Old Mar 19, 2014, 04:18 PM
Alan Sherwood is online now
Find More Posts by Alan Sherwood
Melbourne, Australia
Joined May 2005
A further development on ballonets. A common problem with any scale model blimp is that they are tail heavy. The distribution of gondolas and engines that works for the prototype often doesnít for a model; fins with servos are always heavier and push the cg aft, so you need ballast at the nose, a waste of weight. Itís hard to put anything useful there, except perhaps batteries, but then you have problems with the long cables.
An alternative solution is a nose ballonet. A fixed volume ballonet in the nose pushes the helium aft and restores balance. You need less ballast (if any) at the nose, and use less helium too. See sketch below. The main ballonet is variable volume, controlled by blower and valve.
I have done this on my model ZPG-3W (see postings above). I actually used a latex balloon, with a filler poking out the nose. I blow it up with 45 litres of air from an air mattress hand pump inflator, then seal it. Then fill the main bag with helium. Saves 50 grams of ballast at the nose, and works fine. The only thing to watch is that an air filled latex balloon inside a helium envelope will expand as helium diffuses in. I tested this, it swelled by 5% over 4 hours.
Alan Sherwood is online now Find More Posts by Alan Sherwood
Old Mar 21, 2014, 01:25 AM
pyronaught is offline
Find More Posts by pyronaught
Joined Feb 2009
Wow, that thing looks so realistic I could swear I was watching video of the real blimp! Just slow down the frame rate so the rapid motion wasn't a give-away and you could really convince people they were looking at the real thing. Nice job!
pyronaught is offline Find More Posts by pyronaught
Old Mar 21, 2014, 03:04 PM
ruzam is offline
Find More Posts by ruzam
Go small or go home
ruzam's Avatar
Canada, SK, Regina
Joined Mar 2008
I've found a product at the craft store for sealing helium in latex balloons. 'Hi float' or something. It's a Liquid rubber of some sort. Squirt a bit in the balloon and run it around the intrepid before filling. It really does seal the helium in, at the cost of a little more weight.
In our flying gym there was a common latex party balloon stuck in the ceiling for over 4 weeks. I eventually recovered it with another balloon on a string. Even after all that time it was still well inflated with good lift. An untreated latex balloon will be drooping in a day. I'm thinking of rubbing it in my envelopes, or at least along the seams.
I'm not happy with the pressure changes my micro blimps go through. A ballonet is probably the answer, but I can't see his it could be made light enough. I've seen self inflating Whoopi cushions that have a foam sponge inside. Maybe a flat foil bag with a light weight 'sponge' material to act as a mechanical pressure spring. Just enough to absorb temperature pressure changes for a flying session
ruzam is offline Find More Posts by ruzam
Old Aug 07, 2014, 05:33 AM
Joined May 2005
Another video of my ZPG-3W. Works a lot better when somebody else holds the camera!
IMG 0581000428 029 001348 567 (9 min 22 sec)
Old Aug 07, 2014, 10:42 AM
ruzam is offline
Go small or go home
ruzam's Avatar
Canada, SK, Regina
Joined Mar 2008
Wow! She's a beauty Alan. Please post more details!
Old Aug 07, 2014, 12:23 PM
Joined Feb 2009
What kind of film did you make the envelope with? It looks like the metalized side is on the outside (assuming it was heat sealed).
Old Aug 12, 2014, 09:36 PM
Joined May 2005
Some info on my ZPG-3W blimp:
1.45 cubic meters volume, 4 m long
Typhoon Micro brushless motors, rated at 15 A each (although I haven’t been game to run at full throttle in flight, it’s a handful at half speed)
Controls are rudder, elevator (mixed) and throttle (fwd only, no reverse)
Envelope is made from 15 micron plain aluminised nylon film. I built it about 20 years ago before foil balloon material became available; I had to scrounge around packaging companies for some samples. The gores are glued with contact adhesive. It had stood up reasonably well over the years, needing occasional peeling seam resealing. It does leak now, although at a tolerable level.
Old Nov 08, 2014, 01:02 PM
PhoenixFlyer is offline
Find More Posts by PhoenixFlyer
PhoenixFlyer
PhoenixFlyer's Avatar
South Florida
Joined Dec 2006
Ballonets
Ballonets in the old 2W blimps, were like blisters, fore and aft, also port and starboard. Imagine them sealed to the main bag. We would pump them up when the bag was heavy, and valve when the bag was light. Combo tanks held water, usually sea water, for ballast.
I cannot remember about the 3W, I had been in the tube looking thru to the inside of the bag. There was a large radome inside the 3W bags, could not see that much. 3W attached.
Vince
AEW-ZW-1 Lakehurst
PhoenixFlyer is offline Find More Posts by PhoenixFlyer
Electric Motor equivalent to the G23/G26 gas engine for blimp use? Frisk151 Power Systems 5 Jun 29, 2009 07:18 AM
Looking for Blimp Pilot in Evansville, IN area AcePurple Blimps 1 May 21, 2007 11:35 PM
Dual gas engines for blimp A-Train Prod. Blimps 5 Oct 14, 2005 01:09 AM
Optic 6 for blimp A-Train Prod. Radios 4 Sep 15, 2005 07:33 PM
Question Dual engines for blimp A-Train Prod. Engines 12 Sep 15, 2005 06:38 PM
