Old Jun 14, 2014, 08:10 PM
Oldgazer is online now
Find More Posts by Oldgazer
Oldgazer's Avatar
United States, VA, Richmond
Joined Dec 2013
Originally Posted by jasmine2501 View Post
Hey there's nothing wrong with clones... except the low quality
I'll take exception to that statement. I have two clones and the quality differences are like night and day.
I did a "stupid" and bought a Hausler.
Then I snagged a set of Flasher mechanics from RC Aerodyne.
One difference isin the side frames. The Hausler CF sheet is thin and the edges are "ragged". The Flasher side frames are slightly thicker, stiffer, and the edges are nice and clean like you see on quality printed circuit boards.
Another difference is the rotor heads. The Hausler head was plastic (I went FBL after a crash) and the Flasher is metal with a nice blue anodize that is a shade darker than my Tarot FBL head.
Smaller differences are in the boom supports and TR boxes, but over all the RC Aerodyne is much better.
With that being said, both air frames fly very well.
Oldgazer is online now Find More Posts by Oldgazer
Old Jun 15, 2014, 12:36 PM
jasmine2501 is offline
Find More Posts by jasmine2501
Rocket Programmer
jasmine2501's Avatar
United States, AZ, Mesa
Joined Jul 2007
Sure, you can always find quality differences, but I'll stand by my assessment that for example, my Align 450 Pro is overall better in quality than the HK copy. There were some parts on the HK that I consider better, but overall the Trex is the better quality bird. I shot about half of a comparison video a while back, but there's a lot to discuss, and I don't know if I'll ever finish the HK vs. Align video, in spite of promises to my viewers.
jasmine2501 is offline Find More Posts by jasmine2501
Old Jun 15, 2014, 03:36 PM
abenn is offline
Find More Posts by abenn
Letchworth, Great Britain (UK)
Joined Jul 2004
Having read so much about HK clones I decided to get an HK500TT to compare with my T-Rex 500e which has been upgraded with TT tail. The only parts of the HK version that I consider to be better than the Align one are the frame screws (larger hex sockets, so don't seem to round out like the Align ones do) and the metal servo mounting brackets instead of plastic ones. Parts that I consider acceptable are the basic frame structure, the tail boom and TT drive shaft, the front end boom mounting block and TT drive gears, and the landing skids.
abenn is offline Find More Posts by abenn
Old Jun 15, 2014, 06:16 PM
Oldgazer's Avatar
Joined Dec 2013
I was offering a counter-point to a previous state me that ALL clones are inherently inferior.
What this really boils down to is price point. If money is no object, than you can buy what you want. If, on the other hand, you are forced to live within a strict budget, then cost is always the prime consideration and this is where the clones come in to play. Laying aside the myriad of quality issues for a moment, clones are actually bringing more people into the hobby in much the same way that IBM PC clones fueled the digital explosion during the 1990's.
With that being said, as builders and pilots, it is up to us as a community to get the real word out about clones. We need to let people know which clones are acceptable, and which clones are not acceptable. This is a win-win situation. Word of mouth and real world reviews are much more effective than some ad agency hype.
What saddens me is this pervasive clone bashing that borders on out right snobbery. Instead of shrieking in terror and hollering "Burn the Heritic!", what we should be doing is giving the rookie a break by helping him get his money's worth out of his purchase.
Old Jun 15, 2014, 07:01 PM
spykez is offline
Find More Posts by spykez
Where's the swimming pool
spykez's Avatar
Joined Jul 2011
There are some clone products, that are fairly good.
Granted the morality of them is questionable.
I'm talking clone YGE's, clone v-bars.
The one thing I think you still have to put up with is, when you pay so little, QC probably gets sacrificed. So I guess one is rolling the dice more as to whether one gets a good unit or not.
Now the other thing is for mechanical stuff, if the cloner uses softer alloys from the start.... well...
spykez is offline Find More Posts by spykez
Old Jun 16, 2014, 01:57 AM
abenn is offline
Joined Jul 2004
Personally, I'm more wary of clone electronics than I am of clone mechanical bits, for at least with the mechanics I can see/feel where they're not up to scratch.
By the way, wasn't Align once a clone of the Raptor?
Old Jun 16, 2014, 06:24 AM
Oldgazer's Avatar
Joined Dec 2013
You're spot on. I'm wary of clone electronics too. I must say that so far the only time I've been bitten has been through my own error...
However, I have seen knock off electronics in other areas that don't cut the mustard.
With that said, over the weekend I finally got a Tarot TT upgrade for my Hughes 500, and I like what I see. Bearings are nice and smooth, fit and finish is excellent, and this is a major plus, the tail rotor shaft has an actual flat cut out for the set screw. I added a Tarot metal pitch slider and a metal pitch arm, and this TR is "tight" (no slop) and very smooth.
Old Jun 16, 2014, 11:32 AM
earlwb is online now
Find More Posts by earlwb
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
The other thing about some of the clone stuff is they may be using defective parts that were rejected by the OEM manufacturer for some reason. Instead of recycling and melting the parts down the unscrupulous recycler resells them as originals.
That happens a lot with the electronic components. Plus they may use the defective parts in the fakes and knockoff items, Metal alloys can be a problem if the OEM rejected a lot because of the wrong alloy, casting flaws, or out of tolerance and someone shady sells the things off as original.
earlwb is online now Find More Posts by earlwb
Old Jun 16, 2014, 11:37 AM
spykez is offline
spykez's Avatar
Joined Jul 2011
For all we know, the same factories in China could be making the same bits, and selling the stuff not meeting QC for the brand name as clones, or selling surplus as clones.
Didn't the factory making YGE's in China do the dirt on them? Or so I heard?
Old Jun 16, 2014, 12:11 PM
ZeniethLily is offline
Find More Posts by ZeniethLily
Ground Repeller
Singapore
Joined Jun 2014
its more likely they are selling the blueprints or molds/cnc pattern to other factories to make a quick buck (OEMs do this all the time apparently, which is why you can never keep your design safe by producing in China)
ZeniethLily is offline Find More Posts by ZeniethLily
Old Jun 16, 2014, 12:38 PM
Rocket Programmer
Joined Jul 2007
No, the Raptor used mechanical mixing. The first Align chopper was eCCPM, and was basically an upgrade to the Shogun from EF Helicopters of California. The Align Trex basically put EF out of business, the design was so much better. The Shogun is still sold today under another name though. With modern electrics, it can fly pretty well. All mine needs is a new motor.
Old Jun 16, 2014, 01:50 PM
Brutus1967 is offline
Find More Posts by Brutus1967
I convince things to work
The Netherlands
Joined Nov 2009
I seem to remember a long time ago (maybe as much as 8 years or so) that a friend of mine had a couple of 450 size, or maybe even smaller, Raptor lookalikes. I remember clearly the big pitch cantilever with the roll servo built into it.
I thought he referred to them as "the little T-rexes".
Anybody an idea what those were?
Brgds, Bert
Brutus1967 is offline Find More Posts by Brutus1967
Old Jun 16, 2014, 01:57 PM
Rocket Programmer
Joined Jul 2007
Brgds, Bert
Interesting.. The first Trex I can remember is the XL, which had eCCPM with ridiculous linkages and bell cranks. There were two ways that I remember to do mechanical mixing... One is like you describe where the whole servo tray moves up and down. The other is where the main shaft has a linkage inside that moves the washout up and down, which is how the Shogun worked. I don't remember if Align ever used that method.
Old Jun 16, 2014, 02:40 PM
heli_haven is offline
Find More Posts by heli_haven
heli_haven's Avatar
United States, SC, Moncks Corner
Joined Mar 2012
Trex 450 SA I think? I still got one somewhere...looks just like a larger thunder tiger raptor...just scaled down...
heli_haven is offline Find More Posts by heli_haven
Old Jun 16, 2014, 03:03 PM
Rocket Programmer
Joined Jul 2007
The SA was the one that was partially assembled and sold with the motor but no servos. It was the same kit as the SE but with a few cheaper parts. My first CP was a Trex 450 SA back in 2008.
Discussion mainboard lifespan of Microhelis helihanz Micro Helis 16 May 12, 2014 03:27 PM
Discussion Motor Lifespan for Quad copter ajayoct Multirotor Talk 2 Apr 01, 2014 02:53 PM
Discussion Brushed Motors - Lifespan dsheikh573 Power Systems 5 Nov 05, 2013 03:30 AM
General lifespan of the 600AE battery Scott C Electric Plane Talk 3 Sep 20, 2001 10:21 PM
nimh lifespan bpu6999 Power Systems 9 Jun 03, 2001 01:08 PM
