Old Mar 05, 2013, 01:49 PM
dangerdan is offline
Find More Posts by dangerdan
Aka: Ralph
Canada, ON, Hamilton
Joined Nov 2012
Originally Posted by Sculptor View Post
AJ, is "crow" the same as air brakes? Here in the River the wind is always coming out of the South and I live on the north side of the river. I should have no problem launching into the wind I'm gonna have to bring it back and landed coming down tomorrow have to put it down in about 50 feet of yard. I've never practice landing downwind. You think I can even get this plane on the ground coming downwind?
Angelo sculptor Baker is just gorgeous. Studying your photo of him I projected forward in time to what he will probably look like when he's fully grown. Then I knocked out this 3D sketch. See what you think.
DJAttachment 5589458
I got this quote of another site.
The joy of flaps is not to come in fast and HIT THE BRAKES!.
The joy of flaps is to lower the stall speed of the glider by adding camber to the wing. This way you can come up to your landing spot so slowly that you can just kiss the ground gently so as not to wake up the ants.
Crow, is more of a braking tool but it takes away that slow approach as it kills some of the lift of the wings.
That is why I don't use crow or I only use a very small bit of up aileron. My goal is to approach the landing area slowly and gracefully when I am thermal soaring.
Now, on the slope, where the rotor can be severe and you need speed to keep control of the glider, there crow, and its huge braking force can be very valueable. You come up to the landing area with some speed so the rotor does not toss you around, then you high the brakes and drop it on the spot.
The right tool for the right job is what you want.
dangerdan is offline Find More Posts by dangerdan
Old Mar 05, 2013, 07:03 PM
ajbaker is offline
Find More Posts by ajbaker
Argue for your limitations
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
AJ,
1. is "crow" the same as air brakes?
2. I've never practice landing downwind. You think I can even get this plane on the ground coming downwind?
3. See what you think.
1. Short answer - Yes. But, read above post. He said it pretty well.
2. Short answer - Yes. But, downwind landings are to be avoided if at all possible.
3. Very cool. (is that a greyhound)?
AJ
ajbaker is offline Find More Posts by ajbaker
Old Mar 05, 2013, 08:49 PM
Sculptor is offline
Find More Posts by Sculptor
AKA, Cheap Chiseler
Sculptor's Avatar
United States, FL, North Fort Myers
Joined Mar 2012
AJ
I bought a new Bixler 1.1 and as before I will cut flaps into it, install the Eagle A3 Gyro board because I want fly my little 808 V2 #16 camera on it. This is the plane that I will fly out over the water and then have to land it in my backyard coming downwind. "2. Short answer - Yes. But, downwind landings are to be avoided if at all possible." In this situation it will not be possible.
I'll have to bring in over the water toward me coming downwind. I'll have to have enough power to hold it off the water a couple of feet. When I get to the yard I have to land it. I intend to set up a volleyball net with two nets one on top of the other. If everything goes to hell I'll fly it into the net.
A gentleman just posted a response to my questions about Crow and air brakes and he did a remarkable job in having me understand it, you acknowledged his contribution to my question.
To your question "is it a greyhound", yes Sir it is. And I considered to be the finest greyhound sculpture on earth and nearby planets!
Totally off topic for those who might find this distracting to watch.
Ace DJ Wilkins sculpture of the Greyhound at the University of Indianapolis.wmv (3 min 52 sec)
DJ
Sculptor is offline Find More Posts by Sculptor
Old Mar 05, 2013, 10:17 PM
datura is offline
Find More Posts by datura
datura's Avatar
United States, TX, Austin
Joined Dec 2012
Curious what you mean by "rotor" in this discussion? Thanks for the great info!
Justin
datura is offline Find More Posts by datura
Old Mar 05, 2013, 10:25 PM
ajbaker is offline
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
I think he means this
Justin
Read all about it here.
http://en.wikipedia.org/wiki/Lee_wave
AJ
Old Mar 05, 2013, 11:21 PM
datura is offline
datura's Avatar
Joined Dec 2012
AJ
Wow! Check this out: http://perlanproject.org/
As an amateur physicist this stuff really floats my, er, sailplane!
Old Mar 06, 2013, 01:02 AM
Ricky971 is offline
Find More Posts by Ricky971
Italy, Toscana, Orbetello
Joined Mar 2012
I'm reading everywhere that the perfect prop for this motor, on our Bixler 2, is a 6X4e.
Me too, I've bought a D2826-6 2.200Kv and these props:
http://www.hobbyking.com/hobbyking/s...propeller.html
http://www.hobbyking.com/hobbyking/s..._6x4_2pc_.html
even if the first one seems to be better.
I'm waiting the delivery in the next days, then I'll be able to write about them.
Ricky971 is offline Find More Posts by Ricky971
Old Mar 06, 2013, 02:12 AM
ajbaker is offline
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
The best way to determine the best prop is to run a thrust test on them. The more thrust, the more powerful the prop. Use a ~20lb. scale.
AJ
Old Mar 06, 2013, 02:26 AM
Ricky971 is offline
Joined Mar 2012
AJ
You cannot determine the best prop considering just the thrust: You can have big thrust with too high current drain and motor overload and this is not good.
The best is when You have an equlibrated rapport between thrust, current drain, motor temperature and battery duration.
Considering all these parameters, the best choose for this motor (not for me, but for all that it's written around and from tests made) on Bixler 2 seems to be a 6X4.
With a free software as this http://www.ecalc.ch/motorcalc_e.asp?ecalc
it's possible to have an idea of the correct prop for a long list of motors/ESC/battery/ plane weight.
When I'll receive it, before fly, I'll test everything with a tachometer, wattmeter, thermometer and dinamometer to determine if it's a good choose.
Old Mar 06, 2013, 02:41 AM
agedflier is online now
Find More Posts by agedflier
Australia, VIC, Bendigo
Joined Jan 2012
DJ I know it's off topic but I cannot let it go by without saying something about "Ace" You have impressive talents.I could swear that at some angles "Ace" looks alive.
Now..Have you ever thought about "sculpting" desktop aircraft..Your eye for detail and scale would be something to see.
John(aged)
agedflier is online now Find More Posts by agedflier
Old Mar 06, 2013, 04:11 AM
AussieHoppy is online now
Find More Posts by AussieHoppy
what goes up, must come down..
AussieHoppy's Avatar
Joined May 2010
as AJBaker said, downwind landings should well be avoided.
I would add to that and say downwind landings really should not happen.
A hyperthetical...
If the wind is 20km/hour and your average landing speed is 30kph [with say 20kph stall speed], in this scenerio the plane's airspeed (with tailwind) is only 10kph- no doubt well into a stall and impeding disaster. In this scenerio you need to have an airspeed of at least 40kph to land and this is right on stall speed... and 40kph accross the ground is a fairly hot landing, if you will appreciate
I have had the occassional tail wind landing only because I had to, and I will admit I have been lucky enough to pull it off ok... but I have seen many who have failed.
When I have had to land on tailwind I used a lot of ground to gently bring her down, simply due to the increased speed to keep above stall. You dont want to be in a small area and panic to get it down because a fence is fast approaching... it becomes a choice to either hit the fence or slam it down at speed...
Like anything in life, once you have clocked up enough experience you'll know how to judge a downwind or crosswind, whether to abort or rise to the challenge... but I wouldnt be trying it without experience
Hope that helps, Mr Sculptor
AussieHoppy is online now Find More Posts by AussieHoppy
Old Mar 06, 2013, 04:29 AM
Ricky971 is offline
Joined Mar 2012
Airspeed must be always the same: if Your plane stall at 20 Km/h, it must have at least 30 Km/h of air speed, for a safe final approach.
Since Your plane is in the air, it's the airspeed that You must consider.
What changes is the ground speed; with 20 Km/h of North wind, You can land in North direction at 10 Km/h of ground speed.
If You have the same wind from South and You still land in North direction, You'll land at 50 Km/h of ground speed, but Your airspeed, at the wheels contact instant, will be the same in both situations: 30 Km/h.
Old Mar 06, 2013, 09:22 AM
datura is offline
datura's Avatar
Joined Dec 2012
DJ: Maybe it's time to revisit the floats idea!
Also, very nice work on the greyhound!
Old Mar 06, 2013, 10:23 AM
cmavr8 is offline
Find More Posts by cmavr8
Chris
The Netherlands, NB, Eindhoven
Joined Sep 2010
DJ, can't you bring the plane around for the landing?
So that the end of your runway is the beginning of the lake?
You do face the danger of splashing it in the water, but you can put the volleyball net there... and anyway you'll have lots of space (over the lake) to give throttle and pull up for another try... and it's gonna be a slower landing if wind is stronger... instead of the opposite
cmavr8 is offline Find More Posts by cmavr8
Old Mar 06, 2013, 12:08 PM
Sculptor is offline
AKA, Cheap Chiseler
Sculptor's Avatar
Joined Mar 2012
I think I understand what y'all are trying to tell me. It amounts to don't land downwind, so I made this little film in the backyard showing what I'm up against. I used my new 808 #16 keychain camera, then put the film on the desktop but never having uploaded a film before I'm not understanding how to do this. I could put it up on YouTube meant download their maybe but when I try to attach it from right here that doesn't work. It's not that big, it's only about a minute half.
I just tried it again and it didn't work I'll look for some help files.
Can you tell me how to do this. There is a button for selecting individual lines or paragraphs to quote. I've been quoting the whole damn thing when oftentimes I just want quote line and respond to that. And select it but I'm not getting that right either.
DJ
Discussion Hobby King USA Warehouse wait time for bixler and 9x? elcid79 HobbyKing 13 Jun 09, 2014 08:13 AM
Discussion Hobby King Bixler motor? wehrwolfzug Power Systems 6 Mar 01, 2014 11:33 AM
Discussion Hobby King Buddy codes for Bixler FPV Build xxdixonxx Hot Online Deals 0 Jun 19, 2012 12:51 AM
Discussion Hobby king Bixler Buddy Code aaluu Foamies (Kits) 1 Feb 23, 2012 12:06 PM
