Old May 22, 2013, 12:12 PM
irelandchad is offline
Find More Posts by irelandchad
United States, MI, Clio
Joined Mar 2004
Funjet Ultra Torque Roll
I have a funjet I bought off craigslist the guy clocked it at 169mph. I have flown it three times now and the torque roll on the launch is terrible. Is there anything I can do to help alleviate this problem, other than a smaller motor. Here is the link to my first flight video.
On my second flight I was about treetop level and quarter throttle. Went to WOT and it torque rolled 3 times before I know what happened but ended right side up. It was crazy!!
Motor Turnigy 3648-1400KV
ESC Hobby wing 100a platinum
Bat Turnigy Nanotech 6s 2650
The plane is covered in 10 min finishing epoxy and wieghs in at 4lbs
Any help would be great!
First flight Funjet ultra (1 min 49 sec)
irelandchad is offline Find More Posts by irelandchad
Old May 22, 2013, 12:24 PM
DaveSawers is offline
Find More Posts by DaveSawers
Canada, NS, Lunenburg
Joined Oct 1999
Try launching at half throttle. From idle, always throttle up slowly.
DaveSawers is offline Find More Posts by DaveSawers
Old May 22, 2013, 12:26 PM
Joined Mar 2004
The launch in the video was alittle less than half throttle.
Old May 22, 2013, 12:28 PM
sebbe is offline
Find More Posts by sebbe
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
there is no way to get help , thats how i lost my ultra, this time Im going for bungee start, HK:s blue rubber band they say is allright, take a few steps back and release, and thats enough for the ultra to get airborne and even make a turn before hitting the throttle
I throw hard and straight, didnt help... you have a guy throwing for you, even better, but still its a problem...
anything bigger then 6" prop is a pain and heavy dont help either...
You can throw it straight up, and let the ultra do its thing and just go with it, thats one way..
Dont think you will find a way throwing a 4 lbs ultra with that torque easy way..
sebbe is offline Find More Posts by sebbe
Old May 22, 2013, 12:33 PM
arcticflyer is offline
Find More Posts by arcticflyer
arcticflyer's Avatar
Canada, SK, Prince Albert
Joined Jan 2006
Am curious...what prop?
arcticflyer is offline Find More Posts by arcticflyer
Old May 22, 2013, 12:36 PM
sebbe is offline
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
I would say hes using a 7" prop.
Old May 22, 2013, 12:42 PM
Joined Mar 2004
7x5 prop. The third flight I had was little better. Diffrent guy throwing lots of right stick and a low right wing throw. But it still scared the crap out of me!!.
Old May 22, 2013, 01:40 PM
stanordave is offline
Find More Posts by stanordave
stanordave's Avatar
Joined Jan 2006
I'm not sure the rubber band would work w/6s.
Haven't seen it so can't say for certain but just yesterday tried the latex tubing, which launches a 4s 3300 FJU just fine, and it couldn't get enough pull to get the 6s one moving fast enough to use the elevons. Lot of variables so only someone who's done it w/6s can say for certain..
stanordave is offline Find More Posts by stanordave
Old May 22, 2013, 01:51 PM
sebbe is offline
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
stanordave , the ultra with the hk 1900kv and 6s 2700mah is just fine with that HK blue rubber. its confirmed but at least one guy,,, thats why I bought it.
It was he who said it will go up and make turn before you have to hit the throttle.. he said you have to make it 2 way, spilt the blue rubber in 2 pieces, put them together. perfect..
Sebbe
Old May 22, 2013, 03:27 PM
Rolf D. is offline
Find More Posts by Rolf D.
What is Highspeed ?
Rolf D.'s Avatar
Germany, BY, Bergen
Joined Feb 2011
Oh Boys
the Problem where the "half" torque roll Comes from is very good to see in the Video.
Motor ON:
and at the same Moment the guy throws the FJ out !
Point is - he did not wait for a Moment that the Propeller has grip.
so what happens ? easy : prop no grip : flow demolution - flow demolution what happens by it ?? YES - Plane like a funjet goes starting to torque !
when in the torque roll Propeller gets grip and it that Moment the Motor in the bird has enough power to bring him Forward.
so next time - throttle of, wait a Moment ( I know the dude´s who throw it feel scary from the noise ) and than start like it has to bee
regards
Rolf
Rolf D. is offline Find More Posts by Rolf D.
Old May 22, 2013, 03:43 PM
stanordave's Avatar
Joined Jan 2006
Thanks Sebbe! Gonna order one now!
[edit] not gonna order one now..out of stock!
Old May 22, 2013, 03:53 PM
Kwahn is offline
Find More Posts by Kwahn
Germany
Joined Jul 2010
Why would waiting help the prop develop "grip"? Maybe you should do a burnout at full throttle which heats up the air and the prop and thus gives you more grip like in drag racing!
No seriously, launch with enough power for the plane to accelerate safely, if you have better than 1:1 thrust to weight a steep launch is a good way to give it more room to do its thing without crashing. Don't throttle up immediately after launch because at low speed the inertia of the outrunner can accelerating and of course the torque will flip the plane over. Once you have some airspeed you can smoothly push up the power.
Edit: I've looked up 'demolution' it seems like that's a rock band from holland?
Kwahn is offline Find More Posts by Kwahn
Old May 22, 2013, 03:58 PM
richman03 is offline
Find More Posts by richman03
richman03's Avatar
United States, TX, Friendswood
Joined Feb 2012
Try using reflex on takeoff. I use the speedbrake option on my futaba 7c for takeoff. I flip a switch to put the ailerons up a little bit and give a good throw with 1/2 throttle (hit the switch to neutralize the controls shortly after takeoff). Not sure if this will help your torque rolls on takeoff but it makes takeoff much easier
richman03 is offline Find More Posts by richman03
Old May 22, 2013, 04:00 PM
Rolf D. is offline
What is Highspeed ?
Rolf D.'s Avatar
Germany, BY, Bergen
Joined Feb 2011
I do not mean with FULL THROTTLE
demolution was the Little devil in my Keyboard ;-) means flow demolition
Old May 22, 2013, 04:09 PM
DownUnderPilot is offline
Find More Posts by DownUnderPilot
2012 NZ Speedcup - 231 MPH
DownUnderPilot's Avatar
New Zealand, Tasman, Richmond
Joined Mar 2006
Prop down to 6" (say a 6x6)... A 7" prop is almost 25% of the wingspan.
DownUnderPilot is offline Find More Posts by DownUnderPilot
Discussion Torque rolls and Rolling harriers wishawhunk 3D Foamies 6 Apr 06, 2013 02:26 PM
Sold Funjet Ultra with HS65MG's $100 (local pickup) Houston johnnyrocco123 Aircraft - Electric - Airplanes (FS/W) 0 Apr 04, 2013 09:16 PM
Sold Funjet Ultra with HS65MG's $100 (local pickup) Houston johnnyrocco123 Aircraft - Electric - Airplanes (FS/W) 0 Mar 28, 2013 06:16 PM
Discussion Funjet massive torque roll- need help kingkyle Flying Wings 10 Apr 30, 2011 09:23 PM
Question ultra stick 40 torque-roll Dan and son Bry Competition Aerobatics 0 Jul 16, 2002 01:55 PM
