Old Jun 08, 2012, 01:07 PM
tengarang is online now
Find More Posts by tengarang
Fly Straight Fly High
tengarang's Avatar
San Jose, California
Joined Aug 2010
Hobbyking Shark High Performance Racer/Glider 1228mm Composite
Hey ALL
I think we all need a thread started for this bird....
The Hobbyking Shark is a high performance hybrid glider/pylon racer with distinctive F3A styling, this ARF version allows you to fit your own set up, perfect for the ultra speed freaks!
The airframe is composed of a Fiberglass fuselage AND wing, which is a removable 1pc item, only the horizontal stabilizer/elevator are balsa. The finish is quite superb and durable, there is no doubt, it looks fast, which is just as well, it IS fast! A model this quick needs to be well built and no corners have been cut, ailerons are "live" hinged & all the included hardware is sturdy and good quality for reliability and performance.
The Hobbyking Shark racer offers an unbeatable combination of low price, quality, good looks, practicality, ease of assembly and durability. When fitted with an ultra high performance set up, the Shark offers amazing performance that will keep even the most hardcore speed merchants happy!
Specs:
Wingspan: 1228mm
Length: 737mm
Wing Area: 16.2dm2
Airfoil: MH43 Modified
Flying Weight: 750g~900g
Requires:
Your Own 4 Ch TX/RX
2200mAh 3s Lipoly Battery
28mm inrunner Brushless motor (Min 2600kv)
30A~40A ESC w/BEC
3 x 9g~12g Servo
30mm~32mm Spinner
tengarang is online now Find More Posts by tengarang
Old Jun 08, 2012, 01:15 PM
tengarang's Avatar
Joined Aug 2010
Here is my setup, I got the ARF
480S motor 3200kV
CC75amp icelite
4.75x4.75 prop
1300mah 45C turnigy nanos 4s
have not maidened...CG is within the spec but not sure how it will hold out.
Old Jun 12, 2012, 12:25 AM
tengarang's Avatar
Joined Aug 2010
Maidened her today....wow she is fast,....so fast I couldnt even go full throttle i went as far as 3/4 and then a tid bit more...it was already smoking the funjets out of their misery.....ill need to flush the elevator to the rear horizontal stablizer some more before I take her up again...
my telementary system was reading 142mph....the radar gun reads 137mph....
full throttle next time down wind will yield more information.
Old Nov 13, 2013, 04:37 AM
CelloGuy is online now
Find More Posts by CelloGuy
CelloGuy's Avatar
Australia, NSW, Sydney
Joined Apr 2013
Has anyone else picked up one of these, or the Arrow which looks like exactly the same plane? I wouldn't mind knowing how the PNP version flies.
CelloGuy is online now Find More Posts by CelloGuy
Old Nov 13, 2013, 04:35 PM
tengarang's Avatar
Joined Aug 2010
Ive got one, got the kit version, a very Fast setup! using China Line Hobby 1300mah 4s 40C
used the 480s motor
http://www.hobbyking.com/hobbyking/s...er_3200kv.html
4.75x4.75 prop. Over 130mph easily.
esc 70amp castle creations.
Hand launch at half throttle plenty of thrust to not over torque.
I have not tried the PNP
Yippee! DRAGON LINK UHF - Made in USA, Professional Grade, Fully Guaranteed. JettPilot FPV Equipment 39958 Today 02:35 AM
Discussion Reverb Full Composite High Performance Electric Glider 1320mm fjante High Performance 4 May 21, 2012 11:31 AM
Discussion Deamon-2000 Composite Performance V-Tail mumblety-peg Electric Sailplanes 2 Mar 08, 2012 04:10 AM
Discussion Hobbyking Shark racer chris jones High Performance 3 Jan 21, 2012 10:50 AM
