Old Sep 01, 2003, 02:53 AM
MINE!
Mick Molloy's Avatar
Australia, VIC, Point Cook
Joined Jul 2003
Tiny with a CD rom Brushless ??
I am thinking of building a Tiny and putting a Home made cdrom brushless on it.
The other gear will be
Jeti 5ch reciever
9g servos
Jeti 8 3p ESC
and maybe Lithium Ions or poly cells
I want to build V tail but with no rudder to save weight and i want to fly indoor with it not outdoor.
Any help or suggestions would be good.
Mick Molloy is offline Find More Posts by Mick Molloy
Old Sep 01, 2003, 10:04 AM
poobs's Avatar
oakdale, ny, usa
Joined Aug 2000
Well...If the CD rom motor ends up lighter and more powerfull than than an IPS it should be a hoot to fly.
My Tiny was built from free downlaod plans. I flew first with a regular stock IPS ( from a Lite Stick) drive and 8 300MA cell.
The real fun began when I switched to a C gear ratio and 3 series E-tec batteries.
Vertical and prop hanging are no problems with the above. It still slows down so I can walk next to it.
I have seen videos of Tiny's with Astro motors and can only imagine how much fun they are.
Keep us posted & good luck
poobs is offline Find More Posts by poobs
Old Sep 01, 2003, 03:37 PM
MINE!
Joined Jul 2003
Whats an IPS weigh with out the prop the cdrom i have built weighs 18grams with no prop.
I am waiting for the ESC (Jeti JES 8 3p) which will be heavier than the small 2 amp ones used for the IPS.
Old Sep 01, 2003, 04:25 PM
Pro Bro #495
fwilly's Avatar
Farmington NM
Joined Apr 2002
the ips weights about 28grams or 30 with wires, nuts and washers.
fwilly is offline Find More Posts by fwilly
Old Sep 04, 2003, 12:45 AM
MINE!
Joined Jul 2003
I am looking at making the wing out of cnc cut foam and the V tail out of coro
Does anybody know what aerofoil section the tiny uses?
What does a built up and covered wing on its own weigh???
Old Sep 04, 2003, 09:04 AM
Pro Bro #495
fwilly's Avatar
Farmington NM
Joined Apr 2002
you can download the tiny plans free from http://www.rcmicroflight.com/dec99/tiny01.asp
they should have the airfoil in them
Old Sep 04, 2003, 05:39 PM
MINE!
Joined Jul 2003
I have the plans thanks for that. I was after the aerofoil number beacause the CNC foam cutting software has 1000,s of aerofoils already stored in it and you just and the size and chord % and "bing" you have a foam wing.
I belive i can export it from cad across to a dat file, but i was just seeing if there was an easier way.
Old Sep 05, 2003, 08:03 AM
Lapsed Non Modeller
Andycart's Avatar
West Yorkshire, UK
Joined Sep 2002
I built a 'beefed' up Tiny (didn't cut away the insides of the ribs and riblets and covered with Profilm) and it flies fantastic on a PJS 3D 300. The PJS is about the same as a good CDROM motor so you should be fine. It's one of my favourite hacks. I built the 'T' tail version and coupled rudder to aileron. I am seriously thinking of adding a servo and having seperate rudder. The AUW of my Tiny less battery (I use 8 350mAH nicad 2/3 A cells) is around 5.5 oz.
Regards
Andy
Andycart is offline Find More Posts by Andycart
Old Sep 07, 2003, 09:07 PM
Striving to Rip the Bring
raptor22's Avatar
San Diego, socal, USA, North America, Earth, Solar System, the Orion arm, Milky way, Universe
Joined Apr 2003
the cdrom is about as powerful as the gtws sp300 size; w/ 1/3 the size and weight (assuming that it is 45 speed or better).
--Alex
raptor22 is offline Find More Posts by raptor22
292 Gram (10.34 oz) GWS Me109 with CD-ROM Brushless Motor kensp GWS (Grand Wing Servo) 83 Apr 18, 2006 08:11 PM
Fantastic Models Mig 15 with CD-Rom Brushless Setup.. Tram Aircraft - Electric - Airplanes (FS/W) 2 Jul 22, 2004 01:52 PM
gear question with cd-rom brushless i-fly Micro Helis 14 Dec 11, 2003 06:27 AM
CD-Rom brushless - good winding pictures Graham Stabler Scratchbuilt Indoor and Micro Models 3 Jun 18, 2002 02:52 PM
CD Rom brushless, is this what the fuss is about? Looooeeee! Power Systems 1 May 05, 2002 03:44 PM
