Old Jan 03, 2014, 04:02 AM
hamburger is offline
Find More Posts by hamburger
Hamburger
hamburger's Avatar
Joined Jan 2010
Help!
4blade head for 450 class - recommendation wanted.
Hi,
I have a HK 450 4blade head, but I am not happy with it. The swash plate has a tendency to come apart, the swash follower assembly has lots of slop etc.
So I am looking for a quality replacement, Scale looks is not a must. So far I have only found the ehirobo products .
What are your experiences? What can you recommend? Also, what blades do you use? I had semi-symmetrical blades from ehirobo which seemed to be kinda soft compared to regular CF blades?
Thanks for all pointers.
hamburger is offline Find More Posts by hamburger
Old Jan 03, 2014, 04:09 AM
Brutus1967 is offline
Find More Posts by Brutus1967
I convince things to work
The Netherlands
Joined Nov 2009
Check out the DEAO head...
http://www.deao-helicopter.com/
At least the swashfollower is the best in its class, the swashplate one of the sturdiest I have seen, and stability is real nice, even without FBL....
In my opinion the head itself is also very high quality, but people have had issues with wobble if the Jesus-Bolt is tightened too far. Even though it feels unnatural, fingertight shoud do it here...
Downside is that there are no other blades availlable but the ones DEAO supplies are fairly OK. I only wish he also would supply longer blades...
Brgds, Bert
Brutus1967 is offline Find More Posts by Brutus1967
Old Jan 03, 2014, 08:06 AM
Hamburger
hamburger's Avatar
Joined Jan 2010
thanks for pointing me to DEAO. It looks like the blades cannot be folded together (two to front, two to back) for transportation though. And I would like to pertain the choice of blades - lately I had flown with semi-symetrical blades and liked it some.
Old Jan 03, 2014, 12:26 PM
The Netherlands
Joined Nov 2009
The DEAO blades ARE semi-symetrical and have an excellent lift.
The blades can fold if you care to remove one bolt of each blade 1 set of opposite blades.
This head can take a hit: I "crashed" mine when the skids got fouled in some high grass, toppling over the heli under power (rather violently even), but I only damaged one servo (stripped gear), stripped the main gear and did not even bend the mainshaft.
It is definitely a very good head, but of course, if you crash at full speed, everything can break...
Brgds, Bert
Old Jan 03, 2014, 02:01 PM
holtneil is offline
Find More Posts by holtneil
holtneil's Avatar
United Kingdom, England, Slough
Joined Dec 2012
HI mate align do a 4 bladed head may be the 500 ,but found these if it helps
http://www.ebay.com/itm/5-Blade-Roto...-/111243669957
http://www.ebay.com/itm/US-SHIP-4-Bl...-/171133595185
https://www.google.co.uk/url?sa=t&rc...Zwe6v1ZZNrW7Iw
holtneil is offline Find More Posts by holtneil
For Sale WK-G011 head holding lock Gyro for 450 Class helicopter tengarang Aircraft - Electric - Helis (FS/W) 0 Aug 20, 2013 02:05 PM
Sold WK-G011 head holding lock Gyro for 450 Class helicopter tengarang Aircraft - General - Miscellaneous (FS/W) 0 Mar 21, 2013 10:57 PM
For Sale New FBL V-Bar head conversion for 450 class heli 11290 Aircraft - Electric - Helis (FS/W) 3 Jan 29, 2011 04:08 PM
Discussion Looking for for recommendations for a RTF 450 class CNC Heli jhamm Mini Helis 16 Dec 16, 2008 11:49 PM
Wanted For Trade, 450/600 Class Helis Wanted davidg51537 Aircraft - Electric - Helis (FS/W) 0 Feb 11, 2008 02:00 PM
