Old Nov 30, 2005, 05:59 PM
gabriel s21 is offline
Find More Posts by gabriel s21
Joined Aug 2005
Servo wires
Hi, I have a foamy with hitec hs55 servos. The wires are very long and I wanted to make them shorter to loose som grams, would this affect the servo´s performance? I was told that it would affect the servos speed is this true?
Gabriel
gabriel s21 is offline Find More Posts by gabriel s21
Old Nov 30, 2005, 06:16 PM
RMihara is offline
Find More Posts by RMihara
Aerial Shutterbug
RMihara's Avatar
San Mateo, California, United States
Joined Nov 2001
Hi Gabriel,
I've done a number of 'custom' servo installations over the years, from shared power wiring configurations to extensions as well as lead shortening.
What I can tell you based on that experience is that shortening the leads does not affect servo performance from a speed standpoint. Rather, lengthening leadwires increases the potential for voltage drops across the wiring and that will slow down servo response due to lower available servo motor drive voltage.
-Roger
RMihara is offline Find More Posts by RMihara
Old Nov 30, 2005, 06:38 PM
kevbeer is offline
Find More Posts by kevbeer
3d and other
kevbeer's Avatar
los angeles
Joined Jan 2004
making them shorter won't affect performance in a negative way.. Just make sure you reconnect and shield each wire carefully, and if you use solder, don't use too much. Twist wire ends neatly and heat shrink tightly should be adequate.
kevbeer is offline Find More Posts by kevbeer
Old Nov 30, 2005, 06:52 PM
Joined Aug 2005
Thanks a lot guys
Braided VS Twisted for long servo wires Kevin Murray Radios 7 Oct 27, 2008 07:55 AM
Anybody know how to fix servo wires pulled out of connector? Justin Jackson Parkflyers 11 Nov 19, 2002 11:24 PM
Shielded cable for long wing servo wires? :confused: Bernie Wolfard Power Systems 4 Apr 01, 2002 09:38 PM
Shielded cable for long wing servo wires? Bernie Wolfard Electric Sailplanes 2 Apr 01, 2002 07:27 PM
What are the three servo wires for? djiskra Electric Plane Talk 6 Oct 27, 2001 07:22 AM
