Old Jul 23, 2014, 08:39 PM
BDK74 is offline
Find More Posts by BDK74
Heavy's good, heavy's reliable
BDK74's Avatar
United States, CA, Thousand Oaks
Joined Sep 2012
2.4 antennae placement with carbon tow
I started this repair project on a Kinetic 100. I have a few methods in mind for repairing the nose area as well as strengthening to keep the nose from buckling again.
My question has to do with whether I should run the antennae (Airtronics 2.4) externally or can I run them inside away from the carbon tow?
I was thinking of running one externally under the removable canopy perpendicular to the fuse, and the other parallel to the fuse away from the tow inside.
Antennae placement may dictate the method of repair I do
Thanks for any info
Brandon
BDK74 is offline Find More Posts by BDK74
Old Jul 23, 2014, 09:22 PM
ALEX HEWSON is offline
Find More Posts by ALEX HEWSON
PB of 733kph
ALEX HEWSON's Avatar
Christchurch, New Zealand
Joined Jul 2005
I have been in the exact shoes as you. K100, nose repair, second hand model.
http://www.rcgroups.com/forums/showp...&postcount=234
Read onwards from that post as to what else i did and what I achieved afterwards
ALEX HEWSON is offline Find More Posts by ALEX HEWSON
Old Jul 23, 2014, 09:35 PM
BDK74 is offline
BDK74's Avatar
Joined Sep 2012
Thanks Alex.
I question this because its only a bit of carbon tow. If it was all carbon there would be no question. I can use either carbon or kevlar for the fix and I would like to keep the antenna inside.
Old Jul 23, 2014, 10:10 PM
PB of 733kph
Joined Jul 2005
I have lost two models that only had carbon tow in the fuselage and still had lock-outs.
Whatever you do, the deciding test is a two man Range check. 30-50 paces, low power, one guy holding model slowly rotating through all angles to the transmitter
Old Jul 24, 2014, 12:49 AM
BDK74 is offline
BDK74's Avatar
Joined Sep 2012
Yea, I don't think my normal "flying range check" will be used.
Old Aug 07, 2014, 07:47 PM
ppectatio is offline
Find More Posts by ppectatio
Joined Aug 2014
good,one guy holding model slowly rotating through all angles to the transmitter
ppectatio is offline Find More Posts by ppectatio
Discussion 2.4 in Carbon Fuse - Antenna Placement screamin' eagle Dynamic Soaring 15 May 22, 2015 08:15 PM
Discussion Antenna placement and carbon fiber...? Skyhunter gulbrandsen FPV Talk 6 Jan 17, 2014 01:57 PM
Question 2.4 antenna placement with carbon fuse GarryOgilvie Sailplane Talk 19 Oct 28, 2013 03:30 PM
Poll 2.4Ghz antenna placement firehorse Radios 14 Oct 24, 2013 02:19 AM
Sold X-Plane Full carbon spread tow 4 servos wing Dbox Aircraft - Sailplanes (FS/W) 10 Sep 21, 2013 10:08 AM
