Old Apr 19, 2015, 03:39 PM
DanBo3D is offline
Find More Posts by DanBo3D
RC Keeps Me Sane
DanBo3D's Avatar
United States, NJ, Carlstadt
Joined Sep 2005
http://www.freewebs.com/eppeagle/
says he started shipping again Nov 2014
Graves has the one I fly (E-aero) same bird/kit & painted black.
http://www.gravesrc.com/e-aero-eagle-epp-kit.html
DanBo3D is offline Find More Posts by DanBo3D
Old Apr 19, 2015, 08:02 PM
martimer is offline
Find More Posts by martimer
USA, MO, O'Fallon
Joined Dec 2003
Whew. Too good a plane to have out of production!
martimer is offline Find More Posts by martimer
Old Apr 21, 2015, 01:34 PM
TwistedGrin is offline
Find More Posts by TwistedGrin
Yes it was Abby Normal
Joined May 2012
Originally Posted by Buck Shot View Post
Flew mine for the first time today. Flew like a dream!! No adjustments at all. Wind was 10 to 20 mph no problem!! Had a couple of Hawks come out to check it out. Didn't give it much credit at first. The 1600 batt. worked well. It just floated around with no power. Had a lot of fun with it. Buck
Wow I have flown in soft 10mph winds OK.....My set up would not fly well in 20mph winds!!!
TwistedGrin
TwistedGrin is offline Find More Posts by TwistedGrin
Old Apr 21, 2015, 06:57 PM
Buck Shot is offline
Find More Posts by Buck Shot
Joined Apr 2012
TwistedGrin
All I can tell you is the wind sock was sticking straight out and my buddy was flying it. He has been doing this for 60 years and said he had to fly it every second. Buck
Buck Shot is offline Find More Posts by Buck Shot
Old May 02, 2015, 01:41 PM
Joined Apr 2012
Flew mine for the first time today. Got it up a little rudder and sat down and had sandwich and took a nap!! What a fun thing to fly! Eight Turkey Vultures came over and checked it out. Buck
Old May 02, 2015, 06:12 PM
DanBo3D is offline
RC Keeps Me Sane
DanBo3D's Avatar
Joined Sep 2005
That's what a successful maiden sounds like. Good job, good fun.
Old May 03, 2015, 01:43 PM
philgib is offline
Find More Posts by philgib
philgib's Avatar
Joined Oct 2005
Hi guys,
I have flown my EPP eagle OK with a motor, now i would like to try slope flying and therefore drop the engine, esc, etc...
How do you set up the EPP eagle for slow flying and how do you manage the CG while staying light ? Which lipo ?
Thank you
philgib is offline Find More Posts by philgib
Old May 03, 2015, 01:52 PM
DanBo3D is offline
RC Keeps Me Sane
DanBo3D's Avatar
Joined Sep 2005
It would be the same bird basically but you would have to just keep the correct CG.
Weigh your battery now, then weigh the motor and ESC and combine the theoretical weight to maintain a flyable CG. But the actual weight could/should be less as you could move the battery & Rx more forward if your build allows.
Old May 03, 2015, 02:07 PM
DanBo3D is offline
RC Keeps Me Sane
DanBo3D's Avatar
Joined Sep 2005
Here are 2 vids of Flyparty sloping
EPP EAGLE SLOPE VIDEO~2 (3 min 32 sec)
EPP EAGLE SLOPE VIDEO (3 min 15 sec)
Old May 03, 2015, 09:00 PM
Econoline is offline
Find More Posts by Econoline
Econoline's Avatar
United States, CA, Ventura
Joined Nov 2007
I've thought about sloping mine but I'd just remove the battery and prop, and put some tape over the motor to keep dirt out on landing. Then rebalance to get the CG right. Then it's a simple conversion back to power.
Econoline is offline Find More Posts by Econoline
Old May 03, 2015, 11:06 PM
gofast53 is online now
Find More Posts by gofast53
gofast53's Avatar
New Zealand, Auckland, Pukekohe
Joined Oct 2014
I have tried sloping and found that with the v-tail I could not get large enough control throws to be able to control it. Also not having it set up with ailerons doesn't help.
gofast53 is online now Find More Posts by gofast53
Old May 04, 2015, 12:52 AM
philgib is offline
philgib's Avatar
Joined Oct 2005
Thx guys.
What typical battery should I go for in the absence of motor for an easy CG for sloping ?
3S1500ma ?
Old May 04, 2015, 07:27 AM
DanBo3D is offline
RC Keeps Me Sane
DanBo3D's Avatar
Joined Sep 2005
Possibly, but as you might know, whatever the lightest you could use to maintain a proper CG with it pushed as forward to make the adjustments.
I fly my powered Eagle with a 1300-3s for 10minutes or 2200 for 20minutes
Old May 06, 2015, 11:22 PM
speedactyl is offline
Find More Posts by speedactyl
Defies Logic & Common Sense
speedactyl's Avatar
Philippines, NCR, Makati City
Joined Jun 2012
speedactyl is offline Find More Posts by speedactyl
Discussion EPP Eagle fuzzyhead Foamies (Scratchbuilt) 2 Sep 28, 2008 09:54 AM
