Old Oct 24, 2012, 01:54 AM
skyracer068 is offline
Find More Posts by skyracer068
skyracer068's Avatar
Singapore, Singapore
Joined Jan 2006
RC Lander T-33 "Chino Style"
After watching Corsair Nut and Falcon5 (my brother) do a little formation flying at the Las Vegas "Ace in the Hole" electric event a year ago with their T-33's, I knew this aircraft was needed in my fleet. I like to "change it up" and not have the same plane as everyone else so, I use a technique I've found to work well with foam planes to change the scheme. After filling all the voids and defects in the foam with filler, then applying a light coat of water based clear and sand to an ok finish. Now I apply the scheme of my desire with Oracal 2mil vinyl. Through different distributors, I usually purchase vinyl by the yard for 1/2 the cost of Ultracote. Here is where I'm at so far. I’ve added a couple of pictures of foam planes I have done in the past.
Daryl
skyracer068 is offline Find More Posts by skyracer068
Old Oct 24, 2012, 10:23 AM
CARL SCHIMNOWSKI is offline
Find More Posts by CARL SCHIMNOWSKI
Joined May 2007
Hi Daryl
Are you using the Oracal just for the trim, or covering the whole fuse and wing with Oracal
Carl
CARL SCHIMNOWSKI is offline Find More Posts by CARL SCHIMNOWSKI
Old Oct 24, 2012, 10:58 AM
falcon5 is offline
Find More Posts by falcon5
Capt. Z
falcon5's Avatar
United States, NV, Las Vegas
Joined Dec 2004
Looking great bro..keep the pics coming. I like the vinyl idea pretty sweet. does it add much weight?
falcon5 is offline Find More Posts by falcon5
Old Oct 24, 2012, 11:39 AM
Joined Jan 2006
Originally Posted by CARL SCHIMNOWSKI View Post
Hi Daryl
Carl
The whole aircraft will be covered with Oracal. The 2 mil is very easy to work with as it is very pliable and strechable. Anything thicker is harder to work with.
On the Phase 3 F-16, it only added 1.5 ounces to the total weight. I'm figuring about 7 to 8 ounces total to the weight. the only negative is they dont offer any flat colors. I've seen foam spray that everyone is using now has added over a pound of weight to the airframe but, you also need to factor in the paint that was applied. BTW, mom says hi.
Old Oct 24, 2012, 12:47 PM
Joined Jan 2006
Just to let you know, I had a issue with the T-33 and contacted RC Lander. Tim Wan responded immediately with a resolution. RC Lander has the best customer service I have ever seen.
Old Oct 24, 2012, 12:49 PM
falcon5 is offline
Capt. Z
falcon5's Avatar
Joined Dec 2004
Wow sounds nice..I will look into that stuff. Tell mom Hi back.
Old Oct 24, 2012, 04:10 PM
Joined Jan 2006
The UPS man just dropped by to say hi and brought me these!!!
Falcon5, here is where I buy the vinyl. http://pacificcoastsignsupply.com Just call or email, they will send a brochure with all the vinyl they carry.
Old Oct 24, 2012, 09:42 PM
killickb is offline
Find More Posts by killickb
killickb
killickb's Avatar
The Villages. Florida
Joined Jan 2005
Those models look very nice and the material looks very interesting so visited that site. However seems they have many different Oracal materials/finishes/thicknesses. Do you have an exact part number for one of the colors you choose? Didn't find a color chart on their website -- do they have one ? Will they mail it?
Is this a sticky back material or do you have to apply an adhesive and do you have to adhere to compound curves in small panels? Surface prep? Looks like you might have opened Pandora's box here so now you're going to have to give us a complete finishing process !!!
killickb is offline Find More Posts by killickb
Old Oct 24, 2012, 11:55 PM
AIR SALLY is online now
Find More Posts by AIR SALLY
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
what size fan is that ? i really like this Chino T-33 ...we have seen it the last two years at the airshow .....they aborted both years .they need a good mech.
AIR SALLY is online now Find More Posts by AIR SALLY
Old Oct 25, 2012, 11:45 AM
Joined Jan 2006
killickb- If you call them, they will send you a catalog with all the vinyl sizes and colors. It is a sticky back that adheres very well. It is pliable to stretch around wing tips and compound curves, sometimes with a little heat like from a hair dryer. Don't get it to hot or the foam will begin to separate and give you a bumpy finish. For surface prep, fill in all the defects you donít want to be seen with a filler of your choice and sand, then, apply a couple of light brush coats of a water based clear (like they sell at home depot-brush, not spray. The propellant in the spray cans is not foam safe) and lightly sand. Not to a perfect finish like you would do with paint because vinyl will hide some defects. Now apply the vinyl. Here is a picture of my Ultimate I covered with Ultracote white and then applied the blue and red vinyl. On the wings and fuse, I sprayed the vinyl with Windex, positioned the vinyl in place and squeegee the vinyl to a sooth finish. I hope this helps and I'll have more picture of the process soon.
AIR SALLY- 90mm Stumax. I loved the sound of falcon5ís T-33. Chinoís T-33 was at Reno this year and did 1 lap around the pylons. AWESOME!!!
Here is a Lear I did a while ago with vinyl as well
Old Oct 25, 2012, 01:40 PM
falcon5 is offline
Capt. Z
falcon5's Avatar
Joined Dec 2004
Dang bro that Ultimate looks SWEET!!! nice work. I like the new shroud Stu is putting on his 90mm fans.
Old Oct 26, 2012, 08:01 AM
corsair nut is offline
Find More Posts by corsair nut
fly like an EAGLE ;)
corsair nut's Avatar
tehachapi, CA
Joined Jan 2006
hey D, did anybody happen to ask about chargers left at the field from the event a couple weeks ago? i left i two blue imax chargers at the event on saturday. i figure somebody snagged them, but maybe somebody picked them up too.
corsair nut is offline Find More Posts by corsair nut
Old Oct 26, 2012, 12:04 PM
Joined Jan 2006
I saw that AIR SALLY posted this situation on another thread. I emailed everyone I knew to include club officals to see if they had them. I will get in touch with Darrell Stubbs and Greg Clemenson to see if they have them.
Daryl
Discussion RC Lander T-33 build thread falcon5 Foamy EDFs 1395 Apr 19, 2015 04:26 PM
Question RC Lander CMP T-45 retracts. Are they worth the price? Quentus Electric Ducted Fan Jet Talk 6 Oct 11, 2012 04:27 AM
Discussion RC Lander T-33 power system Hellcat716 Power Systems 6 Feb 18, 2012 01:01 AM
Wanted rc lander t-33 warbird_cowboy Aircraft - Electric - Jets (FS/W) 0 Dec 26, 2011 04:06 PM
Discussion Chino is going to fly their new (old) T-33 Nov 7th Brian Koester Inland Slope Rebels 0 Nov 06, 2009 04:19 PM
