Old Feb 22, 2010, 10:39 AM
playmake is offline
Find More Posts by playmake
Joined Oct 2008
Funjet... FAN!!! [real EDF]
Hi guyS!
I wanted to show you my progress in building my third funjet but... this time i wanted it... FANjet !!!
i decided for a quite extreme setup!
EDF: Wm400 Mk2
MOTOR: Het 2W25
ESC: Dualsky80A
Lipo: Flightmax 2650 40C
i didn't finished yet... but iesterday i tried a motor run with wattmeter...
impressive! 1400W !!! the fan is really screaming!
i'm wondering if that motor will last some flight o will die immediatly... any experience?
at the end, here you are some picture!
last but not least, I modified the wings cutting down the tanks to gain some more speed and imho it's just really beautiful whitout that and with this microjet-feeling
playmake is offline Find More Posts by playmake
Old Feb 22, 2010, 12:26 PM
MustangAce17 is offline
Find More Posts by MustangAce17
EDF Addicted
MustangAce17's Avatar
United States, FL, High Springs
Joined Sep 2005
ive done this 3 times now
MustangAce17 is offline Find More Posts by MustangAce17
Old Feb 22, 2010, 01:32 PM
playmake is offline
Joined Oct 2008
have you got experiences with 2w25?
how many "real" watt can it take?
is it better if I limit the throttle channel? to limit the total power for example 1200w?
or i can trust to fly as it is taking care of a good throttle management?
Old Feb 22, 2010, 03:13 PM
1satnaam is offline
Find More Posts by 1satnaam
1 OM KAR, SATNAAM
1satnaam's Avatar
GTA , Ontario
Joined May 2004
I did the funjet the same way, but
hand launched it and went in hard. Make sure you launch it proper way. I would suggest a Bungie launch to avoid problems. I have destroyed two jets from hand launches.
satnaam
1satnaam is offline Find More Posts by 1satnaam
Old Feb 22, 2010, 03:48 PM
Mark Wood is offline
Find More Posts by Mark Wood
characters welcome!
Mark Wood's Avatar
United States, CA, Bear Valley Springs
Joined Feb 2000
Correction:
You've destroyed two jets from crashes related to hand launches.
mw (head pedantic)
Mark Wood is offline Find More Posts by Mark Wood
Old Feb 22, 2010, 04:38 PM
fh64_lucky is offline
Find More Posts by fh64_lucky
Ginger or MaryAnn ??
fh64_lucky's Avatar
United States, TX, Garland
Joined May 2005
To me,you will be lucky that fan does not rip off that little bit of foam you have it glued onto.Maybee some CF under wood running up towards the front would transfer some of the load off rear of jet.Also,1400 watts eh?That battery may be 40c but it wont hold the amps very long,will be a short flight.What were the amps at?
fh64_lucky is offline Find More Posts by fh64_lucky
Old Feb 22, 2010, 04:50 PM
T-spin is offline
Find More Posts by T-spin
Joined Mar 2005
This is two of the funjets from Ocala, FL. The orange one was very very fast probable 150+, not very good in the turns though. They were racing them.
Tony
T-spin is offline Find More Posts by T-spin
Old Feb 22, 2010, 04:54 PM
Smokescreen38 is offline
Find More Posts by Smokescreen38
Checking CG is for NERDS!
Smokescreen38's Avatar
Joined Jun 2005
Originally Posted by playmake View Post
Hi guyS!
EDF: Wm400 Mk2
MOTOR: Het 2W25
ESC: Dualsky80A
That looks mean, Playmake! Keep us posted.
Smokescreen38 is offline Find More Posts by Smokescreen38
Old Feb 22, 2010, 11:57 PM
playmake is offline
Joined Oct 2008
the fan is just not only glued! there are 4 55mm long bolts wich pass under the wing and there is a second parts of wood in wich they bolts up! as a sandwich!
right for the flight time but with this power obviously i'll be at wot only a very few seconds, probably it will fly FAST at only 50% gas!
i've got also a 3000 30C and 3300 30C to use... in case!
the last question I didn't understand very well what you mean, if you whant to know where i putted wattmeter it was between battery and esc!
battery --> wattmweter --> esc --> motor
Discussion Any real life experts done the Aeronaut 2000NG or TF2000 fan treehog Electric Ducted Fan Jet Talk 5 Feb 07, 2010 05:26 AM
Discussion Schubeler HT Ducted Fan sounds like a real turbine XperTech Electric Ducted Fan Jet Talk 18 Nov 11, 2009 06:58 PM
Video Bob's EDF Funjet with 70mm Minifan-please doppler MustangAce17 Electric Plane Talk 3 Sep 07, 2009 10:24 AM
New Product FunJet EDF mounting bracket and FPV pod crd Foamies (Kits) 3 Sep 05, 2009 10:17 PM
For Sale edf x fan/kms edf motor/feigao edf/ele edf hot FASTBEN Aircraft - Electric - Power Systems (FS/W) 0 Mar 16, 2008 10:24 AM
