Old Jan 27, 2015, 01:46 PM
Jsutherland8 is offline
Find More Posts by Jsutherland8
ELECTRIC R/C
Jsutherland8's Avatar
Canada, ON, Woodstock
Joined Feb 2006
Alert
JST-2P connector NOT wired for LIPO
I just got some JST-2P connector sets in from ROBOTHOME off EBAY and soldered on to an ESC. Went to test it and Burned Fingers, Burned part of model, melted inuslation off wires, and FREID ESC.
I have sent ROBOTHOME a warning to post. Other JST-2P I have seem to be OK.
DANGER......DO NOT USE WITH LIPO BATTERY.......WIRED BACKWARDS
This JST-2P is not wired in the standard congiceration for ESC to LIPO connection. RED and BLACK wires are REVERSED to standard LIPO.
Please post this with item to prevent FIRE or Personal Injury.
Wires Melted, Burned Fingers, Burned through part of model......Fried 10 Amp ESC.
Jsutherland8 is offline Find More Posts by Jsutherland8
Old Jan 27, 2015, 03:28 PM
tacx is offline
Find More Posts by tacx
tacx's Avatar
United States, MI, Romeo
Joined Apr 2009
Never trust anything. Always check polarity on leads, harnesses, servo extensions and batteries. Never trust that the factory has wired things properly.
A multi meter is your friend!!!
tacx is offline Find More Posts by tacx
Old Jan 27, 2015, 06:50 PM
Ira NZ is offline
Find More Posts by Ira NZ
Bombs away! Err...landing
Ira NZ's Avatar
Upper Hutt, New Zealand
Joined Apr 2006
Why would you ever have two different configurations based on chemistry? Should always be red wire positive, black wire negative.
Ira NZ is offline Find More Posts by Ira NZ
Old Jan 27, 2015, 08:26 PM
desertstalker is online now
Find More Posts by desertstalker
Australia, VIC, Melbourne
Joined Feb 2010
It is, but which side of the plug you put the +ve on is not specified, so can vary for different applications.
desertstalker is online now Find More Posts by desertstalker
Old Jan 28, 2015, 02:53 AM
abenn is online now
Find More Posts by abenn
Letchworth, Great Britain (UK)
Joined Jul 2004
I agree, the issue is not LiPo-specific; the plugs and wiring don't know where your electricity comes from. They should always be wired the same way and, from the photos you've posted, they aren't.
I'm not excusing the supplier, but you can easily see if the plugs are wrong when you try to connect them together, without frying things, for red wire should go to red wire.
Incidentally, what's the purpose of the third photo in the OP? It seems to be the first photo turned upside down.
abenn is online now Find More Posts by abenn
Sold JST-XH Lipo Balance Wire Extensions for 2S, 3S, 4S, 5S & 6S iiinsaiii Aircraft - Electric - Batteries & Chargers (FS/W) 2 Nov 08, 2013 04:13 AM
Sold JST-XH Lipo Balance Wire Extensions for 2S, 3S, 4S, 5S & 6S iiinsaiii Non R/C Items (FS/W) 0 Nov 05, 2013 12:56 PM
Sold JST-XH Lipo Balance Wire Extensions for 2S, 3S, 4S, 5S & 6S iiinsaiii Aircraft - Electric - Multirotor (FS/W) 15 Oct 30, 2013 04:04 AM
Sold JST-XH Lipo Balance Wire Extensions for 2S, 3S, 4S, 5S & 6S iiinsaiii Non R/C Items (FS/W) 4 Oct 25, 2013 10:34 AM
Sold JST-XH Lipo Balance Wire Extensions for 2S, 3S, 4S, 5S & 6S iiinsaiii Aircraft - Electric - Batteries & Chargers (FS/W) 0 Oct 10, 2013 08:04 PM
