Old Feb 09, 2014, 08:33 PM
Joined Feb 2014
Load share pin for parallel wiring info on this supply would be too cool...if I cant find it I will just experiment..there are only 4 pins left after resistor or jumper is placed so it cant be too hard to find..lol
jerseyboy is offline Find More Posts by jerseyboy
Old Feb 09, 2014, 10:24 PM
United States, MI, Dearborn Heights
Joined Dec 2009
Try searching....then asking if nothing is found in this thread. Be sure to identify the PS you have, as this thread covers many:
http://www.rcgroups.com/forums/showthread.php?t=1005309
RaySuave is offline Find More Posts by RaySuave
Old Feb 11, 2014, 08:43 AM
United States, OH, Columbus
Joined Sep 2012
Just a heads up. Still using this psu with a simple jumper rather than resistor without any issues. I use it for both my rc charging and my 3d printer.
hcker2000 is offline Find More Posts by hcker2000
Old Feb 19, 2014, 05:44 PM
nom
nom's Avatar
United States, ID, Boise
Joined Mar 2011
Hey Sky Captain, care to share that diagram?
nom is online now Find More Posts by nom
Old Feb 19, 2014, 09:11 PM
Flying is Freedom
Sky_Captain's Avatar
Annandale, VA
Joined Jul 2007
It's actually very simple. Just put a jumper from pin 4 (green) and 8 (red) to slow the fan down. For some reason my HP power supply had pins 6 and 9 soldered together.
I bought a jumper at my local Micro Center. That way they wouldn't be soldered together in case I made a mistake.
Sky_Captain is online now Find More Posts by Sky_Captain
Old Feb 20, 2014, 11:45 AM
Joined Sep 2010
CNC cut power supply rack containing four 12V 75A/100A DPS-1200FB server power supplies.
Slots in rack securely hold PSs while offering significant air circulation for cooling.
LizardMan is offline Find More Posts by LizardMan
Old Feb 21, 2014, 12:24 PM
Joined Sep 2012
Will they handle series chaining like that to get 48v at 100amp?
Old Feb 21, 2014, 05:19 PM
Joined Sep 2010
The real issue for many of us (in the USA), is AC mains power circuit limitations. Typical 120V circuits are rated for 15A, as are standard 120V outlets/plugs.
Using 220/240V AC mains power allows drawing enough current to provide full 2000W output from an iCharger 4010Duo. This charger draws 2200+W from these supplies at full charging capacity.
Full charge power for a 4010Duo at 48V input at about 50A. Half of the rated maximum output for these PSs running on 220/240V input power. I have little interest in attempting to drive these supplies to maximum rated output current.
I use a rack containing three PSs for a 1000W output iCharger 3010B. This model doesn't support 48V input.
Old Mar 23, 2014, 07:46 PM
Joined Sep 2010
Four slot power supply rack CNC design template available on-line at :
http://www.instructables.com/id/CNC-...or-RC-Charger/
This design secures four DPS-1200FB supplies with end mounted DC output binding posts in an easy to use configuration. Rack allows air circulation for cooling and easy temp probe access to each PS.
Old Jul 21, 2014, 01:01 PM
Joined Dec 2009
....eBay Links Updated In First Post
Old Jul 23, 2014, 01:18 PM
Joined Sep 2012
Mine is still running just fine with just the jumper and no resistor fyi.
Old Jul 25, 2014, 11:27 AM
Joined Nov 2012
Was anyone able to find the parallel load sharing pins on the DPS1200?
DemoMan2502 is offline Find More Posts by DemoMan2502
Old Sep 23, 2014, 05:49 PM
Joined Sep 2014
Ok so i have read through tons of pages about the dps-1200fb power supplies and saw lots of into about running them in series but no one replies to people asking about running them in parallel. No one says which pin is the load sharing pin and when the pins from however many psus are hooked up how do you link them together?? Pos to pos and neg to neg?? I only want to hook 2 up in parallel but i dont want to max out one psu while the second only has a couple hundred wats being used when i can split the usage over both evenly so if someone can post some info please do so cause im at a loss.
numnutz2005 is offline Find More Posts by numnutz2005
Old Sep 26, 2014, 05:20 PM
Joined Sep 2014
Ok since no one wants to share this info i decided to risk my psus to figure it out and it seems like i found it. I think its pin #34 and when connected the voltages match up and the load looks to be shared. I tried with both connected to a surge protector and that was connected to a meter on the wall which showed about 200w which is what i put on the psus and when i took one off the power strip and powered one on the meter read 200w about but when i hooked the other one up to the meter and also powered the second one on without it being on the meter the meter read 100w so the other half is on the second psu. Sounds about right to me and it looks like everything is good so far. I will try with a higher load soon and if ne thing goes wrong i will update this post but with the test load it seemed fine.
Question Is it ok to apply 12v to the outputs of a powered off 29A switching 12v power supply? punkindrublik Batteries and Chargers 13 Jul 09, 2013 10:26 PM
Question Is it ok to apply 12v the outputs of a powered off 29A switching 12v power supply? punkindrublik DIY Electronics 4 Jul 09, 2013 01:20 AM
For Sale 100a 12v Power Supply acetech09 Aircraft - Electric - Batteries & Chargers (FS/W) 0 May 24, 2013 08:51 PM
Discussion Chargery S1200 Power Supply - 24V - 1200W - 55A tritan Multirotor Talk 0 Mar 08, 2013 03:45 AM
Sold 12V IBM xseries Power Supply Delta DPS 1300BB tdab Aircraft - Electric - Batteries & Chargers (FS/W) 4 Dec 19, 2012 08:46 PM
