Old Jul 30, 2012, 03:28 PM
Slovenia
Joined Jun 2008
Build Log
Rads Quadcopter - my 1st ever quad
Hello everyone!
I would like to share with you my home made quadcopter build.
It will be my 1st quadcopter ever, so i decided to do a cheap version incase i crash it. The center plates are made of 3mm FR4 material
and arms are aluminium square tubes. Distance from motor to motor is 60cm.
The equipement is as follows:
Motor: http://www.hobbyking.com/hobbycity/s...dProduct=16229
ESC: http://www.hobbyking.com/hobbycity/s...idProduct=2164
Propellers:http://www.hobbyking.com/hobbycity/s...dProduct=10055
http://www.hobbyking.com/hobbycity/s...dProduct=17961
KK board: http://www.hobbyking.com/hobbycity/s...dProduct=24723
Battery will be 4s 4000mAh
The weight with the battery will be from 1400g to 1500g.
Here are some pictures (dont mind the cover on the second picture it will be dome shaped at the end):
Regards,
Paps1984 is offline Find More Posts by Paps1984
Old Jul 30, 2012, 03:32 PM
Ape-pilot Extraordinaire
TS00's Avatar
Canada, NB, Moncton
Joined Jun 2011
Nice, you can't beat a GRP + aluminium frame for rigidity and crash survivability.
TS00 is offline Find More Posts by TS00
Old Jul 30, 2012, 06:03 PM
Mortimer's Avatar
Joined Apr 2010
Nicely made.
3mm FR4 is very rigid and practically indestructible.
Mortimer is offline Find More Posts by Mortimer
Latest blog entry: 5V Power Supply
Old Jul 31, 2012, 02:49 AM
Slovenia
Joined Jun 2008
Thank you for the comments. Yep FR4 is really nice, maybe for the next time, i will go with 2mm or 1,5mm to save abit more weight. Job for today is to buy new shrink tube for ESCs since i had to solder longer wires to them on the motor side. And i have to solder wires on the power side together.
I might need to program the ESCs 1st though. How do you recommend i do that?
I have Turnigy programming card.
These two options are bothering me:
Timing mode: low / medium / high
Start mode: normal / soft / very soft
Since i bought these ESCs without checking if i can flash them 1st i hope it will work. I have seen some videos on youtube where people
fly with them, i have some hope. They have SiLab chip.
Old Jul 31, 2012, 03:46 AM
TS00's Avatar
Canada, NB, Moncton
Joined Jun 2011
Timing mode: medium. Start mode: normal. Don't forget to calibrate throttle ranges. If you can't flash them, they will still fly fine.
Old Jul 31, 2012, 04:52 AM
Slovenia
Joined Jun 2008
Do you know how to calibrate throttle range?
I guess this is the way:
1.)Connect the ESC to the throttle channel of the receiver. Have a motor connected to the ESC as the motor will provide beeps necessary to hear the calibration steps. DO NOT attach the propeller or anything else to the motor; simply have the motor connected to the ESC.
2.)Turn on the radio and put the throttle stick to maximum position.
3.)Now connect the ESC to the battery.
4.)The motor should beep a 1 2 3 beep followed by two short beeps. Immediately after the two short beeps, put the throttle stick down all the way, the motors should make 3 short beeps (representing the 3 cells of the battery) and then finally make a 1 long beep, indicating that the throttle range has been set (calibrated).
Old Jul 31, 2012, 04:53 AM
TS00's Avatar
Canada, NB, Moncton
Joined Jun 2011
Exactly :-)
Old Jul 31, 2012, 05:59 AM
Slovenia
Joined Jun 2008
Done calibrating
Thanks for the help!
Old Aug 01, 2012, 04:21 AM
Slovenia
Joined Jun 2008
Total weight now with 4S 4000 battery but without landing gear is 1492g.
Old Aug 01, 2012, 04:28 AM
TS00's Avatar
Canada, NB, Moncton
Joined Jun 2011
Not bad for the size.
Old Aug 01, 2012, 04:37 AM
Slovenia
Joined Jun 2008
Thats good to hear I didnt really know if that was good or not
Old Aug 01, 2012, 06:01 AM
Slovenia
Joined Jun 2008
OK so i hooked it up to the battery for the 1st time! Works as intended
Had to make another throttle calibration as they didnt start at the same time.
Looking good sofar
Old Aug 01, 2012, 07:05 AM
TS00's Avatar
Canada, NB, Moncton
Joined Jun 2011
Cool, now go flying!
Old Aug 04, 2012, 04:46 AM
Slovenia
Joined Jun 2008
Hey,
OK so im getting really close now. Waiting for propellers (10x4.5) to arrive as i ordered the wrong ones from HK.
The weight will be abit more then i first thought, so with battery close to 1700g.
Old Aug 05, 2012, 10:47 AM
Joined Apr 2012
Nice spherical canopy! Where did you get one ?
riahut.com is offline Find More Posts by riahut.com
Discussion Where can I get inexpensive carbon rads and tube Dave K Composites Fabrication 9 Jul 16, 2012 08:27 PM
Video Hobby King Rad-Jet 800 Video...FAST! budkeywest Electric Plane Talk 0 Mar 20, 2012 09:14 PM
For Sale RAD and Mini RAD for sale nasnem Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 2 Mar 03, 2008 10:58 AM
