Old Dec 27, 2012, 09:00 PM
Joined Dec 2012
Quadrotor power system
Hello all,
I am currently in the process of building a quad-rotor. I just wanted to check to see if these parts would work well together. Hobbyking support wasn't very helpful.
Battery:
http://www.hobbyking.com/hobbyking/s...idProduct=9942
Motor:
http://www.hobbyking.com/hobbyking/s...idProduct=4859
ESC:
http://www.hobbyking.com/hobbyking/s...dProduct=15205
Prop:
http://www.hobbyking.com/hobbyking/s...dProduct=25812
Any help is appreciated!
lief480 is offline Find More Posts by lief480
Old Dec 27, 2012, 10:54 PM
characters welcome!
Mark Wood's Avatar
United States, CA, Bear Valley Springs
Joined Feb 2000
Consider posting in the Multi-rotor forum where the real experts on these craft reside.
Welcome to RCGroups!
mw
Mark Wood is offline Find More Posts by Mark Wood
Old Dec 27, 2012, 11:34 PM
Joined Dec 2012
Thank you I will!
Old Dec 28, 2012, 10:44 AM
snoopy_schulz's Avatar
Germany, lake of constance
Joined Oct 2010
Hi lief480
Your selected motor is totally overloaded with your selected prop and a 3S Lipo. The motor weight is
24 gram. A motor with 24 gram is able to handle about 24 gram * 3W/gram, that means an input power
of about 72 W. I would use your motor only with a 2S Lipo. In the attachment i have a calculation for a 2S and a 3S Lipo.
The input power of the motor is shaft power / (motor efficiency / 100). With 2S your quadrocopter will have a
max thrust of about 1.2 kg (2.6 lbs). That means that the AUW of your quadrocopter should not exceed 0.45 lbs
for a good performance.
Best regards
Micha
snoopy_schulz is offline Find More Posts by snoopy_schulz
Discussion Human powered quadrotor! alevesque Multirotor Talk 1 Sep 05, 2012 10:51 AM
Discussion DJI quadrotor stab system testing sidneyw Multirotor Talk 16 Jul 31, 2011 06:22 PM
Discussion Attempting to make an autonomous control system for my quadrotor Reservation FPV Talk 3 May 08, 2010 08:14 AM
Discussion help in chosing power system for Quadrotor. brij Power Systems 11 Feb 08, 2009 10:55 PM
Discussion help in chosing power system for Quadrotor. brij Power Systems 0 Jan 16, 2009 08:50 PM
