Old Jun 10, 2011, 04:51 PM
Buzz Run Extraordinare!
b-29er's Avatar
USA, MI, Sanford
Joined Jul 2006
large fpv plane question.
I would like to make a large plane to use for fpv. I am thinking something like an easystar, except with an 8' wing. My question is, would this fly on 5lbs of thrust?
b-29er is offline Find More Posts by b-29er
Old Jun 10, 2011, 05:15 PM
T#0
PilotKeeg's Avatar
Steamboat Springs, CO
Joined Aug 2010
first off, have you flown FPV yet?
PilotKeeg is offline Find More Posts by PilotKeeg
Old Jun 10, 2011, 05:18 PM
b-29er's Avatar
USA, MI, Sanford
Joined Jul 2006
yes, on an upgraded wild hawk, 4' stuntcat and a .60 size trainer (6' wingspan)
Old Jun 10, 2011, 05:34 PM
Brazil, PE, Recife
Joined Apr 2011
Search for "14' WS Megastar with Smoke" on YouTube.
radialmind is offline Find More Posts by radialmind
Old Jun 10, 2011, 05:44 PM
WBFlyer's Avatar
Portland, OR
Joined Feb 2007
I fly FPV witha .60 size low wong trainer. 71" wingspan. But I fly out of town with it.
WBFlyer is offline Find More Posts by WBFlyer
Old Jun 10, 2011, 05:46 PM
b-29er's Avatar
USA, MI, Sanford
Joined Jul 2006
i didn't know planes HAD wongs. And for whatever reason, the fpv system I have is sensetive to shock, to the point where full throttle can nearly white out the camera, so it's a pain trying to fly/see with a trainer.
Old Jun 10, 2011, 06:58 PM
I AP'd myself again......
aviatordave's Avatar
Yawn....Iowa
Joined Mar 2005
spelling police....
aviatordave is offline Find More Posts by aviatordave
Old Jun 11, 2011, 02:19 AM
b-29er's Avatar
USA, MI, Sanford
Joined Jul 2006
grammar nazi...
Old Jun 11, 2011, 11:08 AM
Out of the way, Peck!
United States, AR, Arkadelphia
Joined Mar 2010
LOL...otherns poor spellin boddah's me 2. So, i dislike texting...:grin:
I want to build one like this, same construction methods but a higher-mounted wing (lower center of gravity, more stable) and with just a single fuselage, not twin-boom. I like the looks of twin-booms but it will be too bulky for my transportation. I have a truck w/ topper but i'll have other things in it.
http://www.rcgroups.com/forums/showthread.php?t=1034007
For this project i have purchased...
FPV parts I currently have. $794
> = Parts on the way $70
__________________________________________________ _____
Turnigy 9X 9Ch Transmitter w/ 2.4ghz tx module & 8ch rx $60
> FrSky V8HT ACCST 2.4Ghz DIY Module $16
> FrSky V8FR ACCST 2.4Ghz 8CH Receiver (HV) $20
(12) HXT900 9gram 1.6kg .12sec mini servos $33
> (3) HobbyKing 939MG Metal Gear Servos 2.5kg $13
TR 42-40A 1050kv 35A Brushless Outrunner motor $20
TowerPro H40A Brushless ESC w/ 1.5amp BEC $10
TURNIGY 8-15A UBEC $15
> HobbyKing Micro UBEC 3A/5V $4
(6) 3S1P 20C Zippy Flightmax 2200ma LiPo's $54
T610 10amp 200watt Charger/ Balancer $60
(8) 18650 3.7v 2500ma Li-Ions, over-under charge protected $56
(2) 10x5-E APC props $1.50
(2) 11x5.5-E APC props $3
Topflight prop balancer $25
Sunsky 1.2ghz 800mw (500mw) video tx/rx $80
AGL Hobbies OMM 1280mhz Dual Notch Filter $20
(I intend to go with IBCrazy's CP and SPW antennas)
(24) small RAM heatsinks $10
(2) 40mm 12vdc fans $4
Arctic Alumina Thermal Adhesive $10
(These last three are to cool the Video Tx)
(2) cctvohio GP-CX161 micro color board cameras $48
(1) cctvohio micro b/w board camera $Free w/ above
(Will upgrade to a securitycamera2000 600TVL CCD WDR camera when funds allow)
ServoCity 180 servo stretcher $20
7" LCD monitor $80 (for headset FPV rig)
Aiptek MPVR+CB Camcorder, ground station recorder $65 (used)
Aiptek MPVR+CB camcorder AV in-out cables $10
FMA CPD4 CoPilot $60
(Will buy a DragonOSD for $214 when funds allow)
20 pairs of Deans connectors $16
(2) 12", (2) 24" servo extensions, (2) Y-cables $10
(2) Panel Mount On/Off/Switch Jacks $20 (for homemade headtracker) HHT
(2) 36" Badge Retractors $4 (for HHT)
> 33ft Turnigy 5mm Red Heat Shrink Tube $1.60
> 33ft Turnigy 5mm Black Heat Shrink Tube (Yes, it's only $1.60 for 10 meters)
Some 1/4" pink EPS foam
Some packing tape
Gorilla Glue
5-minute epoxy
Various plywood & balsa struts & sheets
Various control rods w/ sheaths & connectors
If anyone has questions or you can't believe the price and need the link, feel free to ask.
Oddmar is offline Find More Posts by Oddmar
Last edited by Oddmar; Jun 11, 2011 at 12:07 PM. Reason: Trying to be a little more descriptive and helpful.
Discussion NewBreedRC 52in. Horus FPV wing grumman5277 FPV Talk 46 Apr 26, 2011 11:06 PM
Discussion Wing Dragon for FPV - FPV Build Log IanJ FPV Talk 10 Jan 03, 2009 09:40 PM
Discussion Questin: Lipo batteries Cheetah401 Batteries and Chargers 1 Sep 13, 2008 02:17 AM
Electric setup questin whidbey1 Electric Plane Talk 8 May 02, 2004 09:11 PM
Tech Questin? GHOST RIDER The Builders Workshop 11 Jan 31, 2004 10:43 PM
