Closed Thread
Old Nov 09, 2011, 02:01 PM
Racing Enthusiast AMA 3557
JetMech2002's Avatar
United States, MO, Sedalia
Joined Sep 2011
Help!
Turnigy 9x will not Stick Set
It was working and now its not. I followed the procedure in the manual just as I did when I first got it, and nothing. Anyone have a suggestion? In the programming you can set the stick config to 1,2,3,or 4 mode.
I use mode two. It will not switch away from mode 1. I had it set, and changed batteries out. now it will not change away. Is there a way to reset to default in the programming? I believe it is probably a software glitch.
Thank you
JetMech2002 is offline Find More Posts by JetMech2002
Old Nov 09, 2011, 05:45 PM
Isleton,ca.
Joined Jun 2005
default
Hold down menu key when turning on transmitter .
Also, when you select mode 2, press menu after, other wise it will not be saved .
T Tail is offline Find More Posts by T Tail
Old Nov 09, 2011, 07:23 PM
Joined Sep 2011
Thanks. I'll give that a try.
Old Nov 09, 2011, 07:37 PM
monkeyhanger's Avatar
Canada, ON
Joined Mar 2010
"Mode 1" means "Model 1", it's just a typo. The radio holds 8 models, so you'll have "Mode 1" through "Mode 8". If I recall, it also says "Mode name" instead of "Model Name".
The screen where you change "Mode", as in Mode 1,2,3, or 4, is called "Stick Select" or something like that, not to be confused with "Mode Select" where you select which model (1-8) you want to fly.
monkeyhanger is offline Find More Posts by monkeyhanger
Old Nov 09, 2011, 11:36 PM
Panorama City, CA
Joined Sep 2004
You must click the menu button after each data entry. Otherwise, new data will not be memorized.
John Kim is offline Find More Posts by John Kim
Old Nov 10, 2011, 01:11 AM
Joined Sep 2011
Thanks Guys! All is well!
Closed Thread
Help! Turnigy and Hobbywing ESCs will not arm helipk Power Systems 8 May 25, 2011 01:29 PM
Discussion Programmable transmitter (Turnigy 9x) Step-by-step set up danda00 Electric Heli Talk 0 Feb 08, 2011 11:57 AM
Discussion Brand new Turnigy 6S will not balance after 10 cycles cardinal43 Batteries and Chargers 133 Aug 08, 2010 05:45 AM
Help! Assigning ch4 to comething other than the left stick in a Turnigy 9x sv650touring Radios 0 Mar 31, 2010 11:39 AM
Discussion 735 SET will not track forward karmann Micro Helis 0 Dec 29, 2008 08:09 PM
