Old Oct 20, 2014, 06:55 PM
United States, VA, Fairfax
Joined Jul 2014
Banana Plug and Wire size?
Hello All:
I'm a newbie, so please bear with me.
I recently just bought a ICharger 4010 duo. The duo comes with a 10 gauge charging wire with EC5 connector on one end and bare lead on the other end, so I want to solder a pair of banana plug to it.
I also bought a 1500w /24V Dell server power supply (2 in series) and it uses a 12 gauge wire with banana plug on both end to make them in a series. It comes with an extra pair of banana plug.
My problem is, it seems like the banana plug for the 12 gauge is a bit smaller for the 10 gauge wire?
Is there a different size banana plug for the 10 gauge wire?
Sorry, I'm really new at this, any advice is greatly appreciate it.
lmxu is offline Find More Posts by lmxu
Old Oct 21, 2014, 05:03 AM
New Zealand, Canterbury, Rolleston
Joined Oct 2011
A banana plug is 4 mm. Anything else is not a "banana plug". Similarly shaped pins and sockets come in a range of sizes - 1 mm, 2 mm, 3.5 mm, 4.5 mm & 5 mm.
XT60 connectors use 3.5 mm pins and sockets. EC5 has 5 mm pins and sockets, XT90 4.5 mm pins and sockets.
You talk about plugs, where are the sockets that they plug into?
The gauges of wire mentioned could be used with 3.5 mm or 4 mm connectors.
Mac50L is offline Find More Posts by Mac50L
Old Oct 21, 2014, 12:57 PM
Joined Jul 2014
Thanks Mac.
The banana plugs that I want to solder on, will plug into the power supply which looks like the first picture below. The wire that connects the two power supplies in the picture is 12 gauge.
The charging cable looks like the one in the second picture with EC5 on one end (EC5 connects to my ICharger), so I want to solder a pair of banana plug on the bare end to plug put into the power supply.
Old Oct 21, 2014, 03:35 PM
Joined Oct 2011
Providing those are 4 mm sockets on the power supply there should be no problem soldering on 2 banana plugs to the wire in the second picture. You could check the inside diameter of the sockets, using calipers/vernier gauge on the power supply just to be sure. Even a metric ruler should be good enough to check. There's a Radioshack in Lincoln that should stock banana plugs
Latest blog entry: Motor cover and mount retention
Old Oct 21, 2014, 05:01 PM
Joined Jul 2014
Thanks Mac. Just checked and it is 4mm.
I just tried to solder the 4mm banana plug to the 10 gauge wire, a bit difficult, it barely fit, but I managed to get it in.
Thanks a lot for your help!!
Old Oct 22, 2014, 01:36 PM
United States, WA, Woodinville
Joined May 2014
In a pinch you can trim off a few strands and stuff only what will fit into the connector. I don't really like doing that but it doesn't really hurt anything as long as you do it neatly.
James_S is online now Find More Posts by James_S
Discussion Looking for a fanless Power Supply with female Banana Plugs Papa Echo Batteries and Chargers 2 Oct 14, 2014 08:43 AM
Discussion 4mm Banana plugs for 26Amp power supply dk31 Batteries and Chargers 8 Oct 05, 2014 12:24 PM
Discussion Banana plug size DirtyDeeds Batteries and Chargers 11 Apr 25, 2014 05:37 PM
Question Banana Plug / Wire Connections Thermalin Fuel Plane Talk 6 Jan 17, 2007 09:46 PM
Rant tp 1010c size banana plugs? BrainDrain_dx Batteries and Chargers 4 Oct 03, 2006 03:47 PM
