Old Jun 21, 2013, 05:36 PM
Why yes, I am an R/C addict!
flyrcehelis's Avatar
About 15 miles from Bristow, OK
Joined May 2009
Help!
Losi XXX-T differential problems
I have a Losi XXX-T I bought a couple years ago and I just now got around to building it. It worked for a while, but I had some problems with the way I had the motor mounted. So now i have fixed that, except now with it won't move, even with the motor and the gears all moving. However, if I lift it off the ground, the wheels spin like they're fine. Is this just a differential problem or is there something else causing it?
flyrcehelis is offline Find More Posts by flyrcehelis
Old Jun 21, 2013, 07:35 PM
Paul Onorato's Avatar
United States, CT, Brookfield
Joined Jun 2013
It sounds like the slipper clutch is too loose.
Paul Onorato is offline Find More Posts by Paul Onorato
Old Jun 22, 2013, 02:44 PM
Joined May 2009
So how would I fix that?
Old Jun 22, 2013, 02:59 PM
Did you check the FAQ already?
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
Tighten the appropriate screw or nut. The manual should have a section about adjusting the slipper clutch properly. If not, there are quite a few tutorials about other cars, which will generally apply to your car as well.
SoloProFan is online now Find More Posts by SoloProFan
Old Jun 23, 2013, 09:02 AM
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
It could be that the diff is too loose as well, it's a ball diff and needs some tension to function properly.
The way to test this is to hold one wheel and the spur gear solidly, then try to turn the other wheel. If it turns easily the diff is too loose.
wparsons is offline Find More Posts by wparsons
Sold Team Losi XXX-T (mf edition) rtheiss1 Cars - Trucks and Parts (FS/W) 3 Apr 28, 2013 11:46 AM
Sold <<<<<SOLD>>>>LOSI XXX-T Parts Lot nhaddock Cars - Trucks and Parts (FS/W) 0 Feb 24, 2013 03:37 PM
Sold LOSI XXX-T/NT Aluminum Parts nhaddock Cars - Trucks and Parts (FS/W) 0 Feb 24, 2013 01:12 PM
Discussion Losi xxx differential issue bigle Off-road Cars 4 Jun 24, 2011 02:26 PM
