Old Jan 11, 2011, 03:18 AM
United States, TX, Dallas
Joined Jan 2011
Help!
70mm setup on a Sniper
Greetings fellow fan flyers! My background is 200mph+ nitro fans, but I'm new to EDFs. My Electrifly Evader and E-flite F86 are fast with their recommended setups but my irrational need for higher airspeeds drove me to build an HET Sniper 70mm (clipped wing). I beefed it up with two CF spars, glassed wing and tail with all flight surface controls inside the wing and fuselage. The airframe is as slippery as it's gonna get. Months of net surfing and fan calcs along with airframe space/weight/balance considerations has yielded only the installation of a Wemotec Fan Pro, CC IceLite 100A ESC and no more than a single 4S 3700 mAH 35C LiPo up front between the converging intake ducts. So what motor to use? Neu 1112-1Y? ARC 28-58-1? Mega 16-something? I would greatly appreciate any real world experienced suggestions or endorsements you may have. Thanks...
Fanflyer is offline Find More Posts by Fanflyer
Old Jan 11, 2011, 07:32 AM
Dublin Ireland
Joined Aug 2005
Hi there
I have had both a composite version and a the one you have with the balsa wings.
I have had it with a HET 2W-20 on 4S 3700mah.That was fast and fun Untill the wings folded.(balsa Wings)
I then went with a composite Sniper. I put in a LS1400 with 5S 3200.(3+2)
I could not get this off the ground.In my opinion too heavy.
I ended up flying this on 3S.I got about 4 mins flying with throttle management.Not fast but fun.
Cheers
Steve.
PS.When you timer tells you to land,"LAND".Otherwise you could loose total power and wreck the plane.
Dont ask me how I know that:
STEVEAIR2 is online now Find More Posts by STEVEAIR2
Old Jan 12, 2011, 11:01 AM
Joined Jan 2011
Thanks Steve, you were spot on with the timer at 4 minutes and throttle management. I use that regime with the Evader( 4S 2600mAH 35C) and the E-flite F86( 4S 3300mAH 30C). All-composite airframes weigh more than glassed balsa does. With double CF spars my Sniper wing held 50 lbs of sandbags at a 15 degree deflection- that's 16Gs! And the aircraft AUW is still under 1200 grams. Now if I could just get 1300 grams of thrust on 4S...!
Old Jan 12, 2011, 01:33 PM
obreitan's Avatar
Joined Nov 2007
Hi
you could rig up with a Typhoon 1W-30 it will give you at least 1500 grams of thrust on 4S
obreitan is offline Find More Posts by obreitan
Old Jan 12, 2011, 01:51 PM
My Lipo is Bigger than Yours!
gjmjoe017's Avatar
Chesterfield,Missouri
Joined Sep 2003
My original Sniper was on a 3s setup and flew great.Got another one this summer and went with a 5s setup,just too heavy.Broke the wing on landing in the grass.Being a belly flopper,too much weight makes almost impossible to land without damage.
gjmjoe017 is offline Find More Posts by gjmjoe017
Old Jan 12, 2011, 02:56 PM
Lipo abuser ... smoke on!
gp125racer's Avatar
Joined Feb 2005
The ARC 28-47-1 is worth a look .... should be good for 1200+ watts on a decent 4 cell lipo (depending on your ducting) in the HET 6904. It'll run right about 95A maybe some small bursts over 100 with a fresh pack, so with your 100A ESC, you'll wanna use short bursts of full throttle.
This setup which is almost identical to yours gets him to 150:
HET Super Sniper with ARC 28-47-1 (2 min 20 sec)
Oh, and the motor will run on 5s as well (if you keep it cool, maybe even more??) but with a very high amp load. Something to consider if you wanted to brave the whole 5s issue.
gp125racer is offline Find More Posts by gp125racer
Latest blog entry: D100
Old Jan 12, 2011, 06:10 PM
Aka: Tom Jenkins
ApexAero's Avatar
Palm Beach County, Fl.
Joined Aug 2008
Good call GP, that and don't forget the mpi heat sink!
The 1W-30 proly be good for a 4s light setup but needs a 125esc and some grunt to push it.
My experience with both motors is the 1W has a bit more punch, limited to 4s only, more power consumed.
The 28-47 seems to be the high power all around motor on 4s, a bit easier on batts. Depending on your needs both are great motors.
ApexAero is offline Find More Posts by ApexAero
Old Jan 12, 2011, 09:02 PM
Joined Jan 2011
ApexAero's point about the ARC 28-47-1's being a little easier on bats is well taken. 150mph on a stock- looking Sniper is encouraging. I rolled up a Mylar efflux tube with a constant taper down to 50mm, but those Wemo glass tubes look interesting..that's prolly another thread. Is the "MPI heatsink" the finned type or a machined aft nacelle?
Old Jan 12, 2011, 10:37 PM
Aka: Tom Jenkins
ApexAero's Avatar
Joined Aug 2008
Finned, I trim it to fit with a band saw and clean up the edges with a wire wheel. Be sure to use thermal paste.
http://www.effluxrc.com/28mm-Heat-Si...ned-2836HS.htm
Old Jan 13, 2011, 09:05 PM
Joined Jan 2011
Got it, stopped by and picked up some 7 carat diamond thermal paste- 4.5 times the heat conductivity of silver and no electrical conductivity. Six bucks for what looks like 2-3 28mm heatsinks worth in the tube. OK, let's see what comes out with the ARC 28-47-1/Wemo MiniFanPro(5 blade)/100A ESC/4S 3700mAH 35C. Thanks everyone...will check back with speedtrap results.
Old Feb 20, 2011, 09:58 AM
kimhey's Avatar
nøtterøy, NORWAY
Joined Mar 2006
Standing by for your results.... planning on similar setup
kimhey is offline Find More Posts by kimhey
Old Feb 25, 2011, 11:55 AM
"LiPo-Blaster"
RugFlyer's Avatar
Duluth, GA
Joined Apr 2009
Flight report, fanflyer?
RugFlyer is offline Find More Posts by RugFlyer
Old Feb 25, 2011, 01:38 PM
AKD001's Avatar
Southern California
Joined Dec 2009
Depending on your flying style, I'd really look into a CC 125A ESC to give you more headroom than the 100A ESC you mentioned.
AKD001 is offline Find More Posts by AKD001
Old Feb 25, 2011, 07:45 PM
Aka: Tom Jenkins
ApexAero's Avatar
Joined Aug 2008
Here's agraph from a 1W-30 on a lander 68mm(70mm class) on a CCIce 100 finned, 4s. Pulls almost 5lbs bell lip open exhaust. A Wemo would do better. You can see the full throttle, half, full and cool down over 90sec run. Esc in airstream, a finned Ice can sustain higher amps when well cooled
Old Feb 26, 2011, 12:31 AM
efflux RC's Avatar
United States, CA, Santa Clarita
Joined Aug 2009
Fan flyer,
Our Efflux pro EDF with a Minifan pro rotor will get you 5.5lbs thrust with the ARC 28-58-1 on 6s. (You may be able to push the Mega 16-40-1 futher on 7s with throttle management.)
Our ALL ALLOY 70 mm Will get you 6.48 lbs thrust with the same motors.
If you don't mind the high amps of a 4200 kv motor, our new "Cool 42" (4200 kv) will run very cool on 4s-5s.
Just a few additional possibilites.
Have fun - fly faaast!
Gary
efflux RC is offline Find More Posts by efflux RC
Site Sponsor
Latest blog entry: Updated blog Jan 2014
Help! Hyperion Sniper 3d servo mounting on there sides or vertical? (AILERONS) burton8012 3D Foamies 11 Oct 20, 2010 10:25 PM
Discussion Super Hot 70MM Fan setup. Big Power? Pepperpete Foamy EDFs 3 Sep 08, 2010 08:59 AM
Discussion Super Sniper 70mm stoneenforcer Electric Ducted Fan Jet Talk 11 Apr 21, 2009 06:34 AM
Discussion HL Specs on 70mm Setup??? jetfan20 Electric Ducted Fan Jet Talk 0 Dec 09, 2008 09:19 PM
