Closed Thread
Old Nov 22, 2014, 05:07 PM
CAVU morning, to you!
trhodes1's Avatar
United States, CO, Erie
Joined Aug 2014
Question
Futaba T8J Flaperon Programming
I'm trying to program a flaperon function and need some help.
I'm using Futaba 2006 GS receiver and have individual 9gm servos on each aileron (no flaps - 4 channels). When I go through the manual procedure and use channel 6 for flaps, I get ailerons moving opposite each other - not as flaps should.
any siggestions - help?
trhodes1 is offline Find More Posts by trhodes1
Old Nov 22, 2014, 06:33 PM
S.A.D. member
ivanc's Avatar
United States, TX, Round Rock
Joined Dec 2004
There are 6 values in the FLAPERON mix:
AIL1 (L)
AIL1 (R)
AIL2 (L)
AIL2 (R)
FLP2
FLP1
see the attached image.
If the ailerons move in opposite directions when using the aileron stick but also move in the opposite direction when using the flap switch or dial, change one of the FLP from positive to negative or from negative to positive to reverse the aileron which goes up when using the flap function.
You may also want to reduce the FLP1 and FLP2 rates from 100% to something like 30% to 50% so you don't lose roll control when the ailerons are down as flaps.
If the plane has ailerons towards the wingtips only, don't use them as flaps as this will stall the outboard area of the wing and the plane will drop a wingtip at low speeds. Use the ailerons as flaps only with full length ailerons which come all the way to the fuselage.
Ivan
ivanc is offline Find More Posts by ivanc
Old Nov 23, 2014, 09:12 AM
trhodes1's Avatar
Joined Aug 2014
AIL1 (L)
AIL1 (R)
AIL2 (L)
AIL2 (R)
FLP2
FLP1
Ivan
Thanks for the reply. I'll try that. It does have full length ailerons.
Closed Thread
Discussion Futaba 9C, how to program for flaperons? sidgates50 Radios 3 Sep 20, 2014 11:33 PM
Help! How to Programming Futaba T8J for Axial Wraith? blackmennewstyle Rock Crawlers 19 May 12, 2014 01:05 PM
Help! Programming Futaba T8J to Naza M-V2 Shannons.spot Radios 1 Oct 21, 2013 03:37 AM
Help! Programming Futaba T8j Shannons.spot Electric Motor Design and Construction 2 Aug 03, 2013 10:50 AM
Help! Please HELP me! Futaba T8J Flaperons.. big_andre Radios 1 Jul 29, 2012 04:19 PM
