Old Oct 24, 2014, 03:01 PM
John O'Sullivan is offline
Find More Posts by John O'Sullivan
John O'Sullivan's Avatar
Nova Scotia Canada
Joined Jan 2004
Need a good CG and MAC Calculator for multitapered wing
I had a great multi-tapered wing CG and MAC calculator which accommodated a 5 panel tapered wing.
However it was on an older computer and I have lost the link to it.
I have searched the internet but the best I can get is for a 3 panel wing. It does the job reasonably well but my old program worked much better.
Does anyone have a link to that wonderful calculator program?
John O'Sullivan is offline Find More Posts by John O'Sullivan
Old Oct 24, 2014, 04:08 PM
rrcdoug is offline
Find More Posts by rrcdoug
rrcdoug's Avatar
Canada, BC, Kelowna
Joined Aug 2010
I guess you could use XFLR5 to do this. It might be cumbersome because it needs airfoil coordinates and must generate polars for each panel foil specfied in your design. It is fussy about older coordinate tables with fewer than 100 chord stations but it has a utility that fixes that. Gives you most any graph you might want about your wing's predicted performance.
http://www.xflr5.com/xflr5.htm
BTW, I have been using rollfuz to make a few tailbooms for a big electric glider. I was able to do a wet seam on one but there are then problems with air getting in the open edge reqired for the seam. The air problem was only cosmetic so the boom was quite usable. Thanks for sharing.
rrcdoug is offline Find More Posts by rrcdoug
Old Oct 24, 2014, 06:00 PM
Wazmo is offline
Find More Posts by Wazmo
Duane
Wazmo's Avatar
No. VA
Joined Nov 2004
Sailplane Calc will do four panels per side.
Wazmo is offline Find More Posts by Wazmo
Old Oct 24, 2014, 07:04 PM
jetmaven is offline
Find More Posts by jetmaven
I use
adamone.rchomepage.com/cg_calc.htm
I believe it will do up to four panels .
Good luck
jetmaven is offline Find More Posts by jetmaven
Old Oct 24, 2014, 08:48 PM
Soarmark is offline
Find More Posts by Soarmark
Mark LSF # 3792
United States, TX, Garland
Joined Nov 2008
Used this in the V version...predicted all of the characteristics of a glider I built and had trimmed by trial and error. Is only four panel though. My preferred CG is dead in the middle of the starting CG and neutral point.
Soarmark is offline Find More Posts by Soarmark
Old Oct 25, 2014, 06:06 AM
Nova Scotia Canada
Joined Jan 2004
Thanks Guys.
Not the original program I had, but they work just as well.
rrcDoug, glad you got some use for the RollFuz method.
http://www.windandwavemodels.com/rollfuz.html
Old Oct 25, 2014, 06:39 AM
hallo is offline
Find More Posts by hallo
incorrigible model maker
hallo's Avatar
Joined Feb 2014
Here is just some additional files that might be useful to some, thanks.
http://www.tailwindgliders.com/Files.html
hallo is offline Find More Posts by hallo
Discussion Calculating CG on rc birds wings ? philgib Electric Plane Talk 5 Jul 01, 2014 03:47 AM
Discussion Calculating MAC for twisted swept wings kcaldwel Nurflügel 127 Jul 11, 2013 07:54 AM
Question MAC calculations for tapered wing? pqt_bach Modeling Science 9 Apr 28, 2009 04:10 PM
Calculating wing CG for a scratch built wing?? rcminiman Flying Wings 11 Sep 30, 2005 11:42 AM
Calculate CG for a flying wing? Pjotrrr Foamies (Kits) 3 Aug 27, 2003 03:14 PM
