Old Nov 20, 2014, 06:56 PM
United States, MO, Fenton
Joined Jan 2012
New Product
HobbyKing™ Wingnetic Sport Speed Wing EPO 805mm
New twist on the Kinetic from Hobby King.
http://www.hobbyking.com/hobbyking/s...05mm_PNF_.html
Fentonflyers is online now Find More Posts by Fentonflyers
Old Dec 09, 2014, 12:06 PM
Joined Jan 2012
Now in stock.
Old Dec 12, 2014, 05:51 PM
If it flies.....I can crash it
blackbrabus's Avatar
United Kingdom, England, Preston on Stour
Joined Nov 2011
Got my wingnetic today......built in less than an hour (using own glue).......went out for the maiden.......and smashed it to pieces on launch due to the tiny finger holes not giving me enough grip on the plane.
pictures and video to follow.
but a note to all....take care on launch.
blackbrabus is online now Find More Posts by blackbrabus
Old Dec 12, 2014, 06:03 PM
Joined Jan 2012
Man that sucks. A little trick I learned. Glue some medium grit sand paper into the divots of the grips. Helps a bunch!
Old Dec 12, 2014, 06:05 PM
Joined Jan 2012
I haven't ordered mine yet. Was going to wait for some flight reports. I may go ahead. If I do I will get the arf with motor.
Old Dec 12, 2014, 06:53 PM
Foam is my friend!!!
NewZee's Avatar
United States, NY, Depew
Joined Mar 2014
Hey Fenton! (see you on the "Ominus" thread!) Anyway just ordered the Wingnetic . While I was surfing the HK site an add popped up offering the PNF version for $77!!! so I thought WTH!!?? I was thinking of buying a motor, folding prop, ESC etc. for a glider I'm re-building, and fiqured if I crash this I can use all the stuff in other planes? I'm interested if others have flown this yet??
At 32" WS it's small enough to throw in the car and go! Hope it's a decent flyer??
NewZee is offline Find More Posts by NewZee
Old Dec 12, 2014, 06:55 PM
NewZee's Avatar
Joined Mar 2014
Oh man!!! that bites!! Sorry for your problem, I just ordered a Wingnetic from HK! Will you be able to save yours?
Now you got me thinking about other launch techniques? hold by wingtip? or overhand grasp over the canopy and toss underhand?
Old Dec 12, 2014, 08:05 PM
Joined Nov 2011
Think I'll be going with the wing tip launch.
Should be able to fix it but needs a new prop, adapter, motor mount and canopy.....and a nose section if I didn't want to glue it together.....issue I have is the weights are all wrong on the shipping so it's saying it'll cost me over £10 shipping for 2.7kg.
Mental
Old Dec 12, 2014, 09:07 PM
Joined Jan 2012
blackbrabus don't they have that stuff in the UK warehouse? I have bought items from there for my son when he visits his girlfriend and the shipping was always fast and super cheap.
Old Dec 12, 2014, 09:11 PM
Joined Jan 2012
Yeah Zee I recognize you. I am hoping it's good. I liked what I saw in the product video. I have a Kinetic that I haven't built yet. Might just sell it if this one turns out good.
Old Dec 12, 2014, 09:29 PM
NewZee's Avatar
Joined Mar 2014
Mental
Just watched a HK "Daily Video" saying they have spare parts in all warehouses! You should try the UK warehouse!? Good luck and post a video if you can!
Old Dec 13, 2014, 04:50 AM
Joined Nov 2011
So here is my box to build to crash.
well packaged and arrived with no damage
The only bit of work needed during the build really is cutting the decals to mount the stabs.....but dont get any of the off cut on your fingers....i'll never come off
nice amount of cooling on the motor
lots of room up front........but not used.
battery bay and receiver area looks well planned out
Orange R615 mounted in the fuz......you will need to use a Y lead for the Ailerons due to the servo cables being very short.
the 1000mah lipo fits of but for the CG to be correct without adding weight up front I used the Zippy compact 850mah 3s
all finished and ready for the maiden......I did have to adjust the surface horns to get them level.
and then the maiden
Hobbyking Wingnetic maiden,,,,,,,and crash (2 min 1 sec)
So that really didnt go well.
as I gave about 3/4 throttle the plane pulled out of my fingers and pivoted down from the finger grips into the deck.
new nose, spinner, props, motor mount needed......gutted.
Old Dec 13, 2014, 08:35 AM
NewZee's Avatar
Joined Mar 2014
Thanks so much for the pics and vid! I appreciate you sharing your "Fail" as it will definitely help me (and others) avoid the same mistake (seriously I would have likely done the same thing).
You are also to be commended on how well you handled the disappointment of a failed maiden! That's another thing I could learn from you!
I hope you repair your "Wingnetic" and have many successful flights with her!
Old Dec 13, 2014, 08:52 AM
Joined Jan 2012
+1 Zee. Very well said. Blackbrabus thanks for your post.
Old Dec 13, 2014, 09:20 AM
Joined Nov 2011
Thanks guys.......every failure hurts.
Main reason for posting is to stop anyone doing the same thing.
New Product Hobbyking Sonic 64 Wing EPO 1230mm FltLtBiggles Flying Wings 18 Dec 21, 2014 09:42 AM
Discussion Hobbyking Phantom FPV Flying Wing EPO Airplane 1550mm / 61 inch - closed? PeterVRC FPV Aircraft 8 Oct 10, 2014 03:38 AM
Discussion HobbyKing Dolphin Micro Sport Glider EPO, 555mm (PNF) e_lm_70 Micro Ready-to-Fly 108 Jul 09, 2014 03:23 AM
Sold Hobbyking Phazer KX EDF Jet Flying Wing 860mm EPO xrichierichx Aircraft - Electric - Jets (FS/W) 1 Dec 05, 2013 11:07 AM
Discussion Hobbyking Spirit Mini Sport Glider 815mm EPO (PNF) Westwood Electric Sailplanes 2 Jul 28, 2012 09:09 AM
