Old Nov 14, 2012, 03:40 PM
Joined Oct 2005
Outrunner Wires in EDF Installation
Is it acceptable to drill through the shroud of an EDF to bring the wires out or should you just run them behind the EDF and out through a hole in the thrust tube.
Jeremy300 is online now Find More Posts by Jeremy300
Old Nov 14, 2012, 03:45 PM
Joined Jan 2011
I'd just bring them out through the back, and through the thrust tube. Fairly certain thats what most do. No need to weaken the shroud.
stingeragents is offline Find More Posts by stingeragents
Old Nov 14, 2012, 04:23 PM
"Take Off" eh!
vettster's Avatar
Canada, ON, Beeton
Joined Aug 2008
You can counter sink it a bit as I have done in this picture. Your behind the staters and mounts, and not much goes on there.
vettster is offline Find More Posts by vettster
Latest blog entry: 3DTRYER ripped me off!!!
Old Nov 14, 2012, 08:48 PM
Pro Horder
turbonut's Avatar
upland CA
Joined Dec 2004
do what ever works..I have done them in a sleeve and even did flat metal tabs to clean up the airflow..but most of the time just run them up the back behind a stator as the loss is not really measureable
Old Nov 14, 2012, 08:52 PM
Vertical Arrival Specialist
clinth01's Avatar
Townsville, Australia
Joined Sep 2009
I usually run the wires around the back of the shroud, but I normally put heat-shrink around the wires that are in the airflow to minimise the disturbance.
clinth01 is offline Find More Posts by clinth01
Old Nov 15, 2012, 01:22 AM
Joined Jun 2012
cs12
PAPE is offline Find More Posts by PAPE
Old Nov 15, 2012, 03:50 AM
Aka: Tom Jenkins
ApexAero's Avatar
United States, FL, West Palm Beach
Joined Aug 2008
Yes!
I read out runner in the title, not practical for an ESC in the thrust tube of an out runner setup
ApexAero is offline Find More Posts by ApexAero
Sold Walkera 10A L3 Micro ESC 22AWG Upgraded Wireing/MicroDeans Installed$10.00 Shipped/PP HeliFlyer711 Aircraft - Electric - Helis (FS/W) 2 Jun 07, 2012 09:46 PM
Sold Change Sun 90mm 12 Blade w/ installed 1800kv Outrunner fastjetadic Aircraft - Electric - Jets (FS/W) 0 May 05, 2012 01:38 PM
Mini-HowTo Installing 26mm outrunner into GWS EDF-55 fan Bruce Abbott Electric Ducted Fan Jet Talk 4 Sep 13, 2010 11:53 AM
Discussion EDF, outrunner and wires Langster Electric Ducted Fan Jet Talk 5 Jan 22, 2010 11:44 AM
