Old Dec 31, 2013, 04:28 PM
super kupfer is offline
Find More Posts by super kupfer
Anything that gives me a High
super kupfer's Avatar
Canada, BC, Richmond
Joined Jan 2010
Build Log
Kyosho F4U Corsair 40 ARF
Planning to convert the subject to electric.
I got it a few months ago and was thinking whether to power it with gas/nitro or electric, I decided to go with electric (planning to go with OS 50 motor).
This is not going to be a basic conversion as I'm planning to incorporate some additions, I'm currently building a YA F16 so to finish this is not a priority.
super kupfer is offline Find More Posts by super kupfer
Old Dec 31, 2013, 04:30 PM
Joined Jan 2010
Started with striping all covering, The wing construction looks top quality.
Old Dec 31, 2013, 04:42 PM
Joined Jan 2010
The glass work on the fuse looks great.
Using a Dremel I started with opening the exhaust holes (planning to put a dummy one), tail gear opening (going to install a retract), cockpit floor (planning to put a full size one or may even scratch build one).
Old Dec 31, 2013, 04:54 PM
Joined Jan 2010
Next would be to remove the radio tray and install one that would be electric friendly (need one with a battery tray).
Glue joints were very weak so I removed center and rear bulkheads as well (going to cut and glue new ones).
Old Dec 31, 2013, 05:22 PM
Joined Jan 2010
If anybody has this bird, can you tell me if its epoxy or poly fuse? How do you tell the difference?
Old Jan 05, 2014, 09:49 PM
Joined Jan 2010
Still working on those new bulkheads (Since I didnt get a respond to the above post, I will be using Hysol on everything).
In the mean time I decided to fit the rudder on.
Old Jan 09, 2014, 10:16 PM
Joined Jan 2010
Today I got my:
OS 50 motor, Robart 100deg. rotating retracts, Robart 3" scale wheels.
Going to start some more dremeling and also gluing this weekend.
BTW, the fuse is made of poly not epoxy glass (thank god my sense of smell is back after that nasty cold I had).
Old Jan 10, 2014, 12:59 AM
scirocco is offline
Find More Posts by scirocco
scirocco's Avatar
Australia, ACT, Kambah
Joined Feb 2001
You're going to like that motor. About 1300W (6S 16 x12) and it comes down only warm on a 30+ degree C day.
scirocco is offline Find More Posts by scirocco
Old Jan 10, 2014, 07:14 PM
Joined Jan 2010
Its my first OS motor
Article Banana Hobby's BlitzRCWorks 9 Ch 1.2m F4U Corsair ARF Review Michael Heer Electric Warbirds 132 Apr 20, 2015 10:25 AM
Discussion ESM F4U Corsair Color F 74" Wingspan Model ARF scootrb4 Fuel Warbirds 144 Mar 15, 2015 09:49 AM
Question Kyosho F4U Corsair 40 ARF gagallagher044 Fuel Warbirds 25 Dec 16, 2013 05:23 AM
Sold 5-CH AirField1430mm F4U Corsair ARF w/ Motor/ESC/Retracts $100 Winterdd Aircraft - Electric - Airplanes (FS/W) 2 Oct 09, 2013 12:55 PM
Rant Kyosho/f4u corsair ARF- HELP! jetfighter Fuel Warbirds 2 Jun 22, 2004 12:27 PM
