Old Apr 27, 2014, 06:29 AM
mastroggeppo is offline
Find More Posts by mastroggeppo
mastroggeppo's Avatar
Joined Jun 2012
Build Log
Alize' build log
Hi guys, this is my first thread on rcgroups. After Gepporunner (see TWF build orgy) my next task is an all-composite tailless wing, specs are:
Description: Name: uploadfromtaptalk1398598070157.jpg
Description: see soon for update ( some moulds are ready to work.... )
Mastroggeppo
mastroggeppo is offline Find More Posts by mastroggeppo
Old Apr 27, 2014, 07:53 AM
Cable is offline
Find More Posts by Cable
United States, CA, Lancaster
Joined May 2013
All composite. Nice! Looking forward to watching how this turns out.
Cable is offline Find More Posts by Cable
Old Apr 27, 2014, 09:02 AM
Joined Jun 2012
Here som other shoots....Name: uploadfromtaptalk1398607298286.jpg
Description: Name: uploadfromtaptalk1398607310126.jpg
Description: Name: uploadfromtaptalk1398607332825.jpg
Description:
Mastroggeppo
Old Apr 27, 2014, 10:38 AM
Knoll53 is online now
Find More Posts by Knoll53
less is more
Knoll53's Avatar
United States, CA, Marina
Joined Sep 2006
Looks like a speed demon. What sort of control surfaces do you have planned?
Knoll53 is online now Find More Posts by Knoll53
Old Apr 27, 2014, 02:18 PM
HerkS is online now
Find More Posts by HerkS
Herk
HerkS's Avatar
Virginia USA
Joined Jun 2007
subscribed
Kent - that's my question too?????????
HerkS is online now Find More Posts by HerkS
Old Apr 27, 2014, 02:52 PM
Joined Jun 2012
The control surfaces will be:
Aileron (external)
Elevator (internal)
Rudder
And....
A a system which allows a in-flight C of G variable position.
Substantially a servo controlled moving mass mixed with elevons to compensate and adjust trim speed.
Mastroggeppo
Old Apr 27, 2014, 04:38 PM
less is more
Knoll53's Avatar
Joined Sep 2006
At 2.5m you could use a ballast system too.........
I tried a moveable weight on low AR Horten wing and even though the weight had a lot of travel, CG change was minor. Your wing will be more sensitive. so maybe there's a workable system for you. How much CG change are you aiming for?
Old Apr 28, 2014, 12:54 AM
Joined Jun 2012
With a ballast between 200 and 400g i did some calculation and have (with a total weigth of 1600-2000g) a C.G. moving about +/-5 +/-10 mm. With a plank-like planform like this it will be work for fine tuning CG.
Old Apr 28, 2014, 09:56 AM
less is more
Knoll53's Avatar
Joined Sep 2006
That would be great.
Even a 3mm CG shift would be noticeable. So if I understand correctly, you are planning on making the ballast moveable in order to achieve in-air CG adjustment.
Old Apr 28, 2014, 10:20 AM
Joined Jun 2012
Yes it's correct, i will mix some up or down deflection of entire wing to widen the speed range of the plane. backwards CG for poor condition and more reactivity, (it's a sloper) and forward position when is needed more stability on rough condition.
here some work on the moulds, this is the tail mould, lamination of first piece, and first piece out of the mold (in Banzai edition !)
See soon
Mastroggeppo
Old Apr 28, 2014, 11:23 AM
less is more
Knoll53's Avatar
Joined Sep 2006
Holy Moly it's molded !
This may be the first molded project to arrive at the Nurflügel forum. I understood that it is all composite, but that could have been vac. bag over foam.
That is a really, really, REALLY nice looking fin.
Old Apr 28, 2014, 12:05 PM
Joined Jun 2012
Yes, is made all in vacum bag a -0.85bar at 40°C in custom made oven.
The layup for this piece was:
- release agent
- 2k polyurethane finish, red and white
- 25g plain glass cloth
- 80g twill glass cloth (at+/-45°)
- 1,2mm airex C7075
- 50g plain glass cloth
plus peelply+microhole release film+aereator cloth
Mastroggeppo
Old Apr 28, 2014, 02:50 PM
less is more
Knoll53's Avatar
Joined Sep 2006
Wow again...............
So the skin is a molded laminate with a "foam" airex C7075 core.
The airex must provide for a very stiff laminate......no need for carbon fiber, even at DS speeds.
The great thing about molded composites is that once you have completed the massive amount of work to perfect the molds, you can "pop out" the highest quality parts in day.
If any plank has a chance of breaking the DS speed record, I would think that it would be this one.
I'm still trying to guess what country you are from.... the airex was a good clue. Here's my guess.
Old Apr 28, 2014, 04:44 PM
Joined Jun 2012
You are right . I'm from Revello , Italy, near to Monviso mountains ....
Old Apr 29, 2014, 02:36 AM
Joined Jun 2012
Alize
.... And here his sister.... again same weigth 68g
Mastroggeppo
Link RC kite build logs.. show your kite and link it to your build log davereap RC Kites 15 Feb 10, 2015 09:29 PM
Build Log Build Log or not to Build Log ??? Chris Craft Tripple Barrel Back Animal2449 Scale Boats 180 May 11, 2014 02:03 PM
Build Log build log of a scratchbuilt multirotor and 3 axis gimbal biggles uk Multirotor Talk 21 Dec 02, 2013 11:46 AM
Build Log MultiWii/FPV/H-Quad Build Log AdrianM Scratchbuilt Multirotors 9 Oct 15, 2013 09:13 AM
