Old Mar 16, 2012, 04:28 AM
minkyboodle is offline
Find More Posts by minkyboodle
United States, NH, Nashua
Joined Dec 2011
Help!
lipo Short?
ok so i was going to cut the positive wire on my new lipo and when i went to cut it sparks flew everywhere, the negative wire wasn't touching the positive either.
any idea what happened, is this a short?
should i toss the batt.
minkyboodle is offline Find More Posts by minkyboodle
Old Mar 16, 2012, 05:03 AM
sts41 is offline
Find More Posts by sts41
Canada, ON, Stouffville
Joined Nov 2011
I guess I was too late
Well either the girl of your dreams walked into the room.....Or more likely the battery was shorted if sparks occured....
If you mesure each tap on the balancing plug...Is it above 3 volts?
If so you are probably OK...lower than 3V...probably worthless for flying.
sts41
sts41 is offline Find More Posts by sts41
Old Mar 16, 2012, 07:05 AM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
Simple truth is that you damaged the new LiPoly and also it sounds like you made the mistake of cutting both leads at the same time.
How badly damaged is it no one can tell you withit testing and most likely you have no suitable testing equipment so try it in a application where if it fails the loss of the aircraft will not be that bad or discharge it to zero and discard it.
And the rest off this Thread , or should be..
http://www.rcgroups.com/forums/showp...81&postcount=1
FYI It is really not necessary to start multi Threads to cover the same subject / question / problem / issue.
You can even edit a post to add information to it. You can also close a duplicate / same subject thread.
Charles
Discussion tenergy lipo short lifespan? numanair Scratchbuilt Indoor and Micro Models 5 Dec 09, 2011 09:24 PM
Question lithium-Poly (LiPo) Failure Mode = Short, Typical? Nehmo Batteries and Chargers 5 Oct 21, 2011 01:09 PM
Question Looking for low profile LiPo, 18-20A in short bursts TTC Batteries and Chargers 3 Oct 10, 2011 02:53 PM
Discussion Lipo care, Lipo short and long term storage/care. Whistler71 Batteries and Chargers 1 Oct 24, 2007 03:25 PM
how long is a short burst in a e-tec lipo jeff262 Batteries and Chargers 3 Jan 13, 2004 06:57 AM
