Old Mar 04, 2002, 05:02 AM
Mark Sanders is offline
Find More Posts by Mark Sanders
Mark Sanders's Avatar
Windsor, UK
Joined Jun 2001
New APC folding props - Anyone seen or used ?
APC make a range of folding props - with a 'unique hub system'
http://www.apcprop.com/store/agora.c...lding-Prop-Hub
But I cannot find any pictures or drawings to explain how it fits together and key dimensions. Anyone seen or used these, or know of a web site with pictures ? Thanks Mark
Mark Sanders is offline Find More Posts by Mark Sanders
Old Mar 04, 2002, 09:10 AM
Azarr is offline
Find More Posts by Azarr
Old age is not for sissies
Azarr's Avatar
Dayton Intl, Ohio, United States
Joined Jan 2000
Re: New APC folding props - Anyone seen or used ?
I'll try and post a picture later, basically, the hub is a two piece affair that bolts together and has recesses to accept a molded protrusion of the ends of the blades. Unfortunately the hubs have an 8mm prop shaft hole so they normally have to be bushed down. The blades do not have pin holes drilled, so they cannot be used with more conventional hubs.
Azarr
www.ecubedrc.com
Azarr is offline Find More Posts by Azarr
Old Mar 04, 2002, 10:20 AM
Sparky Paul is offline
Find More Posts by Sparky Paul
Ascended Master
Sparky Paul's Avatar
Palmdale, CA
Joined Oct 2000
Here's what the APC hubs look like..
and the blades can be use in some other hubs..
Sparky Paul is offline Find More Posts by Sparky Paul
Old Mar 04, 2002, 10:59 AM
JRuggiero is offline
Find More Posts by JRuggiero
Blacksburg, VA 24060 USA
Joined Feb 2000
Reliable?
Mayhbe it's a silly question, but is such a blade mounting system reliable? How many Gs does it take for the blade bosses to work their way out of the hub holes? I prefer steel screws to secure my blades.
JRuggiero is offline Find More Posts by JRuggiero
Old Mar 04, 2002, 12:29 PM
California Condor is online now
Find More Posts by California Condor
Old Timer
California Condor's Avatar
CARMICHAEL, CALIFORNIA USA
Joined Apr 2001
Re: Reliable?
How about being tested with a 10 hp motor at over 16,000 rpm!
California Condor is online now Find More Posts by California Condor
Old Mar 04, 2002, 01:32 PM
Troy is online now
Find More Posts by Troy
Caution:Makes sharp left turns
Troy's Avatar
United States, CA, Lake Forest
Joined Feb 1999
Is that a proposal or testimonial?
Troy is online now Find More Posts by Troy
Old Mar 04, 2002, 02:43 PM
Windsor, UK
Joined Jun 2001
Thanks Paul - 1 picture = 1000 words Mark
Old Mar 04, 2002, 02:56 PM
Cometlover is offline
Find More Posts by Cometlover
Still diggin' holes...
Belgium
Joined Jan 2002
Re: Reliable?
I don't know if you know how much force it takes to break a steel screw the way they are used in those folders, but I can guarantee you that screw is a lot stronger then the prop blade...
Second thing, if a manufacturer like APC thinks it's ok, I'm sure they have tested it thousands of times. They won't put something on the market that isn't 100% safe (when used correctly).
Cometlover is offline Find More Posts by Cometlover
Old Mar 04, 2002, 07:59 PM
jrb is offline
jrb
Find More Posts by jrb
jrb
Member
jrb's Avatar
Edina, MN, USA
Joined Oct 1999
Don't have the info with me; but there are some collet adpater parts @ Hobby Lobby that match the taper of the APC"F" hub.
I think it was like 25050 for 5mm 25040 for 4mm and 25032 for 3.2 mm.
Its near the Fruend.... folder.
The spinners will work as well!
jrb is offline Find More Posts by jrb
Discussion LOOK- New Lipo, has anybody seen or used them? wilscor41 Batteries and Chargers 16 Aug 21, 2007 08:55 PM
Has anyone seen or used WHITE fanfold? I FO nut Foamies (Kits) 7 Nov 29, 2003 09:59 AM
APC Folding props mt_100 Electric Plane Talk 0 Aug 05, 2001 03:40 AM
How to make the new APC Electric props fit your adapter Joe Elston Electric Plane Talk 6 Jun 17, 2001 01:56 AM
Will APC Folding props fit directly on a SP400? Foxtrot Electric Plane Talk 5 May 30, 2001 10:32 PM
