Old Dec 29, 2002, 06:24 AM
london england
Joined Dec 2002
Question
piccolo pro
Hi I wondered if anyone could let me know if they have had major problems with the pro ie; it just does'nt seem towork very well
ian harris is offline Find More Posts by ian harris
Old Dec 29, 2002, 11:48 AM
EDF Jet Jam 2015, May 28-31st
Robert Belluomini's Avatar
United States, KY, Crestview Hills
Joined Dec 2000
I have a PIC Pro and I am very pleased with it. What seems to be the problem? I am flying mine with seperate components from the start and it has worked great.
Bob
Robert Belluomini is online now Find More Posts by Robert Belluomini
Old Dec 29, 2002, 12:59 PM
london england
Joined Dec 2002
pro problem
Hi
well when its powered up the tail spins but not always the same way and tail motors don't last more than a few flights.
do you fly with head in hold
Old Dec 29, 2002, 01:40 PM
Live to ride... and fly!
Tres Wright's Avatar
Forney, TX
Joined Mar 2002
==when its powered up the tail spins but not always the same way ==
Are you using a Piccoboard? Mine does the same thing at low throttle settings, I always have to correct the yaw to get the tail pointed the right way before liftoff. It's like the tail motor has a mind of its own until about 50% throttle.
Tres Wright is offline Find More Posts by Tres Wright
Old Dec 29, 2002, 02:41 PM
london england
Joined Dec 2002
pro problem
No the tail spins at full throttle and yes it's with pico plus board
it has never flown right it does seem to have amind of it's own
can not correct it thanks for your replies chaps
Ian
Old Dec 29, 2002, 06:13 PM
Coimbra, Portugal
Joined Feb 2000
Hi Ian,
Is the Picoboard installed in the position the instructions say?
If not the gyro might not be stabilizing the vertical axis of the bird (with the tail rotor) as it should. A fellow clubmate did that mistake.
BTW a question: is the tail motor of the Pro a GWS or is the same motor of the standard Pic?
Thanks, Joćo
joao is offline Find More Posts by joao
Old Dec 30, 2002, 05:22 AM
london england
Joined Dec 2002
pro problem
Hi jaoa
Yes everything is as it should be and tail motor is pro
has had new pico board various tail motors but still the d*** thing will not perform like it should it flies once ok then seems to go haywire just cant get it right thanks
IAN
Old Dec 30, 2002, 06:08 AM
Rotorhead
Luxor's Avatar
Oly, Wa, USA
Joined Jun 2001
Slipping tail pinion maybe?
Eric S.
Luxor is offline Find More Posts by Luxor
Old Dec 30, 2002, 09:47 AM
FlyTime's Avatar
Webster, NY
Joined Dec 2002
Hi Ian,
I'm not sure I understand your problem. Is it that it did fly but now the tail motor goes full speed? Or has it not worked at all?
If it did work and now doesn't check you battery voltage. It was the case that as the battery voltage drops very low the tail rotor motor goes to full speed.
Or if voltage is good and it did fly it could be a failed controller
If you did not ever get it to work check your tail rotor servo direction. I believe it needs to be in the "reversed" and not normal.
Or again it could be a defective controller
I hope this helps
j
FlyTime is offline Find More Posts by FlyTime
Piccolo Pro Brushless 020 ok? DarkWing Electric Heli Talk 0 Aug 19, 2002 11:25 AM
Someone finally recieved a Piccolo Pro Tom Cardiff Electric Heli Talk 0 Aug 09, 2002 01:50 PM
Piccolo Pro -- where to buy? serious_sam Electric Heli Talk 9 Aug 03, 2002 08:56 PM
Anyone Know When The Piccolo Pro Will Be Available JUSTGLUEIT Electric Heli Talk 0 May 08, 2002 09:40 PM
Nurnberg Toy Fair pics(CP Piccolo Pro, Hornet CP, ect...) Eco8gator Electric Heli Talk 11 Feb 08, 2002 12:36 PM
