Old Feb 15, 2009, 01:23 PM
Is getting old...
quadracer111's Avatar
Canada, Saskatchewan, Saskatoon
AVOID mcx ac fast charger!!!
I recently purchased http://cgi.ebay.com/Eflite-Blade-mCX...d=p4634.c0.m14
on ebay. After about 7 charges with it on 4 of my batteries, 2 70mah vapor batteries and 2 110mah blade mcx batteries it has wrecked all 4 batteries!
They will not charge in the stock AA charger and false peak in about 3 minuets. The flight time? 10 seconds the LVC kicks in! I have contacted the seller about this. It has wrecked $48 worth of my batteries! I am not pleased!
quadracer111 is offline Find More Posts by quadracer111
Old Feb 15, 2009, 02:25 PM
Joined Jun 2008
It says in the info it charges at nearly .3a.... you do know why it wrecked your batteries, right?
A 70mAh batter should be charged at .07a . That means your charging at arround 4C, asking for a lipo fire!
There is a guy on here that has made a charger and intends to sell them. It can charge from .02a to .4a in .02a increments and can charge 4 batteries at a time.
http://www.rcgroups.com/forums/showt...hlight=charger
Tripod333 is offline Find More Posts by Tripod333
Old Feb 15, 2009, 02:27 PM
Power Wheels Guru
UNGN's Avatar
Southlake, TX
You are charging the batteries at 3 to 4C, if not more, so yes, it should severely shorten their life.
UNGN is offline Find More Posts by UNGN
Old Feb 15, 2009, 02:38 PM
Pro Bro #495
fwilly's Avatar
Farmington NM
Joined Apr 2002
the stock charger charges at well over 1c as well.
fwilly is offline Find More Posts by fwilly
iPhly R/C with iPhone
iter's Avatar
Silicon Valley, Calif
Joined Jan 2005
The page you reference says, inter alia:
Q: What is the charge current?
A: It has not been measured with a voltmeter, but based on how long it takes to reach a full charge it is approx 250mA-300mA.
The author is careless either in his choice of equipment or choice of words. Neither instills confidence in his product.
Ari.
iter is offline Find More Posts by iter
Old Feb 15, 2009, 03:21 PM
RC pilot,AMA Member.
sonicjet's Avatar
Northeast PA
Joined Sep 2007
The e-flite charger is the same as the pz charger,fullriver batts can be charged at that voltage and current btw,better chemistry,should last 100 charges plus.
sonicjet is offline Find More Posts by sonicjet
Old Feb 15, 2009, 03:50 PM
Is getting old...
sonicjet please explain? So you can charge these batteries at .3a?
Old Feb 15, 2009, 03:55 PM
Is getting old...
I feel like such a dink!! The reason my vapor wasnt flying is because the pinion on the motor was loose and hardly spinning! My batteries are fine! This charger is good, it charges fast! And even if i get 50 charges out of the batteries im fine becauses there only $10
Old Feb 15, 2009, 04:13 PM
Playing with AutoCAD!
PiperCub49's Avatar
United States, ME
Joined Oct 2008
How long does it take to get a full charge?
PiperCub49 is offline Find More Posts by PiperCub49
Old Feb 15, 2009, 04:24 PM
Deletedfor proving Nauga wrong
Joined Mar 2005
The stock AA powered charger chages rather fast.. appx 20 min to charge from LVC of the mCX to full.
There is a post on here some where about opening the charger and tweaking a pot to reduce charge rate... You really want it to be 1 hr.
High rate charging and high rate discharging is very hard on LiPos.
found the thread
fhhuber506771 is offline Find More Posts by fhhuber506771
Old Feb 15, 2009, 05:09 PM
sonicjet's Avatar
Northeast PA
Joined Sep 2007
yes on reg. lipos,smaller ones take it better.
You can get about 100 flights out of an air hogs u build it,with a 130mah lipo charging at 3.5C
Old Feb 15, 2009, 06:02 PM
TheyreComingToTakeMeAway!
derk's Avatar
USA, ID, Coeur D'Alene
Joined Dec 2003
i have heard that the charge rate is directly linked to the C rating of the battery. i.e. for every 10C, you can charge 1C. so for a 30C constant discharge pack, you could charge it at 3C safely because the cell structure can take it.
as far as i know, all these small cells are 20C or less.
just my 2
derk is offline Find More Posts by derk
Old Feb 15, 2009, 07:45 PM
Beijing, China
Joined Nov 2006
It depends on the lipo.
Full River has a quick-charge series that will take a 10C charge rate. Their "Safe Toy" series, which is what goes in many RTF products, is rated 1-3 or 1-4C, depending on battery.
reylf_gnijieB is offline Find More Posts by reylf_gnijieB
Old Mar 03, 2009, 01:18 PM
Joined Jan 2009
REtract
Hey Quadracer111, why don't you delete this negative statement or have the sysop delete it?
Somebody may only read this far and only get the bad message.
These guys are friends of mine and don't really need the bad PR.
Chuck
helichuck is offline Find More Posts by helichuck
Old Mar 03, 2009, 01:35 PM
HyperFlight Support
Neil Stainton's Avatar
United Kingdom, England, Stratford-upon-Avon
Joined Feb 2001
Agreed. It is bad to leave a thread with unfounded accusations on file. Either clearly edit the first post to point out your mistake, or delete the thread.
Neil.
Neil Stainton is offline Find More Posts by Neil Stainton
For Sale F/S DuraTrax Piranha CX10 AC/DC Fast Charger biffybiff Cars - Trucks and Parts (FS/W) 0 Feb 12, 2009 05:02 PM
Rant AC Powered Charger for MCX helichuck Batteries and Chargers 6 Jan 22, 2009 07:16 AM
Fast Charger for RAYOVAC 9 volt Nimh Batteries? Jamie- Power Systems 2 Jul 25, 2001 11:00 AM
Best AC/DC Charger for NiCad & NiMh? CheeseWing Electric Plane Talk 1 Jul 21, 2001 08:30 AM
Best AC/DC Charger for NiCad & NiMh? CheeseWing Electric Plane Talk 6 Jul 21, 2001 07:45 AM
