your idea.
Old Today, 07:54 AM
Heli Crash Survivor
Crash Survivor's Avatar
United States, AR, North Little Rock
Joined Feb 2011
2 weeks ago my son requested me to repair his V120. His Bob's tail shaft was bent right at were the notch is at for the locking collar. I just eye ball it & held with a pair of needle nose pliers at the edge of the notch & with thumb pressed other end of shaft. My intent if that didn't work was to put his stock shaft back on, but to my surprise it bent back pretty easy & didn't break.
Crash Survivor is online now Find More Posts by Crash Survivor
Discussion new heli from walkera HIKO400? xyzy2 Micro Helis 15 Jan 12, 2012 11:16 AM
Sold Align 70A ESC W/BEC from 500/550 class Heli NEW! HD Hucker Aircraft - Electric - Helis (FS/W) 3 Oct 13, 2011 12:37 PM
Discussion Ultra Durable Diamond Mini Gyro 3 Channel Indoor Ready to Fly RC Remote Control Heli LittleG Coaxial Helicopters 32 Jan 14, 2011 12:55 PM
Discussion Walker 4#3 throttle problem Ė new heli Ronon Micro Helis 2 Jan 24, 2009 04:22 PM
