Old Feb 16, 2013, 09:27 PM
United States, OH, Woodville
Joined Jan 2013
Gas delta wing?
I have been flying my little foam board delta wing with a small blue wonder motor. At the club i go to i recently seen a guy with a delta wing about the size of mine that was made of foam board and he had put a nitro engine on it. Well I have a shot at a .10 size nitro motor and want to try to put it on my delta wing some time. The reason i made this post is because i want to know if this is just a stupid idea or if it would work. Delta wings wing span is 22 inches and is 21 inches from front to back.
h710railfan is offline Find More Posts by h710railfan
Old Feb 18, 2013, 10:19 AM
United States, SD
Joined Aug 2010
Well glow fuel isn't good with foam, it will melt the airframe. If you could get an exhaust deflecter so no goo got on the foam, it would work.
Kyler1 is offline Find More Posts by Kyler1
Old Feb 18, 2013, 10:37 AM
Joined Jan 2013
Ah i see to much work for me to mess with right now then, ill stick to electric.
Old Feb 18, 2013, 08:06 PM
Yep I got another one.
mohillbilly's Avatar
Springfield, Mo.
Joined Jan 2005
If the foam is covered or painted it would be fine. I have several .40 or .60 planes with foam wings that are either covered with film or taped.
Mo.
mohillbilly is offline Find More Posts by mohillbilly
Old Feb 18, 2013, 08:10 PM
Joined Jan 2013
Ah so it could work then because i always tape mine for speed and some more strength. Thanks for the info
Wanted Delta Wing plane, e.g wild wing used or new littlephoenix Aircraft - Electric - Airplanes (FS/W) 4 Sep 24, 2014 08:30 PM
Article MicroDAN 2505-2900Kv Delta/Flying Wing Outrunner Motor Review DismayingObservation Power Systems 22 Apr 04, 2013 06:23 PM
Discussion Aerodynamics of flat plate delta wing kadil Modeling Science 1 Jan 15, 2013 08:44 AM
Discussion Flaps on Delta wing Teddy Ong Electric Plane Talk 2 Jan 05, 2013 08:49 AM
Discussion HK Flight Stabilizer V2 Delta wing 4touchdowns Flight Accessories 1 Jan 03, 2013 12:38 PM
