Old Oct 21, 2013, 02:13 PM
concreteman's Avatar
United States, CA, Torrance
Joined Aug 2004
Flew more and checked cg. 102. Looking forward to tungsten wing slugs!
WD
concreteman is offline Find More Posts by concreteman
Old Oct 21, 2013, 04:06 PM
Joined Sep 2007
If you are willing to shear info, I would highly appreciate to know a supplier that can make tungsten ballast in these dimensions.
What is the "ownweight" of these tungsten alloys supplied?
Lead is 11,3, tungsten , depending on alloys, all between 15 to above18.
krvedaa is online now Find More Posts by krvedaa
Old Oct 22, 2013, 02:07 PM
Joined Aug 2004
When the tungsten appears I will share the results. I used a friends Fosa slugs, it was essentially double weight, so I am thinking total wing ballast was 55oz. or so. When I find the paperwork, I will forward the information.
WD
Old Nov 05, 2013, 04:53 PM
Joined Aug 2004
Pitbull getting more friendly the more I fly it. Won last 2 local contests using Pitbull. CG 1-2. Tungsten coming soon, will report with pics upon arrival.
WD
Old Nov 05, 2013, 06:21 PM
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
1-2 what?? I think you migt have typo'd and meant CG 102??
R,
Target
target is offline Find More Posts by target
Old Nov 05, 2013, 06:23 PM
Heavy's good, heavy's reliable
BDK74's Avatar
United States, CA, Redondo Beach
Joined Sep 2012
I think that's 1/2
Bout haff way back
BDK74 is offline Find More Posts by BDK74
Old Nov 05, 2013, 06:27 PM
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
Dude! Stop it, that is so funny. Good thing he didn't write 2-3 then!
:-D
Old Nov 05, 2013, 07:37 PM
David Cortina's Avatar
United States, CA, San Marcos
WD
We will work to correct that issue
David Cortina is offline Find More Posts by David Cortina
Old Nov 06, 2013, 08:59 AM
Joined Aug 2004
You comics! Yes 102 cg.
Old Dec 03, 2013, 06:05 PM
Joined Sep 2007
Second Pitbull F3F arrived today
Received my new weapon for moderate to severe conditions, the Pitbull F3F, no tow-hook in this buddy
This one is the normal strong 160grams carbon outer wing skin, I left out the 68 grams carbon inner cloth this time, and this had 50 grams glass cloth inner wing skin. That seems to be some difference in weight.
With pre-installed wing servos, Futaba S3172SV high voltage S-BUS, the weight is 1890 grams. I reccon to add approx. 300 grams to this, that should
give approx. AUW at 2190 grams.
Wings = 700 and 700 grams
Joiners 2x70= 140 grams
V-tails 2x36= 76 grams
Fuselage = 275 grams
Seems to be Pitbull no. 32, at least what it is tagged all over with tape.
Also received a Fosa Lift in same Box along With the Pitbull, and picked up a well used Pike Kobra DS at the local model club meeting today, have been flown to 262mph which should meet my demands for years to come.
A happy day today, I must say.....
Old Dec 07, 2013, 07:13 AM
Joined Sep 2007
After some initinal checking I have concluded that Futaba S3150 size servos would be suitable in the Pitbull.
I was afraid the servo shafts would be too high in the fuselage, but it seems okay that it will not conflict any linkage scratching into the fuselage next to the ballast compartment..
A modified servotray were prepared suitable for Futaba S3150 or S3172SV.
Also saved 3mm of lenght in fuselage compared to original servotray, meaning more space for wiring or whatever other equipment desired.
Old Dec 07, 2013, 09:12 AM
Ja9
Norway, Rogaland, Tjelta
Joined Dec 2004
Kristian.
What batterycell are you using?
I am looking something like that to use in my Pitbull. I`m struggeling to fit battery, reciver and noseweight.
Ja9 is offline Find More Posts by Ja9
Old Dec 07, 2013, 09:42 AM
Joined Sep 2007
Hi Jan,
I will use 2pce. 18650 cells 3,7V Sony 2250mah Li-Ion made to 7,4V battery package to have the extra power and capacity, weight approx. 95 grams as seen in picture above
http://www.fasttech.com/products/142...echargeable-li
Lead in nose at 102mm, for your model 69 grams with this configuration, you should be able fit that in the nose, if made solid, not using lead beads. I used model clay that is baked in the owen at 120 degree celsisius, stuffing the nose in this mass, to make a mould, then after baked, put aluminium foil inside mould and pour lead.
http://www.pandurohobby.no/Catalogue...t-Farm-Animals
I have two 1800mah Lipo battery packages that should be suitable, could have one unused package down to you for 200 kroners.
http://www.elefun.no/p/prod.aspx?v=14106
For your receiver, consider removing the plastic cover from it, heat shrink it and place under ballast tube, if too tight, if using two 18650 cells, should free some space, making you able to place the receiver on top of battery, or under depends how you see it.
Old Dec 09, 2013, 12:01 PM
Ja9
Joined Dec 2004
I ordered some 18650 cells.
Hope that gives me some more room.
My reciever ( Jeti R9 without case) seem to be to big to jam under the ballasttube.
Old Dec 12, 2013, 05:34 PM
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
If you are careful, you can do what I do all the time:
Put the nose of the plane in a tub of water, and pour in the correct amount of lead.
Usually this is hard to do with any gear in (i.e., servo tray mounted), so some trial fit and balance has to occur first. And of course a slight underfill is recommended!
BE SURE THAT NO WATER CAN LEAK IN THE NOSE BEFORE YOU POUR IN THE LIQUID LEAD!!!!!
R,
Target
New Product F3B/F3F Eldorado fly-up85 Multi Task F3X 30 Mar 11, 2014 08:28 AM
FS or Trade: Acacia F3F/F3B/F3J slope racer for heli robdoyle Aircraft - Sailplanes (FS/W) 3 May 12, 2003 07:33 AM
Want to Buy F3F or F3B Dugman Aircraft - Sailplanes (FS/W) 1 May 01, 2003 09:11 PM
F3B and F3F ships - differences ? yclui Thermal 3 Jan 14, 2003 09:13 PM
Wtb: F3b, F3j, F3f g00bd0g Aircraft - Electric - Airplanes (FS/W) 3 Sep 23, 2001 10:15 AM
