Go Back   RC Groups > Aircraft - Electric - Helis > Electric Heli Talk
Old Dec 06, 2002, 05:16 PM   #1
New Astroflight motor for Voyager E
I've had the opportunity to test some brushless motors for Bob AKA Astrobob. The best configuration was an "020" size can (very small and light) with a 3 turn armature. This motor produces 4400rpm/volt which allows the use of the stock 15 tooth pinion.
Performance is stunning, especially when the small size of the motor is taken into context. Compared to the stock motor, my VE now climbs at least twice the rate and still manages to get 8+minutes of very fast forward flight and hovering. One of my buddies flies a VE with a much more expensive Hacker motor. It will be very interesting to fly each heli back to back and compare performance and run time. In the coming weeks I will be experimenting with larger pinions and fine tuning the helicopter setup. I will also take temperature readings and tach the head speed.
Bob plans to have this motor available very soon. It will be displayed at the IMS show in January, 2003. The motor will have holes drilled to utilize the stock VE mount. A "heli" ESC with governer mode is under development. I will be testing it when its ready.
Heli setup:
8 3000 mAh nickel metal hydride cells
collective set to -8 0 +10
normal mode throttle curve: 0%, 50%, 100%, 100%, 100%
Idle up throttle curve: 100% all points
HS-81 servos
GY240 heading hold servo
3dwanabe is offline Find More Posts by 3dwanabe   Reply With Quote
Old Dec 06, 2002, 05:31 PM   #2
Our Daddy and Heli Junkie
Fred Bronk's Avatar
The motor sounds great, and an American option for the motor is nice too.
But isn't a 100% throttle curve leaving little headroom to hold headspeed? Or at least not the norm.
Seeing where you are I would like to check it out, and I bet Jon would to.
By the way, I just got a few of his 3 pin ZL plugs and they are very nice
Fred Bronk is offline Find More Posts by Fred Bronk   Reply With Quote
Old Dec 06, 2002, 06:34 PM   #3
johntbyrne's Avatar
Did bob indicate when it may be released (ie, first quarter 2003 perhaps?). I planned on getting a hacker this winter. I have the ESC already. Last piece of the puzzle you know.
Thanks much
John
johntbyrne is offline Find More Posts by johntbyrne   Reply With Quote
Old Dec 06, 2002, 08:01 PM   #4
Fred Bronk's Avatar
We should know at IMS, January 15th weekend.
Old Dec 06, 2002, 09:11 PM   #5
3d,
are you going to bring this tomorrow (sat)? mine is at the store so I will need to get it too compare.
BTW, crashed my rappy30 bigtime today, was getting a little too fancy
Fred,
BTW, I had to basically set my throttle curves on the Logo 20 with the Hacker b50-20xl to 95% in order to keep it from overheating. also seems to like the 38.4K switching mode better???
-jon
JonMann is offline Find More Posts by JonMann   Reply With Quote
Old Dec 06, 2002, 09:27 PM   #6
Tell Bob to make one of these with a Kv of 2800-3300 to run in Eco's and Corona's.
BTW, that motor sounds like it'd be good in a Whisper too!
Later!
Greg in Minneapolis
gstew is offline Find More Posts by gstew   Reply With Quote
Old Dec 06, 2002, 11:29 PM   #7
Site Sponsor
thanks for the update on the Voyager.
looks very good .
we will soon be testing a four turn version
with kv = 3300 in a corona.
hope to have a flight report soon
astrobob
astrobob is offline Find More Posts by astrobob   Reply With Quote
Old Dec 07, 2002, 12:10 AM   #8
What Canary?
KeithK's Avatar
I have an 020 6 turn. I thought the kv was around 3600. You have one with lower windings and lower kv? Is this really an 020 case?
Any chance my 020 would work in my Corona? It needs a good home.
KeithK is offline Find More Posts by KeithK   Reply With Quote
Old Dec 07, 2002, 06:07 AM   #9
A few years back I read somewhere in this forum about someone that used the AF .020 in a conversion LMH. It worked well for a while and then burned up or something. His conclusion was that this may not be quite enough motor.
Has the motor been improved, or just a different wind perhaps?
I have both an AF .020 and .050 and was thinking about trying one of them in a Corona.
tdearth is offline Find More Posts by tdearth   Reply With Quote
Old Dec 07, 2002, 07:24 PM   #10
saw 3D's Voyager fly today with the astro motor. very fast, powerful. good 8 minutes of flight time. motor ran very cool. this is a very impressive motor, Bob did a nice job.
Old Dec 08, 2002, 12:54 AM   #11
Fred Bronk's Avatar
It must eally have good effeciency then. My Hacker runs warm with a heatsink! Plus the VE like to be lite, which this helps even more.
With 3300 cells, it should get close to 10 minutes then!
Old Dec 08, 2002, 01:29 AM   #12
I had a chance to fly the VE again today. After a moderate flight of fast forward flight and hovering, Jon's temp gun indicated 94 degrees F at the hottest point on the motor (the shaft end). The battery was 91 degrees and the controller was at 90 degrees. Ambient temp was approx. 60 degrees. The 020 certainly appears to be operating well within its capabilities. I didn't have a chance to tach the head speed, but it appears to be quite high. What really suprises me is the motor does'nt seem to bog down very much when I pump in full collective. Top end speed in FFF is very fast. More than enough for good sized loops and rolls. Too bad I'm not up to that pilot skill level yet.
One cool thing about electric motors is that they are variable horsepower. Given the same voltage(throttle setting), they draw an amount of current that corresponds with the load applied to them. So even though I am flying at 100% throttle, I am not using 100% of the available power until I load the motor with max collective. Our motors and controllers are most efficient when flown at 100% throttle because the controller is in it's off state for a shorter period of time. This also results in cooler operating temps. As much as possible, I like to have the throttle set at 100% and let the collective dictate how much power I'm drawing from the battery.
Well I didn't get to drag race my buddy with the Hacker. He found out about my hot new motor and decided to check out my helo before bringing his.
My next step is to tach the head speed at hover and possibly make some adjustments with the pinion size to achieve approx. 1650 rpms.
I do not have a Corona or Eco-8 so I cannot comment on how this motor will work in these helos. There are too many variables to consider to make a prediction.
Fred,
If you would like to check out my VE, please feel free to drop me an e-mail.
Attached is a pic of my VE
  • Name: dsc00096.jpg
Old Dec 08, 2002, 01:51 AM   #13
Fred Bronk's Avatar
That is great news, but the idea of running 100% is off a little.
At 100%, the motor has no headroom to pull more power. This has been discused her many times.
A setup that is running very good, will need less headroom, but need it it will or voltage will drop at high amp draw and bogging will occur.
For many of us this will occur little, but occur it will.
What ESC are you running now?
Old Dec 08, 2002, 04:18 AM   #14
NiCd + Mabuchi 550 was da bomb
Talk about minute collective throw; how many degrees of pitch do you get with those hitec horns?
boom is online now Find More Posts by boom   Reply With Quote
Old Dec 08, 2002, 07:32 AM   #15
Fred,
Where can I purchase the 3300 cells? I have heard of theme, but no website?
William
lanew is offline Find More Posts by lanew   Reply With Quote
Sold AF020 motor for Voyager E Earthbound Aircraft - Electric - Power Systems (FS/W) 0 Jun 04, 2007 03:00 PM
For Sale Astro 020 motor for voyager E xrbeast Aircraft - Electric - Helis (FS/W) 1 Jan 23, 2006 01:48 AM
Which Motor For Voyager E? Chasvo Electric Heli Talk 3 Oct 09, 2004 11:21 PM
Astro Flight Motor For Voyager E? Bourbon Electric Heli Talk 3 Jul 22, 2003 01:00 PM
aveox b/l motor for Voyager e Antyoo Electric Heli Talk 8 Nov 30, 2001 12:00 AM
Congratulations SimpleM!
